Question about iHome Ih-ip2101
User manual Some buttons stick an two show up like press m an km shows up an some buttons on left side don't work
I bought an Orbo or3198 for my granddaughter from a friend it did not come with a user's manual. How do I go about getting one?
A couple links below to check out, second link is the manufacturer website, where you can get support and manual.
Took a long time to find this, show your appreciation by pressing the helpful button and follow me on fixya for more tips and info.
Orbo Jr 4GB Android 4 1 Five Point Multi Touch Tablet PC Kids Edition...
Search results for Orbo jr Manual
Feb 14, 2016 | Tablets & eReaders
My SM-T550 is completely frozen.
Soft Reset
If the device is frozen or unresponsive, try pressing and holding the “Power” button for about 20 seconds. This should force the Galaxy Tab 10.1 to restart normally.
Hard Reset
A hard reset will set the device back to factory default settings and erase all data on the device. This is normally done when troubleshooting methods prove to be fruitless.
Option 1
1.With the device powered off, press and hold the “Home” and “Volume Up” buttons while powering on the device using the “Power” button.
2.The Recovery Screen will appear. Use the volume buttons to toggle the highlighted selection to “wipe data/factory reset“. Press “Power” to select it.
3.Highlight “Yes — delete all user data“, then select “Power” to choose the selection.
4.Once the reset completes, you will be prompted to “reboot system now”. Choose this selection to restart the device.
The hard reset is complete.
Galaxy Tab How to Hard and Soft Reset
Jan 02, 2016 | Samsung Galaxy Tab Tablet PC
How do Im hard reset a Allwinners a31s tablet?
Try this one...
1. Turn off your Tablet
2. Press Power Button and the Volume UpButton at the same time until the Tablet show the Start-up Logo. then if you see the logo release the button.
3. wait until you see that your tablet is in Android System Recovery Mode.
4. use VOLUME DOWN BUTTON to go to the WIPE DATA/FACTORY RESET OPTION then Press POWER BUTTON to select.
5. then use VOLUME DOWN to choose YES--delete all user data then press POWER BUTTON
Mar 02, 2015 | Tablets & eReaders
Hkc model p886a will not upload the upgrade to tablet ... tried going online and using stick but doesn't show my model? any suggestions
Click "Settings" in the main menu interface and click "About tablet", click the 'System updates' tab. It is in the user's manual which you can find at:
http://www.hkcdigital.com/pdf/manuals/P886A.pdf
Jan 04, 2015 | Tablets & eReaders
Need English Manual for SANEI N78 7 inch Android 4.1 RockChip Dual-core RK3066
If you haven't resolved the language issue yet, try this:
1. power up the tablet by pressing the power button on the left side of the top edge of the tablet
2. slide the lock to bring up the home screen
3. across the top of the screen you'll see a magnifying glass (top left), a microphone, a folder with three dots on it (center) and dark area on the top right corner with six blue squares in it. Press the squares. Now you'll see your apps.
4. swipe your finger across the screen from right to left to show the next screen of apps. Look for the Settings app. It's grey with a light grey gear/sprocket in the center. Press that and you'll go into the Settings screen.
5. Down the left side you'll see a menu of options. Look for the Language and Input option. It is the one that looks like a solid light coloured square with the letter A in the center of it. Press that.
6. when that's hightlighted on the left side of the screen, you'll see the language option at the very top of the right side of the screen. There's no icon beside it, but it's the very top option. Press that.
7. the twelfth option in the list that comes up on the right side is "English (Canada)". Count down to the twelfth option and press it. The language of your table will be English. Go back and change it to something else if you don't want that particular English option.
Hope this helps. I found this youtube video that might help, too.
http://www.youtube.com/watch?v=e_rK6WRT3Ps
Skip ahead to 2:38. That's where he turns it on and then he changes the language (he could be changing it to Spanish, but you'll get the idea).
Mike
Apr 01, 2013 | Sanei Freescale IMX6Q Tablet PC
Forgot my passcode symbol on my tablet an need to reset it please
This works with devices having physical home button
1.
Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory. With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
Note: I Use My Tablet SUNBERRY, and reset my Tablet
Turn Off your Tablet and then
Press Power + Volume Down (Press up Factory menu Show)
If you use Android 2.2 (Froyo)
Press Wipe data / Factory Reset -> Yes, Delete ALL user data -> if Finish press Reboot Now
If you want more other andoroid OS and other tablet visit my Blog
you can see how to Reset android with video
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Feb 14, 2013 | Archos 101 Internet Tablet 16GB 10.1"...
Looking for user guide
Go to acer.com click on support then download. You next need to select your device to go to its support page. Tablet, then Iconia Tab then W500P then click on image of your tablet. Under DOCUMENT scroll down to find the user manual. You have to scroll down or it doesn't show on the listing. Click on the orange download button at the left of the line listing and the zipped user manual ile will start to download. Your browser will either ask where to save this to or will put it where you have specified under browser options. I you save it to a place you can recall or to your desktop then you can extract the files usually just by clicking on them. Inside will be a pdf file which is your user manual which you will need something like Acrobat reader (free from Adobe) to use to read this file. If the second part of this works that will be the direct link to the user file and you might be able to download it using that.
http://global-download.acer.com/GDFiles/Document/User%20Manual/User%20Manual_Acer_1.0_A_A.zip?acerid=634378292522483553&Step1=Tablet&Step2=ICONIA%20TAB&Step3=W500P&OS=722&LC=en&BC=Acer&SC=PA_6
Jan 18, 2012 | Acer ICONIA Tab W500PC52G03iss
I just bought a samsung galaxy tablet and i do not know how to set up the web cam on it. I also have skype installed on my tablet and for some reason i am not seeing a video call button when i click on my...
Hi! First of all in user's guide manual says that this tablet works just fine with only 3 IM : 1.Google Talk; 2. Windows Live Messanger 3. Yahoo! Messanger. Try one of those to see if the camera button appears.
However, if you need more information you can find them here: ( http://www.userguidemanual.com/samsung-galaxy-tab-gt-p1000-tablet-manual-user-guide-french-english/ ). *This link allouds you to read and download free user's guide manual (in PDF format).
I hope this will work! Have a nice day!
Sep 02, 2011 | Samsung Galaxy Tab Tablet PC
I want to change owners so I want to reset Kyros 8024. How do I do that?
Following the instructions below will cause losing all user data, including the third party installed applications.
This action will even delete the "Getting started" video file, which will cause the "Cannot find video" error when a user is trying to play the video clip using the "Getting started" application. With knowing this fact, the user can follow the instructions below.
  • Turn off the unit.
  • Take a microSD card out of the slot. (Empty the microSD card slot.)
  • Press and hold down the power button for a few seconds while pressing and holding down the "Home" (Silver Push Button) button. (Both "Power" and "Home" buttons must be pressed down until he see the phrase "upgrade system activated" in the middle of the screen.
  • Release both buttons once the phrase "upgrade system activated" appears on the screen.
  • Wait until it reboots. You will see the following sentences on the left top corner of the screen: Can not find any update image. Press MENU/KEY_VOLUMEUP key to init SD card, Press BACK/KEY_VOLUMEDOWN key to cancel.
  • Press the "VOLUME UP" key. The volume up key is located at the left side of the unit and the button is closer to the built-in camera than the volume down button.
  • Wait until it finishes making a partition and shut down the system automatically.
  • Once the unit is turned off, your system will be reset to the factory settings. Thus, your previous data are lost at this point.
Jul 20, 2011 | Coby Kyros 716829701508 Tablet PC
In my email addressfor access to appslib has an underscore, and my Kryos does not show one on the tablet screen, any idea how to overcome this.
Press the ?123 button on the bottom left hand side of the keyboard. Then press the ALT key. This will bring you to the second screen of symbols. The underscore ( _ ) key is in the middle of the keyboard. Hope this helps :)
May 09, 2011 | Coby Kyros 716829701508 Tablet PC
iHome Ih-ip2101 Logo
Top iHome Tablets & eReaders Experts
Brett Duxbury
Brett Duxbury
john cordey
john cordey
Are you an iHome Tablet and eReader Expert? Answer questions, earn points and help others
