Question about Refrigerators
How to remove ice dispenser lever on an lg LFX31925ST/00
Ice dispenser sticks open
    Scholar:
    New Friend:
  • 81 Answers
To replace that you have to take that whole assembly out and you need to install a new Solenoid, new dispenser flap, and a new spring for the flap.
Posted on Nov 28, 2013
4 Suggested Answers
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
TheMobilian
  • 8220 Answers
SOURCE: ice dispenser door sticking. has been cleaned but still sticks
See page 38
Posted on Mar 25, 2010
Why does ice dispenser stick?
I dont know what brand you have. But there is a springlever to return the lever to closed posision. Eather the return spring/mechanism is broken. Or has become loose from the fastnerclips holding it in place. I have also seen that ice is the reason for this. Iceing around the very top of the lever.
Feb 17, 2016 | Refrigerators
LG Freezer ice maker makes ice but wont dispense
There is a mechanical flap (trap door) that should open to allow ice that is being pushed by the auger in the bottom of the bin to fall out. Possibly the solenoid that opens the door does not work, or you just have an obstruction (piece of ice) preventing the door from opening far enough to allow the ice to pass through. Here is some helpful information and instructions.
Mar 19, 2014 | LG LSC23924ST Refrigeration : Refrigerator...
Lg freezer ice maker making ice but not dispensing
I have the same problem. I am getting tired of having to clear it out about once a week. I take the ice holder out and empty it in a large bowl and remove any large, melted together pieces, then replace it. It works fine for a while.
Mar 17, 2017 | LG LSC23924ST Refrigeration : Refrigerator...
How Do You Repair An lg lfx31925st error code 1f
IF error code. This typically refers to a problem with the ice maker fan. It is recommended to unplug the unit and allow the ice maker compartment to defrost, thaw, and melt any ice buildup. Dry up the excess moisture before plugging the unit in again. This should resolve the matter. If not, post back to me.
Nov 16, 2012 | LG LFX31925ST Stainless Steel Bottom...
Ice cube dispenser
make sure the ice maker lever is in the down position, when removing the tray the arm was probably moved to the top(off) position as if the tray was actually full which would shut off the ice making process
Aug 30, 2012 | LG LFX25971ST Bottom Freezer French Door...
LG LSC26905 makes ice, but will not dispense through door. Ice backs up on inside of freezer door when attempting to dispense ice (crushed and whole cubes). Water dispenses OK. Any help? Thanks.
Sounds like the flap or door directly above where the cup would be is not opening. Press lever and look up in there, if that is the case there is a problem inside the door.
Sep 17, 2011 | LG LSC26905 Side by Side Refrigerator
LFX25970 Bottom Freezer Refrigerator This morning it began to make a clicking noise coming from the ice/water dispenser and cold air was coming down from the opening. I pushed the lever for ice and it...
You may have an issue with one or more of the following:
* icemaker
* dispenser actuator
* ice chute door assembly
* ice dispenser solenoid (if the solenoid is stuck in an open position, the ice chute door/flap would remain open allowing cold air to escape).
Contact an appliance service company.
Feb 16, 2010 | LG Refrigerators
The lever is stuck on my LG ice dispenser
You'll need to replace the whole ice maker system. Problem exist in the mechanical box connected to the lever which once opened is almost impossible to re-assemble. Cost around $95.00
Aug 06, 2009 | LG LRSC-26922 Side by Side Refrigerator
Ice maker makes ice but can't dispense ice
Please try this. Remove your Removable Ice Bucket Assembly which is where the Auger (corkscrew) is located. You should be able to see the Auger Motor Drive Fork which is located permanently inside the freezer compartment... opposite the end of the Removable Ice Bucket Assembly that you just took out. Close the freezer door and attempt to dispense ice... if you can hear the Auger Motor running as you attempt to dispense ice... then the Auger Motor is OK. Dump out all the ice that is in your Removable Ice Bucket Assembly and wash it out in your kitchen sink with warm water. Reach into your freezer and put your hand on the Auger Motor Drive Fork ... you should be able to rotate it CW or CCW...it is a little hard to turn but it will turn. Position the Auger Motor Fork to a 12:00 and 6:00 o'clock position. Now take your Removable Ice Bucket Assembly and position its Receiver Auger Fork to a 9:00 and 3:00 o'clock ....Re install the Removable Ice Bucket Assembly into the Auger Drive Fork. Close the freezer door and again attempt operate the ice dispenser... you should hear the Auger Motor again run as you press the ice dispenser. Note....at this same time the Ice Chute Door in the Freezer Door should spring open so that ice can fall out. Of course you have no ice in the Auger at this time...but it all this works then future production of ice will fall out. Note...Usually the Auger Motor never fails. but the whole thing can get jammed with ice and not dispense. Also, the the solenoid that operates the Ice Chute Door fails quite frequently. Last but not least... if nothing is happening... it is a control board type problem. Hopes this helps! Handy Henry
Jul 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
310 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
