Pioneer CDX-FM1289 12-Disc CD Changer Logo
Posted on Oct 11, 2007
CD changer problem
When the audio discs are loaded,it refuses to play .It will display error-11.Do u know wat's the problem?.Sometimes,it plays while sometime it refuses to play and displays error-11.
                   Nick
  • Anonymous Mar 22, 2008
    Disc plays for a short time . stops. error 11 displayed. Power off play other discs; same thing happens.
George Nalley
Level 1:
  • Contributor 44 Answers
  • Posted on Feb 05, 2008
George Nalley
Contributor
Level 1:
Answers
44
Questions
Helped
20858
Points
76
According to the manual, error 11 means the disc is inserted upside down.
Hi,I have had this Pioneer CDX FM67 mounted on my bike for 5 yrs and it always played good and showed no problems.This year every time I load some cds in the player nothing happens and then I get an error...
It relates to the failure of the loading section. So check on the linking wires/flexible strip to the load motor- this is a ccommon fault and is seen most of the time.
Secondly the tray with CD can get strck due to a faulty disc- being warped. if so manually retrieve and reset.
finally there is a tiny hole near to the eject which can reset the changer if this has hung up or is jammed.
Open the covers and probe.
4helpful
Hyundai CD player displays ''error'' for all functions
my cd player in my sonata keep eject the cd can anybody help
SOS
4helpful
2answers
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Kenwood RXD25 CD player intermitent??
Hi jenoss
Sounds like the unit has either a failing load belt to the cd drawer mechanism,not allowing the transport to fully load the cd. Give the unit a gentle tap just after the drawer closes and see if it resolves the problem.
OR a faulty spindle motor, you will have to take the lid off and after pressing play, give the disc a gentle "kickstart". If it then begins to run, then the motor is the problem.
If you find it is neither of these, get back to me here and I we shall go further
regards
Graeme
Keeps displaying error cdc
you can try to use a cd lens cleaner CD. Put the lens cleaner in slot 1 and load disk 1 the cleaner shouls be dropped in place and begin to clean the cdrom lens.
Cd player wont play
The error code is a mechanical error fault, possibly something in the mechanics that load the CD onto the spindle motor. The only sure way to know what the problem is, is to open the unit and let it load a disc and see what happens. The problem may also be due to a very dirty laser lens, with a dirty lens the laser won't be able to read the TOC (table of contents) and all the CD's will cycle through the changer and a error code will be set. Best of Luck.
Pioneer KEH-P6600 diplays "error-11"
use your user guide to read the problem related to error 11 .. most probably your wire connecting your changer witht he head uint is either cut or not functionall ... hope that answers the question
Changer refuses to eject or play CDs, keeps saying reset
Hello, in order to repair CD changer you have to be equiped with special tools and knowledge. This repair is only possibble in Authorized Sony Service or at the shop with best references for this kind of job. Best regards, Arpi
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
