Question about Car Audio & Video
Is a kenwood kdc-bt752hd stereo compatible with Sirius xm v200 connect vehicle tuner
  • 69 Answers
SOURCE: tuner error
Use a multimeter to check for connectivity to the sirius. Where did you mount the antenna? Maybe its a reception problem? Sounds like the head unit is going bad. Try shutting it down, and take the pace plate off, let it reboot and see if it works. Check to see if the Tuner is unplugged.
Posted on Aug 14, 2008
Mykel_N
  • 315 Answers
SOURCE: I have a stereo deck I had someone install it and
if you have the manual have a look under the page titled security...
If not then try 3051
if that doesnt work try this:
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
push button "track up" for 3 seconds
The security is canceled and the set enters the TUNER mode!
Hope that helps
Mike
Posted on Sep 01, 2009
  • 35 Answers
SOURCE: I have a kenwood KDC-MP438U stereo. Ipod error.
Hi If anything the stereo was probably designed and tested using a certain version of the Iphones software, now that version 4 has been released the way the IPhone communicates may have changed.
As a result the stereo is no longer able to talk to the phone and vice versa. your probably best off contacting Kenwood direct to see if they are aware of this problem and if there is anything that can be done about it.
Posted on Jul 28, 2010
  • 140 Answers
SOURCE: How do I unlock my Kenwood KDC-MP528 car stereo
To reset the code do the following:
1) Turn on the car.2) The faceplate rotates out and the CODE - - - - prompt appears.3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
For further assistance please let me know.
Posted on Feb 17, 2012
  • 483 Answers
SOURCE: car stereo installion
I think you left the yellow wire from the kenwood disconnected
Posted on Mar 06, 2013
Chrysler 200 convertable how to put pictures on radio
SiriusXM Connect Vehicle Tuner - Shop - SiriusXM Radio
https://shop.siriusxm.com/xm/ctl10600/cp49759/.../c...
Sirius Satellite RadioMy Account. I'm a Subscriber ... Image 1 SiriusXM Connect Vehicle Tuner · Image 2 ... Add Satellite Radio to any SiriusXM-Ready™ car stereo receiver. Connect ...
[PDF]User Guide - SiriusXM
www.siriusxm.com/.../pdf/SkyDock_UserGuide.pdf
Sirius Satellite RadioThe XM SkyDock incorporates an XM Satellite Radio Tun- er . A special .... image to match the XM SkyDock's .... found on the My Account screen (in Settings), ... Button: Tap to tag the current song and add it to your tagged song list . For.
Dec 10, 2015 | 2011 Chrysler 200
Kenwood car stereo manual
Crutchfield has the manual on the product page in the Details tab: http://www.crutchfield.com/S-bfT7rFz0tNa/p_113DDX790/Kenwood-Excelon-DDX790.html . Scroll down to the What's in the box section on the right. The direct link to the manual is http://a248.e.akamai.net/pix.crutchfield.com/Manuals/113/113DDX370.PDF .
If you mean the Sirius XM Radio ID to associate the receiver with the Sirius Connect Vehicle Tuner, when in the Sirius XM mode, tune the unit to Channel 0 .
I hope this helps.
Aug 29, 2014 | Kenwood DDX790 In-Dash 6.95" LCD...
Car stereo installion
Mar 05, 2013 | Kenwood KDC-BT752HD CD receiver
The radio says it's Satellite ready, but when I hit the search button I do not get a Satellite option. When I called Sirius/XM to switch service from one car to another, they said that I must now also...
No it is satellite ready, meaning you need to add atuner to the stereo, but you can use the stereo to control the tuner. Again, a seperate tuner will need to be bought and installed. Good Luck.
Sep 08, 2011 | Kenwood Kdc-bt645u Car CD/ MP3 Player
Where do you connect the data cable...on back of the stereo and where else?
The data cable (IP Bus) can connect to several different component designed for your unit, i.e. xm/sirius tuner, HD radio tuner, CD changer, etc.
Sep 17, 2010 | Kenwood KVT-715DVD Car DVD Player
I don'tknow how to use the satellite radio...
Got this off the crutchfiel web site.
Item #700XMSON1 $129.98 This XM Direct 2 package includes everything you need to add XM Satellite Radio to your compatible Sony receiver: an XM Mini-Tuner, a CNP2000UC universal adapter, and a Sony connector cable. The Mini-Tuner connects to the universal adapter, then you use the connector cable to hook up the adapter to your Sony receiver.
Use your home computer to program the universal adapter for your Sony receiver — you can reprogram this adapter to work with another brand in the future. Once connected, you'll be able to change channels and see programming information on your stereo's display. You can also use the included XM Mini-Tuner with your XM-ready home receiver or in another vehicle with a compatible dock.
A computer running Windows XP and Internet Explorer is required. The unit is not compatible with Windows Vista.
Note: A subscription to XM is also required — learn about XM's programming. Satellite radio service is available only within Canada and the lower 48 states — not available in Hawaii or U.S. territories. Portable reception may vary by location. If you have questions about the proposed XM/SIRIUS merger, read the XM Customer Promise. To view this file, you will need the Adobe Acrobat PDF reader.
Apr 16, 2009 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
KDC-MP532U (Lost ESN # ??)
That will be a problem with the XM box you connected to it, call xm see if thay can help, the radio is just liike a screen for the XM nothing more the box controlls all of it.
Don
Jul 09, 2008 | Kenwood KDC-X590 CD Player
Sirius vs. XM
Hello pdweidner,
The CN-NVD905U is fully satellite ready and is compatible with both Sirius and XM. To change services you will need to purchase and install a XM compatible tuner and antenna to replace the Sirius tuner and subscribe to XM service.
Best regards,
Ken
Go Ahead. Use Us.
May 13, 2008 | Panasonic Strada CN-NVD905U GPS Receiver
Tuner error
Nov 16, 2007 | Kenwood Sirius KDC-MP225 CD Player
Sirius ESN
either look on your sirius tuner, or if you go go into your deck's main menu, it will probably say it there
Apr 28, 2007 | Kenwood KDC-MP228 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
