Question about Electrical Supplies
I have a Generac portable generator 5000 watts, won't start!
I have a Generac portable generator 5000 watts with 10 horsepower Briggs and stratton engine and I cannot start the engine after an oil change; there does not seem to be any spark at the plug when I try to start it. I do not have the owners manual and need a troubleshooting flow chart.
  • Samuel Charles Spriggs May 11, 2010
    There is probably a sensor which will not allow engine start when low on oil. How much oil did you put in it? Do you have owner's manual?
  • Anonymous Mar 13, 2014
    What kind of oil does a ust 1200 watt portable generator use
    Scholar:
  • 79 Answers
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
Posted on May 08, 2009
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
May 13, 2014 | Briggs & Stratton Briggs and Stratton...
Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator voltage adjust
Usually the cause of slightly low voltage like this is that the engine is not running at full operating RPM. Find the high speed adjusting screw on the govenor linkage and adjust the engine RPM until the output is 220V - 240V
Dec 09, 2013 | Briggs & Stratton Briggs Stratton 6200...
How to fix an off and on switch on a briggs and straton model series, 19e400 5000 watt, on and off switch located on top of the motor. is there a wire thats supposed to hook onto the switch somehow.
Kill switch should have a wire connected to the tab on the spark coil under fan cover. The switch is a means of shorting kill wire to ground. On some generators, there will be another method of shutting down the engine. Usually on/off switch will be more visable on the control panel. Most likely the switch on fan cover was not connected to prevent confusion.
Sep 14, 2011 | Briggs & Stratton Briggs and Stratton...
What is the fuel capacity of the Briggs and Stratton 5550 watt generator and what type of motor oil does it neet?
Hello, probably a really good guess is 2 1/2 to 3 gals. Oil type I would use cleaing additive multi-temperatur 10/15 or 10/20 well know brank. Synethic oil I don't know how well does it work in an air cool engine. GB...stewbison
Aug 23, 2011 | Briggs & Stratton Power Products 5,550...
Every tme I plug in an extenson cord the circuit breaker trips.
Try a different cord and see if it works ok. If the circuit breaker trips without anything plugged into the extension cord then the chances are that there is a short in the socket of the cord or it is wired incorrectly.
Apr 27, 2011 | Briggs & Stratton Briggs and Stratton...
I have a 5550 generator and all the sudden the power outlets stopped working. I pressed the reset buttons and nothing. I hooked my electrical device to another generator and it works. What is the problem...
Hello, it sounds like either you have a voltage regulator failure, the rotating field coil is shorted or opened, or the exciter windings have failed. No easy answer because there are a number of issues here as you can see. Depending on how old the unit is you might have warranty. I would suggest you take it to a generac service center to have it checked out. I have 30 years experience with generac units. If it is a voltage regulator issue, (this can be expensive) you can get a jobber regulator. This link is for a good generic substitute. http://www.mcphersoncontrols.com/html/mcp_products/voltage_regulators/MTS63-4.html
I have used this regulator on 4000 watt to 50 kw units successfully. If it is a winding, then to rewind the stator part of the generator is expensive and a new generator is cheaper.
joe
Jan 15, 2011 | Briggs & Stratton Briggs Stratton 6200...
GENERATOR WILL NOT MAKE POWER AT PLUGS ONLY MAKES 23 AMPS
Your manual says only plug 20Amp loads into each 120 receptical. See manual at: http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=fequxHX-nfBhU7y
that would be 4 recepticals tmes 20 = 80 Amps'
80 Amps times 120 V = 9,600 Watts This means that you cannot hook up all 4 outlets at the same time as that would overload the generator all you can hook up would be 2 outlets of up to max of 23 Amps
The manual restricts you to each load no more than 20 amps because some devices such as drills, water pumps exceed their running load upon start up, and would exceed the 20 Amps momentarily, thus 23 amps.
The maximum power load of the generator is 5000 watts and 20 amps at each outlet.
You certainly are within the useful range.
Volts time Amps = Watts
Jan 10, 2011 | Briggs & Stratton Briggs and Stratton...
Electrical Supplies Logo
2,016 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
