Question about Electrolux Twin Clean Bagless Canister Vacuum
Vacuum turns off after a few minutes - Electrolux Twin Clean Bagless Canister Vacuum
Brush Bar Randomly Stops Turning
There are numerous things that could cause this. It would be best to find a qualified Dyson repair person to determine the cause of your DC28.
Nov 30, 2017 | Dyson DC28 Animal Bagless Upright Vacuum
Will not start, will not reset
I have a Silver Moon S558, when I turn it on the power light comes on and a few secords later the red warning light comes on. What is causing the vacuum not to work? One day I was vacuuming, turned it off and a few minutes later went to turn it on and nothing, but these lights turning on. Is there a fix?
Mar 11, 2011 | Miele s558 Silver Moon Vacuum
My vacuum cleaner will run for a few minutes and then shuts off. The plug light on the panel blinks. I thought the motor was shut, but after a long time it will turn on again, but again, only for a few...
I know nothing about your particular vacuum, but many vacuum cleaners these days have
safety cut out's, which causes the motor to do exactly what you describe. Sadly blockages, faulty switches, over stretched cables, carbon brushes etc could also give similar symptoms, so sounds like a job for the repairer on this occasion. Get a quote first if you can.
Feb 06, 2011 | Electrolux Epic 6500 Vacuum
Irobot stops after a few minutes and says plaes
soooo, what is not understood here ?
turn it over, open brushes cage, take each brush out and clean it.
In addition, also clean the sides from any dirt/hair that may stuck in its pivots.
good luck
Avi
Apr 07, 2010 | iRobot Roomba 560 Robotic Vacuum
Dies after a few minutes of vacuuming
The thermal cut-off in your machine is activating - this indicates that you have a blockage or a clog in the machine. The machine will turn itself off so that the motor doesn't overheat - the machine will cool off and you'll be able to turn it on after 30 mins to an hour.
Call the Dyson Helpline for a thorough blockage check - they know what they are doing.
Jun 15, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Eureka Vaccum Tripping Breaker While in Use
ur overloading the circuit in the house try turning off everything that is on that surcuit i mean everything then see if the vac works
Apr 04, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
CUTTING OFF
Ok What is probably causing the problem is an internal error inside the vacuum. What I recomend you to do is take it back where you bought it and tell them what ever is wrong with it.
PLEASE RATE MY ANSWER AS SOON AS POSSIBLE!
Hope it works! Tell me if you have any questions later on!
Jun 17, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Electrolux Twin Clean Bagless Canister Vacuum Logo
15 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
