Keeps off switching• A handheld PDA electronic device keeps switching off?
How to change from com 1
Palm (PDA) - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/Palm_(PDA)
WikipediaThe Palm Treo 700p is one of many smartphones produced that combines Palm ... Although HP kept the Palm brand initially, all new PDA devices announced at press ....In order to try to change this trend Palm had been working on a new ...
How to Replace the Battery in Your Palm Tungsten E2 PDA ...
? 4:34
https://www.youtube.com/watch?v=caJVwecskho
Sep 2, 2007 - Uploaded by Aaron Kelly
How to Replace the Battery in Your Palm Tungsten E2 PDA. Aaron Kelly ... for battery replacement. Includes one year money back guarantee!
[PDF]Handbook for the Palm Tungsten E Handheld - Textfiles.com
pdf.textfiles.com/.../PDA/PalmOne%20Tungsten%20E%20Handheld.pdf
Chapter 1: Setting Up Your Palm™ Tungsten™ E Handheld . . . . . . . . . . . . 1. System requirements . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Jan 03, 2016 | Palm Computers & Internet
Can not get the device to turn on
There should be a pin hole on the back of the PDA. Press the hole using a thin paper click. This will RESET your PDA. Press the power button and it will work OK. All PDA's have a RESET option.
Jun 01, 2015 | Palm z22 32mb handheld pda organizer z22-b
How do i cornect with my handheld pc im on bt broadband
go to devices and then right click on your handheld then trouble shoot then fix.
Feb 05, 2011 | Pretec 56k Compact Flash Modem for PDA...
Tungsten E: difficulty starting and turning off
PalmOne had a manufacturing issue in the Tungsten E and E2 PDA versions.
Bottom line is the On/Off switch is not properly soldered (enough soldering amount) so is easy that breaks the soldering joint of the switch to the main board.
The repair requires to open the PDA, remove very carefully the mainboard, and put straight (vertical) and re-solder the switch again.
It is needed a minimum of tools for it (soldering iron, torx screwdriver, wire soldering, plastic pry tool), and some skills and experience in fixing electronics.
Also, you can get with a radio or TV repair techniocian, and ask specifically to resolder such On/Off switch.
Best regards,
Jun 08, 2009 | Palm Tungsten E2 Handheld
I need to replace battery. Is it easy to get back off? Manual says I need to take it to repair shop
Basically to take any phone or pda apart, unscrew all screws and look for hidden screws under soft objects or labels etc.
ones all screws are out, use a small flat screwdriver or a case opener tool to carefully open the case of the phone or pda. it should snap open, very likely plastic holders on the corners that keep the case closed, carefully snap them open / off, don't break them.
May 13, 2009 | Mitac MIO P350 PDA POC PC+ GPS SAT NAV...
Fatal Exception
Make sure you have more than 25% space left on your device and try again. If this fails then try a hard reset: hold down power button and press reset.
For more help:
admin@dec-help.co.cc
DEC Electronics Limited
www.dec-help.co.cc
Feb 17, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Wireless web
Assuming you have Blue Tooth, Go to the bluetooth application on your PDA and click on setup devices. You will also need a bluetooth computer that is connected to the internet for this. When you have set up your computer then click on bluetooth hotsunc in the device setup page and follow the onscreen instructions.
For more help:
www.dec-help.co.cc
Jan 15, 2009 | Palm Tungsten E2 (Multilingual) Handheld
How can i connect to the msn messenger / google talk
I believe this may be a problem with your handheld device or handheld wireless service and not either of your broadband routers. Your particular PDA does not utilize the same wireless technology that your PCs and laptops do. Your PDA works with GSM,gprs & GPRS technologies. While laptops and PCs most commonly use 802.11a/b/g technologies. In summary, your PDA does not go to the Internet through your broadband routers. In fact, other than connectivity through bluetooth or USB, I doubt your PDA has any interaction with any devices connected to the broadband routers. Now, why can you not access certain services on your handheld? It may be that you are not connected to the right network with your service provider. It looks like this devices works on the Cingular network. There are 3 types of networks available. GSM, which is used primarily for voice traffic. gprs (note the lowercase), which is used for simple text messaging. And GPRS (note the uppercase), which handles all the other types of data transfer, including browsing the web and chatting. First, you may want to check with your service provider that you have an active plan that supports Internet surfing and chatting, such as GPRS (note the uppercase again). Second, once this has been confirmed, make sure the network indicators on the PDA show that you are connected to the GPRS (and not the GSM or gprs) network. Only when you are connected to the GPRS network, will you be able to utilize all the features of your PDA (voice calls, text messaging, and e-mail/web browsing). One way to force the PDA to get on the GPRS network is to just resset the wireless antenna. Second would be to reboot the device. If neither of those work, I would recommend contacting your service provider, as they will be able to help you trouble shoot PDA and network issues further. More info can be found here: https://onlinecare.cingular.com/support/setDevice.do?universe=cingular&make=HP&model=iPAQhw6515&x=42&y=0 Or call here: 1-800-331-0500
Sep 06, 2006 | D-Link DI-707P Router (DSDLDI707P)
Keeping Programs when updating ROM
Save the programs file to your Ipaq Storage Memory, which is part of the memory on you PDA that will not lost its files when you do a rom update or hard reset.
Sep 11, 2005 | HP iPAQ HX4705 Pocket PC
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
