Question about Altusen Aten CS62U-2 Port USB KVM Switch
Only 1 light on leads work and only 1 coputer will work
I have both computers pluged in and the monniter on, but only 1 light is on, on the leads you use to connect the computers together,
That is the way it is designed, only the light of the PC you are controlling will be lit. Once you switch using the hotkeys, the light switches as well.
Posted on May 12, 2009
ZX4800-07 monitor wont come on
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Test all power and data leads that attach to your hard drive IDE,SATA the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even something as small as a faulty electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error Check your RAM. The RAM is located in the middle of the motherboard. There are tabs that you can push to release the RAM. Remove it and put it back in place until the tabs pop out. Loose RAM can cause your computer not to start properly where you want to see a video signal.
Make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free Restart your computer then reinstall it this should activate found new hardware wizard Check the vga lead for secure dust free connection or try another vga lead.
Feb 23, 2013 | Gateway One ZX4800-07 20 inch All in One...
Dell wont boot when pluged in it comes up for split second and shuts down green light on motherboard is lit
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a 40 pin flat ribbon type it will be the fist to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be
faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty power lead can cause you problems
computers need power and data travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all power and data leads make sure they have secure dust free connections
cd/dvd floppy drives need to have current go through make sure these drives are working
check you CPU make sure its securely seated and has thermal grease
hope this helps
Jul 15, 2012 | Computers & Internet
When I turn on my 4 year old HP Compaq dc7600 the monitor never receives a signal. All cables are pluged in and working. Help!!!
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 06, 2011 | HP Compaq dc7600 Convertible Minitower PC...
I just installed the driver software for a Brookstone Photo Scanner (SKU No. 63494) on my HP computer that uses Vista Software. Now nothing on my coputer functions. I can not even get the thing to shut...
Did you try switching the computer of a the plug and start it up again,
or do you have a restore disc for the computer,
when you load your software in for the scanner dont have the scanner pluged in
untill it tells you to...
Nov 24, 2010 | Computers & Internet
My coputer is have chopy display when i watch
Your graphics driver may be corrupted or not properly installed. You need to install that to get proper graphics and also to prevent restarts.
Jun 12, 2010 | Epson Computers & Internet
Saturn coputer problems failing im test
i doubt the car computer is at fault,,,,its probably not ready for testing which means it needs to be riven to pass the tests inside the cars computer,i worked at saturn for 8 years and never had a bad car computer be at fault for failing test,,,either there is a check engine light on or something else,maybe your mechanic is not that good?
Mar 13, 2010 | 2006 Saturn ION
The computer
yes it has everything to do with the running. it is the CDI
Sep 20, 2009 | 2004 Yamaha XT 660 R
Bush tv model number rf2185ntxsil/a stopped working
do you have the tv in an extention lead if so try pluging it into the main socket as you might have over loaded the exteention lead
Jul 21, 2009 | Televison & Video
LCD (IBM) monitor power light is green but no display
Make sure the monitor lead which goes behind the computer is in correctly and has not come loose.
Unscrew it from the PC and put it back in again.
Jan 06, 2009 | IBM ThinkVision L170 17" LCD Monitor
No display
check the power cable, whether pluged well or not remove the monitor cable which is connected to your CPU only pluged the power cable and watch the LED status and let me know
Oct 10, 2007 | Proview PS 720F-1s (Silver, Steel Blue) 17...
Computers & Internet Logo
413 people viewed this question
Top Altusen Computers & Internet Experts
David Payne
David Payne
Are you an Altusen Computer and Internet Expert? Answer questions, earn points and help others
