Question about Logitech Premium Headset
Loose Wire I want to open the Premium Headset. Can you give me the steps on how to do it? I'm kinda afraid to do it without knowing the proper steps because I might wreck it
I have the same problem. If you have the receipt, and the headset was purchased less than 2 years ago, you can fax receipt to Logitech, and they will send you a new headset. I just did it. Logitech customer support is 646-454-3200. They are NOT making me return the bad headset.
Posted on Jan 28, 2008
Just open it again u will be all set
Posted on Dec 25, 2007
Brand New AKG GHS1, only getting sound out of 1 ear
If warranty is there, get it exchanged. If replacement is not available try testing using a multimeter for continuity of left driver. If not getting continuity, open the headphones and see if wire is contacting properly. After opening, you can again test continuity of driver and wire separately and determine exact problem. If wire is wrong, you can purchase a cheap headset and take wire from it and replace your headphone's wires. If driver is spoiled, not easy to find spare.
If you use computer for browsing, this may be helpful for you.
https://youtu.be/9C3SRvhUMwY
Sep 27, 2017 | AKG GHS1 Headset
The rubber casing of the wire in my headphones has came off slightly. How can I fix this? The headphones still work fine, however, im afraid that, with only partial cover, the headphones will overheat. I...
Since it's somewhere between the ends of the wire, you can use a heat shrink. Here's a video explaining how to use it:
http://www.youtube.com/watch?v=d-j98tkAbh8
Mar 18, 2011 | Microsoft LifeChatâ„¢ LX-3000 Headset
My left cup has stopped working in my sennheiser pc 350 headset and I would like to know how to get it working again.
when one of the cups stop working it is a loose wire and you have to identify the wire cut and restore the connectivity ..Usually the cut is near the entry in the headset ..or in side on the mini-speaker ..
You will have to open them up and see where the wire is interrupted
Dec 31, 2010 | Sennheiser Pc 350 Headset Premium Gaming...
Odd buzzing/vibrating tone
Could be feed back loop, try trying a loose knot in the wire.... Might be a battery problem.... also try to seek the unit again.....
Feb 14, 2010 | Jabra BT350 Bluetooth Headset Headset
USB Device Not Recognized...
Your headset is faulty. Open it to check for loose wires.
May 28, 2009 | Logitech ClearChat Pro USB Headset
My left side of this headset is not working
those wires are very fradgile and chaces are they have snapped inside the jacket
it happens mostly when you pull on the wire instead of the jack or the wire gets caught or stretched --is your jack fully inside the connecter? wiggle the wire and if it sound than it is the wire
Apr 22, 2009 | Logitech Premium (980445) Headset
How to pair the jabra BT125 headset with personal computer to here songs without using head phones
hi vrajasekar20, thank you for using fixya.
to pair your jabra to a PC for headset use, you have to install the jabra PC Suite first and use it as your default sound input / output device.
The PDF file below will give you a step by step instruction on how to have it installed and working.
http://www.jabra.com/sites/Jabra/GNimages/Products/Adapter/A330/A330_FAQ_EM_EN_2838.pdf
Should you need more info on this matter,please do not hesitate to let us know.
regards,
voodoo
Apr 17, 2009 | Jabra BT125 Headset
Broken wires on headset
after exposing the enameled wires...light a match and burn the enamel off the wires,.careful not to over burn. ...twist the two ends together or (solder) and viola!
Jun 29, 2008 | Compaq PC Microphone (Black or Beige)...
Problem with headset
if you can't get it to work, I've found that the wiring inside the headset is very weak and loose. open it up with some screws, and solder it back on. I tried this, I know it will work, as it fixed mine, but the wire is so thin, I couldn't strip it and thus couldn't get it to stay on properly. Make sure you have a steady hand!
Nov 09, 2007 | Microsoft Xbox 360 Console
Logitech Premium Headset Logo
313 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
