Question about Trendnet Tup1284 Parallel Adapter Usb Parallel
Printer adapter trendnet tup1284 how to install\\
Wireless adapter problem
GO http://www.trendnet.com/downloads/list_subcategory.asp?SUBTYPE_ID=1310
Dec 30, 2011 | Trendnet TEW-664UB IEEE 802.11a/b/g IEEE...
I need driver for windows 7 to tbw-160ub, because i cannot install.
You can download the driver as well as the user guide and installation guide here
Mar 22, 2011 | Trendnet TBW106UB MicroBluetooth USB...
Button of WIFI is not working and on bottom right donot showing wifi option.
1. you may need to upgrade to new standard.
2. check with the Acer site for wirelss card updates if no updates I suggest you get the Trendnet wireless adapter ( it is a usb wireless G adapter that is compatible with today's wireless connections.
3. Your wireless card support 802.11b which is obsolete and will not connect.
Here is the site for the Trendnet products.
They can be purchase at the local computer stores for a small price and they work pretty good and have wide scan rate. up to 300 ft.
http://www.trendnet.com/products/
Mar 16, 2011 | Acer InviLink 802.11b (91.49C10.002)...
I have a dual band netgear router N 300 series. i have just purchased the trendnet adapter and opened it from the box. i followed all the steps for setup to to "t". The adapter is able to connect...
yes, the g based adapter is only compatible with G networks not N. You can fix your problem by logging into your router and changing the advanced setup options so they accept the G Based adapter.
Jan 08, 2011 | Trendnet TEW649UB Mini Wireless N Speed...
T3616 with XP pro can't recognize Trendnet TEW-424UB wifi adapter
Go to Emachines - - the intel 10/100 is what you need - try downloading speccy - - this tells you what you have to a point you can go to the website.
Try also - going to the intel.com website and downloading their utility so it can find out what you need from intel.
Apr 12, 2010 | E-Machines eMachines Desktop PC
Attempting to connect with trendnet TE100-p11 print server doesn't work. Trendnet infers it is not compatible with CAPT (Canon Advanced Printing Technology) type printer
Make sure the Print Server has the same IP address as your network. The run the PS-Wizard which is available on the disk. This PS-Wizard will install the printer driver as a network printer. This will let you print without any issues
Feb 08, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
I NEED A DRIVER FOR WLAN ADAPTER
Have a look here:
select your model from the dropdown menu an viola.
Nov 12, 2009 | Trendware (TEW-424UB) 802.11g/b Wireless...
Wireless network adapter(code 10) and pci modem (code 28)
install proper driver then set ip adress .
enable wireless adapter.
Oct 07, 2008 | Trendware TRENDnet TEW-421PC 54Mbps PCMCIA...
Trendnet Tup1284 Parallel Adapter Usb Parallel Logo
70 people viewed this question
Top Trendnet Computers & Internet Experts
youbrokeit
Level 1 Expert
Are you a Trendnet Computer and Internet Expert? Answer questions, earn points and help others
