Question about Windex Multi Task with Vinegar, 32 oz. Bottle
Suggest me the most common green cleaning products commonly found in every house. Are enough to do tough jobs?
    New Friend:
Vinegar, Baking soda, Coke can be easily found in every house. And vinegar is strong in nature and can clean almost everything.
Cheers!
http://www.thoroughclean.ca/
Posted on Nov 27, 2013
How do I connect an old 3-way toggle switch to my new 3-way dimmer?
Cookrobert- you have to determine wich wire is the common wire in the box (house). Look in the box and see wich two wires ore in the same sleave. (These will be your travelers, (more than likely a black and a red) the wire that is in its own sleave (black)with a white tied to other whites is the common. Now the dimmer will tell you wich wire is commom. Tie the tow commons together. The green wire is ground if your house does not have ground , cap it and forget the green, if your house does have a ground (bare copper wire) then connect the green to the bare wires is the house box. Now your to travelers on the house side will tie to the two travelers on the dimmer side. Once you have found the traveller's on the house side and dimmer travelers they can be flip flopped. It dosnt matter. Just as long as they are the traveller's it will work. It sounds complicated but I'm sure you got this. I'm a 30 year electrician. (master).. I'll be looking for your update my friend. Good luck
Jan 21, 2015 | Electrical Supplies
Heater core
Remove the dash, remove all fasteners and seperate the heater core housing, remove the core. Install in reverse order. Its a tough job for a novice, i suggest let a shop do it.
Dec 06, 2013 | 1993 Pontiac Bonneville
Recomended cleaning for kitchen porcelain sink
Scouring powders or cleansers contain abrasives commonly used to clean and remove stubborn stains that are slow to respond to chemical action alone.
However, use of an abrasive cleaner may scratch and damage smooth finishes such as porcelain, fiberglass or enamel making it even more difficult to clean the surface in the future.
New kitchen and bathroom fixtures do not require a scouring cleanser to clean them of soap films and body oils. Dissolving soil by soaking with the correct non-abrasive cleaner (especially a foaming type that sticks to the surface) then wiping and rinsing usually does the job.
When cleaning older, abused fixtures, choose the mildest abrasive cleaner available such as a Soft Scrub -type product or baking soda, and apply just enough that, with light pressure, the embedded soils are loosened and may be rinsed away.
Aug 21, 2010 | International Thermocast Corp Thermocast...
Scanner bulb warming up
Common problem with this model. You most likely need to take the scanned apart and clean the mirrors. Tough job for a novice. Average cost for a good tech to do this is $ 60.00.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 05, 2009 | HP LaserJet 3330 All-In-One Printer
High mileage 1996 Ford Explorer v8 overheats at 75-80 mph
if your mechanic seen no leaks from hoses or thermostat housing its sounds that either your fan clutch or your thermostat is bad. if its heats will driving streets and not highway its your fan clutch and needs to be replaced. if it overheats in streets and highway its your thermostat and needs to be replaced,you will need a thermostat and gasket with some silicone. Drain, follow the radiator hose to the housing and take 3 bolt off, clean housing well,CAREFULLY install the t-stat exactly the way is was taken out (pic), gasket,sillicone, bolt. ecc3d0c.jpg   its an easy job. Good luck!
Apr 27, 2009 | 1996 Ford Explorer
Diesel engine
Yep coded. someone with a ford diagnostic machine or equivlent should ne able to do it though, not a tough job if you know what your doing.
Good luck Davelee
Dec 31, 2008 | 2004 Ford Focus
OVAL SPOT IN PICTURE
LCD 101, your blue device is dying in the projector. Very common problem. The blue device cant handle the heat and allowing the other colors to come thru. I suggest replacing with a dlp brand product.
Jun 22, 2008 | Sanyo PLV-Z4 Multimedia Projectors
No picture when Turning on
your trouble syntom is very common.. the problem of your tv is due to lost contact soldered part...if your inclined with this job i suggest you to reheat the board....this will take time but this is the best solution gud luck!!
Mar 10, 2007 | Protron PLTV-32 Television
Windex Multi Task with Vinegar, 32 oz. Bottle Logo
54 people viewed this question
Top Windex Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Windex Office Equipment and Supply Expert? Answer questions, earn points and help others
