Question about Master Equipment Z-Lift Electric Dog Grooming Table in Ivory Size: 24" W x 42" D
I have a 24 x 36 in. master equipment z lift groom table. The lift no longer operates. It has pedals on both sides of the table, one side quit about a year ago, now the other side has stopped workin
The electric outlet is working, the power cord appears to be in working order, all cords seem to be properly attached. There have been no accidents or issues, it just stopped working. I would like to fix the problem, not have to replace the entire table just because it needs a motor or circuit board replaced.
How to replace the brake light switch on a 1997 grand marquis
REMOVAL
  1. Disconnect the wire harness at the connector from the stoplight switch.
NOTE: Locking tab on connector must be lifted before connector can be removed.
  1. Remove the hairpin retainer and slide the stoplight switch, the push rod and the nylon washers and bushing away from the brake pedal. Remove the stoplight switch by sliding the stoplight switch up/down as required to remove.
NOTE: Since the stoplight switch side plate nearest the brake pedal is slotted, it is not necessary to remove the brake master cylinder push rod and one spacer washer from the brake pedal pin.
INSTALLATION
  1. Position stoplight switch so that the U-shaped side is nearest the brake pedal and directly over or under the pin. Then slide stoplight switch down or up trapping the master cylinder push rod and black bushing between the stoplight switch side plates. Push stoplight switch and push rod assembly firmly toward brake pedal arm. Assemble outside white plastic washer to pin and install hairpin retainer to trap whole assembly.
CAUTION: Do not substitute other types of pin retainers. Replace only with a production hairpin retainer. Component damage may occur.
  1. Assemble the wire harness connector to the stoplight switch.
NOTE: Stoplight switch wire harness must have sufficient length to travel with stoplight switch during full stroke of brake pedal. If wire length is insufficient, reroute harness or service as required.
  1. Check stoplight switch for proper operation.
Dec 18, 2015 | 1997 Mercury Grand Marquis
Tip
Drive Hub, Spring Pulley & Chain Replacement for Steppers
Video about the Drive Hub Replacement Procedure for Stairmaster Steppers
  • This videocovers replacing the spring pulley, the step chain and the drive hub assembly on the Stairmaster steppers
  • Tools needed:
    • Snap Ring Pliers
    • Tip Kit for Snap Ring Pliers
    • Socket Wrench
    • 7/16" Socket
    • 7/16" Wrench
    • Needle Nose or Standard Pliers
    • Safety Goggles
  • Begin by disconnecting the spring
  • Do this by pulling up on the spring and unhooking the spring from the frame post
  • Next, using the snap ring pliers and proper tips, remove the snap ring from the spring pulley shaft
    **Important: Be sure to wear safety goggles when working with snap rings**
  • Remove and inspect the spring pulley for any flat spots replacing the pulley if necessary
    • Flat spots develop over time and can result in roughness in the pedals
  • On the side that the pulley was just removed, slowly press the pedal down
  • Remove the step chain retainer brackets (if equipped) using the 7/16" wrench, 7/16" socket and socket wrench
  • Once the retainer bracket is removed, the spring can be lifted up over the drive sprocket and disconnected from the chain
    • The spring is opened at one end to allow for maneuvering over the link
  • Using the standard or needle nose pliers, remove the master link attaching the step chain to the pedal arm
    • Place one jaw of the pliers against the open end of the clip (if installed correctly, the open end of the clip is opposite the direction of chain travel) and the other jaw of the pliers against the far side of the nearest rivet coming through the keeper link; and squeeze pliers together
    • This should pop the clip free allowing you to remove it from the master link
    • Next remove the link bar
    • Finally remove the master link disconnecting the chain from the pedal arm
  • Inspect the new step chain making sure all the chain links flex
    • Manufacturer recommends lubricating the step chain with 30W motor oil using a clean rag to remove any excess
  • Attach the new step chain to the pedal arm reversing the steps taken to disconnect the chain
  • Relieve tension on the opposite spring by lifting up on the spring and unhooking it from the frame post
  • Slowly press the pedal down
  • Feed the spring around the pulley and lift the chain up over the sprocket to move it out of the way
  • Disconnect the remaining two bolts from the drive hub assembly
  • Lift the drive chain over the sprocket and pull the drive hub from the frame
    • As the drive hub assembly starts to develop problems, you may feel clicking, hear some grinding sounds, or a pedal may stick in one position (which usually happens on one side); All of which are indicators of a worn drive hub assembly
    • The drive hub can be replaced as a complete unit
      • The drive hub consists of (3) sprockets
        • Two one way clutch sprockets that drive in one direction and slip in the opposite direction which are for the step chains
        • A larger sprocket that spins either direction and is for the drive chain
    • An inspection of the drive hub can help determine need for replacement
          • If either of the one way clutch sprockets slip in both directions, they need replaced
          • If there is a catch in any of the sprockets in any position, then it likely needs replaced
  • Reinstall the drive hub the same way it was removed
  • Slip the drive chain over the drive sprocket before mounting the hub assembly to the frame
    • The drive hub assembly on the SC916 stepper only has 4 bolt positions. The drive hub assembly on the 4400 and 4600 steppers has bolt holes all around the hub allowing the hub to be rotated for chain tension adjustment. The SC916 stepper has a preset tension and the adjustment is no longer necessary
  • Once the drive hub is bolted to the frame, reinstall the step chains on each side
  • Place the free end of the step chain (opposite the pedal arm connection) up over the step chain sprocket
  • Lift up on the pedal and pull down on the step chain
  • Place a hand on the sprocket keeping the step chain from feeding back and allowing the pedal to drop
  • Grab the spring with your opposite hand and join the spring to the step chain
  • Once the spring is attached to the chain, press the pedal down again
  • Reinstall the spring pulley and the snap ring onto the pulley shaft
  • Lift up on the pedal and pull the spring to route through the pulley, hooking the spring onto its frame post
  • Repeat these steps to attach the step chain and spring on the opposite side
  • Reinstall the step chain brackets (if equipped) making sure all bolts face the same direction
  • This concludes the video demonstration of replacing the drive hub, spring pulley and chains on the Stairmaster steppers
Spring Pulley Chain Drive Hub Replacement Video for Stairmaster Stepper...
on Feb 25, 2015 | Stairmaster Exercise & Fitness
Why won't blades stay aligned?
Ok either the 2 screws that hold the blade to the clipper are loose or the adjusting lever on the side could be loose please check both.
P.S you must align blade before you tighten the screws.
www.angliaclipperservices.com
Anglia Clipper Services professional dog grooming equipment
Aug 25, 2015 | Wahl Whal Stable Pro Pet Animal Clippers...
How to replace brake switch connector on 96 ford explorer?
REMOVAL:
Lift the locking tab on the switch connector and disconnect the wiring.
Remove the hairpin retainer, slide the stoplamp switch, pushrod and nylon washer off of the pedal. Remove the washer, then the switch by sliding it up or down.
On some vehicles equipped with speed control, the spacer washer is replaced by the dump valve adapter washer.
INSTALLATION:
Position it so that the U-shaped side is nearest the pedal and directly over/under the pin.
Slide the switch up or down, trapping the master cylinder pushrod and bushing between the switch side plates.
Push the switch and pushrod assembly firmly towards the brake pedal arm. Assemble the outside white plastic washer to the pin and install the hairpin retainer.
Don't substitute any other type of retainer. Use only the Ford specified hairpin retainer.
Assemble the connector on the switch.
Check stoplamp operation.
Make sure that the stoplamp switch wiring has sufficient travel during a full pedal stroke.
May 17, 2014 | Vehicle Parts & Accessories
Problems Andis AGC 2
Sounds like it's time to replace the clippers with something much better.
Apr 24, 2013 | Andis Agc Super 2-speed Clipper...
Andis master clippers lose power
Oil the blades and then adjust them. You will need to add oil while grooming from time to time and then clean & oil them again when finished.
Sep 23, 2012 | Andis Improved Master Clipper/Trimmer...
How to change break switch on 89 mustang
  1. Disconnect the negative battery cable.
  2. Unplug the wire harness at the connector from the switch mounted at th brake pedal. The locking tab must be lifted before the connector can be removed.
  3. Remove the hairpin retainer, slide the stoplight switch, the pushrod and the nylon washers and bushings away from the pedal and remove the switch. NOTE: Since the switch side-plate nearest the brake pedal is slotted, it is not necessary to remove the brake master cylinder pushrod and washer from the brake pedal pin. To install:
  4. Position the switch so the U-shaped side is nearest the pedal and directly over/under the pin. Slide the switch down or up, trapping the master cylinder pushrod and black bushing between the switch side plates. Push the switch and pushrod assembly firmly toward the brake pedal arm.
  5. Assemble the outside white plastic washer to the pin and install the hairpin retainer to trap the whole assembly.
  6. Assemble the wire harness connector to the switch. Check the switch for proper operation. Connect the negative battery cable. NOTE: The stoplight switch wire harness must be long enough to travel with the switch during full-pedal stroke. If the wire length is insufficient, reroute the harness or service, as required.
Fig. 1: Brake pedal assembly
Feb 07, 2011 | 1989 Ford Mustang
Install power brake booster on 1988 ford ranger
REMOVAL & INSTALLATION NOTE: Make sure that the booster rubber reaction disc is properly installed if the master cylinder push rod is removed or accidentally pulled out. A dislodged disc may cause excessive pedal travel and extreme operation sensitivity. The disc is black compared to the silver colored valve plunger that will be exposed after the push rod and front seal is removed. The booster unit is serviced as an assembly and must be replaced if the reaction disc cannot be properly installed and aligned, or if it cannot be located within the unit itself.
  1. Disconnect the stop lamp switch wiring to prevent running the battery down.
  2. Support the master cylinder from the underside with a prop.
  3. Remove the master cylinder-to-booster retaining nuts.
  4. Loosen the clamp that secures the manifold vacuum hose to the booster check valve, and remove the hose. Remove the booster check valve.
  5. Pull the master cylinder off the booster and leave it supported by the prop, far enough away to allow removal of the booster assembly.
  6. From inside the cab on vehicles equipped with push rod mounted stop lamp switch, remove the retaining pin and slide the stop lamp switch, push rod, spacers and bushing off the brake pedal arm.
  7. From the engine compartment remove the bolts that attach the booster to the dash panel. To install:
  8. Mount the booster assembly on the engine side of the dash panel by sliding the bracket mounting bolts and valve operating rod in through the holes in the dash panel. NOTE: Make certain that the booster push rod is positioned on the correct side of the master cylinder to install onto the push pin prior to tightening the booster assembly to the dash.
  9. From inside the cab, install the booster mounting bracket-to-dash panel retaining nuts.
  10. Position the master cylinder on the booster assembly, install the retaining nuts, and remove the prop from underneath the master cylinder.
  11. Install the booster check valve. Connect the manifold vacuum hose to the booster check valve and secure with the clamp.
  12. From inside the cab on vehicles equipped with push rod mounted stop lamp switch, install the bushing and position the switch on the end of the push rod. Then install the switch and rod on the pedal arm, along with spacers on each side, and secure with the retaining pin.
  13. Connect the stop lamp switch wiring.
  14. Start the engine and check brake operation.
Fig. 1: Check the booster pushrod adjustment using a gauge with the shown dimensions
Fig. 2: Exploded view of the typical power brake booster tecnovative_79.gif Fig. 3: Booster vacuum hose connections - 2.3L & 2.9L
Fig. 4: Booster vacuum hose connections for the 4.0L
Feb 03, 2011 | 1988 Ford Ranger
TO JTURCOTE, THANK YOU BUT MY SWITCH DOES NOT LOOK LIKE THE ONE IN THE DIAGRAM. MINE IS MOUNTED HIGH ON THE BRAKE PEDAL ARM BUT IS NOT CONNECTED TO THE MASTER CYL. PUSH ROD. HELP
Sorry. That is the one autozone.com calls for in your car. there is another one in the book for the other trucks. Does yours look like this? If so, instructions pasted below.
Fig. 1 Exploded view of the brake light switch
  1. Lift the locking tab on the switch connector and disconnect the wiring.
  2. Remove the hairpin retainer, slide the stop lamp switch, pushrod and nylon washer off of the pedal. Remove the washer, then the switch by sliding it up or down.
On trucks equipped with speed control, the spacer washer is replaced by the dump valve adapter washer.
  1. To install the switch, position it so that the U-shaped side is nearest the pedal and directly over/under the pin.
  2. Slide the switch up or down, trapping the master cylinder pushrod and bushing between the switch side plates.
  3. Push the switch and pushrod assembly firmly towards the brake pedal arm. Assemble the outside white plastic washer to the pin and install the hairpin retainer.
CAUTION Don't substitute any other type of retainer. Use only the Ford specified hairpin retainer.
  1. Assemble the connector on the switch.
  2. Check stop lamp operation.
Sep 24, 2010 | 1999 Ford Expedition
How to adjust my til tof my 10
When you are facing the saw as if you would be operating, there are two adjustment wheel on the front and right hand sides of the saw cabinet. The front wheel adjusts the blade height, the wheel on the right side of the cabinet adjusts tilt. Each of these wheels are equipped with a locking nut, a smaller wheel in the center. this must be loosened before any adjustments can be made and should be tightened before operation. If there is significant resistance while trying to adjust either of these it may be a result of misaligned gear or excessive buildup of dust and shavings on the gearing.
Feb 14, 2010 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Master Equipment Z-Lift Electric Dog Grooming Table in Ivory Size: 24" W x 42" D Logo
22 people viewed this question
Top Master Equipment Pets - Others Experts
Ross Keen
Tom Chichester
Ruth summersides
Are you a Master Equipment Pets - Other Expert? Answer questions, earn points and help others
