Question about Uniden GMR1038-2 (7 Channels) 2-Way Radio
Uniden gmr325-2 stuck in rx mode - Uniden GMR1038-2 (7 Channels) 2-Way Radio
2 Suggested Answers
SOURCE: Uniden uh064sx-2 2-Way RX Stuck On
Didyou have any luck resolving this issue? We currently have exactly the same problem
Posted on Apr 15, 2010
How do i turn off the RX option in my uniden UH064sx- 2a
Do you have a earth on your signal pole for to combat this problem
May 29, 2015 | Uniden Radio Communications
Uniden gmr2638_2ck is always stuck on receive. Rd is always showing and static coming from the speaker
Adjust your SQUELCH control or setting so that the noise disappears. The RX indicator will go out.
Mar 01, 2015 | Uniden Radio Communications
My uniden UH3O5sx is always stuck on receive (rx is always showing) can receive but not transmit
Set up your privacy tones or adjust the squelch level to stop the static and bring the handy out of receive mode. Some models have a busy channel lock out, that if it beleives it hears something it will not let you transmit over the other station.
Oct 04, 2014 | Uniden Radio Communications
Why does the uniden grant go into transmit mode when turned on
if this happens without a mic attached, it is common for the tx/rx switching transistor to fail
Aug 16, 2014 | Radio Communications
How to get rx off screen
This model has a "Monitor Mode" feature that allows you to listen for weak signals on the current channel at the press of a key.
1.) To turn ON monitor mode:
Press and hold the volume/monitor up or down key. The rx icon will blink.
2.) To turn OFF monitor mode:
Press the volume/monitor up or down key. The rx icon will stop blinking.
Jul 15, 2014 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Stuck on rx mode
Rx is an abbreviation for receive. (Tx is transmit) There are a variety of reasons a radio will be "stuck" in Rx:
1) Another radio in the group is stuck in transmit and you cannot reply if your radio is receiving the other radios transmission.
2) Your radio is programmed for Rx only.
3) Your radio has a Tx problem such as a bad mic, or something covering the mic opening.
4) Your battery is low or bad. It takes more energy to Tx than to Rx.
Best regards.
Feb 07, 2014 | Cobra LI3900-2DXVP (14 Channels) 2-Way...
3040 ck
It's a Uniden model 3040 CK, is this correct, if so then the problem is due to someone or something causing a carrier frequency to be received by your unit, causing the Rx to stay open, the fact you can Tx and Rx the other station you're communicating with, indicates that the radio is working as it should, the problem is caused by external interference and not in your radio.
I hope this has answered your query.
Regards,
Peter
Nov 10, 2012 | Uniden Radio Communications
I HAVE UNIDEN TWO WAYS HOW DO WE TAKE THE RX OFF
  • You need to get your radio out of monitor mode. To do this just pres the "mon" button for two seconds. Monitor allows you to just listen on that frequency and also receives weaker than normal transmissions while in "monitor" mode as well.
Regards, Tony
May 09, 2011 | Uniden GMR-1088 2-way Radio Walkie Talkie...
Cx80 stuck in rx mode , power cycled, swapped batteries, changed channels, will only swtich to tx when ptt button pressed, otherwise always in rx mode, other radio from package works fine
But thats how a walkie talkie works, it stays in Receive Rx mode UNTIL you press the PTT button,, then it Transmits Tx, and when released it goes back to Rx, receive?
Feb 18, 2010 | Radio Communications
Aug 05, 2009 | Uniden GMR1038-2 (7 Channels) 2-Way Radio
Uniden GMR1038-2 (7 Channels) 2-Way Radio Logo
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
