Question about Hoover V2 U8130-900 WindTunnel Bagless Upright Vacuum
How to remove and replace a handle release lever on a hoover vacuum
  • 19 Answers
SOURCE: How to remove handle from Hoover 5445-900 upright wind tunnel vacuum
Hoover.com doesn't have a manual specific to your model but there is one similar which will show how to remove the upper handle from the body.
http://www.hoover.com/pdfs/manuals/U5467900.pdf
Do you have a replacement switch? If not I believe you can buy one from Hoover (the switch and/or the upper handle assembly). Unfortunately your model isn't listed on the website, is this a new vacuum? I recommend giving them a call, that would be the easiest way.
Also remember when working with electronics to unplug the vacuum. Even when there is no power residual electricity can remain in the wires. If you feel unsure, take it to a repairman.
Hope this helps!
Posted on Dec 22, 2007
SOURCE: Hoover Self Propelled wind tunnel vacuum U6433-900
I need to replace the actuator pivot arm on my Hoover Wind Tunnel to fix the self propel feature. I can see where it needs to go but I can not seem to get the cover off the vacuum so I can get to it. How do I do this?
Posted on Sep 16, 2008
  • 294 Answers
SOURCE: foot latch is broken. need to replace with new
it is accessed from the bottom underneath by the rear wheel. However, If there are and cracks on the pedal release socket area then the base will need replacement. parts are little cost but the unit needs to be completely disassembled.
Posted on Oct 18, 2009
  • 190 Answers
SOURCE: How do you replace Hoover Handle Release Pedal on
The handle pedal is snapped in to the base, where it pivots.
The pedal needs to be pried away fron the base, exposing the pivot pin to release it for removal. On your model, you will likelly have to remove the lower handle from the base (where it pivots) to get room to release and replace the pedal.
Posted on Mar 12, 2010
  • 377 Answers
SOURCE: Need to replace the handle-release
The exploded views at this URL will help you identify the part and you will be able to order it as well.
http://www.ereplacementparts.com/hoover-u8125960-savy-bagged-and-bagless-vacuum-parts-c-37315_37337_37538.html
Posted on Oct 13, 2010
How release locked handle on Hoover U6476-910 vacuum?
heck for a release button or lever at the base.
Nov 28, 2015 | Hoover Vacuums
Handle release lever placement.
Best you go on line to Hoover and input the Model into their system. The support area has downloads whereby you can get the Manual free and fix the problem yourself in minutes.
Dec 18, 2013 | Hoover Vacuums
How to remove the hoover windtunnel handle release lever
Tilt the handle back and pry it out with a flat blade screwdriver.
Jan 23, 2013 | Hoover U6630-900 WindTunnel Bagless...
How do you replace the handle release lever on the hoover windtunnel 6425-900
The release lever is held in place by tabs molded into the base. You just need use a screwdriver or two to press the plastic tabs back and then push the release lever out. The new release lever can be just pushed into place and the plastic tabs will snap and hold it in place.
Nov 15, 2010 | Vacuums
Need to replace the handle-release lever on a Hoover model U8125-960 Vacuum cleaner
Oct 13, 2010 | Hoover Vacuums
Remove & replace handle release lever on hoover model U6445, s/n 039900015686
From under the vacuum, there is a tab release that you need to pry out the old part. At this point, based on your serial nuimber, your vac is over 10 years old and may also need the base. The bracket is part of the base and not expensive, but the replacement is involved. Once the vac is disassembled, other things may need to be replaced.
Apr 19, 2010 | Vacuums
Mar 11, 2010 | Hoover Vacuums
Stand up lever is plastic, broke when stepped on to release handle, can it be repaired, replaced with a better one, plastic breaks too easily?
The pedal release can be replaced but the base will need to be checked for cracks as well. if the base is broken most common is the socket the pedal release snaps into. some of the plastic parts have been made with better materials
Oct 20, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Foot latch is broken. need to replace with new one. how does one access to remove the foot pedal latch. By foot latch, I mean the foot lever that releases the upright to lower the handle and begin...
Oct 17, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
Hoover V2 U8130-900 WindTunnel Bagless Upright Vacuum Logo
119 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
