Question about Garden
Mahindra 3016 hst. noise from trans. slows under load,how is there warenty
4 Suggested Answers
  • 29 Answers
SOURCE: trans range switch
Most dealers will only cover this under 3 year, 36,000 mile warranty. You might get a courtesy replacement if you are just over that, but don't count on it. I checked when mine went bad, the dealer quoted me "about $300 to get it fixed". After extensive research, I find that this is a very common problem with Suzuki's. Cheaper and easy fix is to go to oemsuzukiparts.com, in the mechanical section type in transmission range selector or neutral safety switch (not sure which one I used), and it will come up---$34 part held in place with two bolts!!!! I ended up unhooking the upper radiator hose from the radiator to give me more room, but it was so worth it. It only took me less than half an hour to replace. Just make sure you line up the teeth on the internal gears of the switch, and the tranny is in park. No problems, and more than $200 kept in my pocket
Posted on Jan 28, 2010
emissionwiz
  • 78272 Answers
SOURCE: polaris ev drive train noise under load and low battery. grinding noise surges in power and drive tran grinding noise
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems.
Posted on Sep 18, 2012
Tractor will not start,this machine is a new 1538 hst mahindra with 40 hours,??
still under warranty
get the service people out to fix it under warranty
Nov 25, 2017 | Garden
Scanner read code p1792 in mahindra maximo
Definition of check engine code P1792:
Acura:
TRANS EEPROM Checksum Error
Chrysler/Dodge/Jeep:
Battery power was disconnected since last power down
Citroen/Peugeot:
Barometer Pressure Circuit Malfunction
Ford:
GM:
Transmission Control Module Reprogrammable Memory
Honda:
Problem in Engine Coolant Temperature (ECT) Sensor Circuit
Isuzu:
Trans EEPROM Checksum Error
Jaguar:
Ignition Supply Malfunction
Kia:
Mercedes:
Opel:
CAN data bus,ECMITCM communication - malfunction detected
Volkswagen/Audi:
Transmission Range Display Circ. Short to B +
Volvo:
Sep 07, 2017 | Mahindra Cars & Trucks
Do you have a parts manual for a Mahindra 3510 HST 4 x 4 tractor
Good answer Posted by
Clyde Ottaway Aug 25, 2017
get on the computer punch in Mahindra 3510 HST 4x4 tractor parts manual and a web page will come up that will supply the parts manual.
The link is below
parts manual Mahindra 3510 HST Google Search
Aug 25, 2017 | Garden
Where do I check the hydraulic fluid on a mahindra 3016 hst
I'm not terribly too sure about the Mahindra, but I have recently had to check my hydraulic fluid and I consulted with the manual. Do you have a manual for your vehicle? If you don't, then I would get a repair kit which should have some instructions that could help you out with your situation. https://www.hydrapakseals.com/storefrontCommerce/hydraulicRepair.do
Feb 24, 2015 | Mahindra Cars & Trucks
1997 ford expediton two problems 1. is when coasting to a stop or just rolling slow a clicking noise coming from rearend area I first thought u-joint but checked that then wheel bearing checked that it...
If you use the Emergency brake more when you park a trailer, then both the clicking and the wheel bearing noise is due to the Emergency brake. The linings in the E brake are drum type and are inside the rear rotor. They will accumulate rust and make noise.
The rear pinion bearing in the differential can make a noise under load. This noise will go away if you are coasting in DRIVE, or put trans into NEUTRAL while moving. Pulling a load puts more strain on the bearing.
The heater problem can be several things. Usually an electric or vacuum "door" under the dash. A low water level after warmup. Or a bad thermostat will stick to begin with and then open too much causing a temperature drop. After the truck is warmed up, feel the heater hoses and see if they are both hot. If they are both hot, then its a "door" problem under the dash.
Mar 24, 2010 | Ford Expedition Cars & Trucks
When I press on the gas pedal it make a winding noise and it slows down
One reason can be a slipping serpetine belt. This would make a noise and the electrical power will drop and the vehicle will cutout.
The second reason would be a transmission problem. The parts inside the trans are slipping when you put a bigger load on them. Check your trans fluid first and smell the trans dipstick to see if it smells burnt. Then check the trans fluid level.
Jan 11, 2010 | 2000 Ford Expedition
1997 ODYSSEY AUTO TRANS SHIFTS HARD BETWEEN 1st & 2nd, 2nd & 3rd
It has nothing to do with the transmission, it's your engine mount thats bad.
Jul 27, 2009 | 1997 Honda Odyssey
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
