Question about Dell Vostro 3700 Laptop Computer PC Notebook
Dell inspiron n4050 PXE-E61:Media test failure, check cable
tparsenault
  • 170 Answers
SOURCE: when turning my laptop on i get a message media test failure
You see this message when the laptop trying to boot from a remote server using the network card. If you didn’t see the PXE-E61 message before, it means that the network card was listed after the hard drive in the boot order (you can set the order in BIOS) and the laptop booted directly from the hard drive. Now, when the hard drive has failed, the laptop cannot detect it and tries to boot from the next available device – the network card. Your laptop is not configured to boot from a remote server using the network card, that’s why you are getting PXE-E61 Media test failure error. You have to replace the hard drive and reinstall the operating system.
Posted on Jan 19, 2009
ajx13
  • 110 Answers
SOURCE: my mini dell inspiration laptop sends me an error
This error comes up if the computer is not able to detect the hard drive. Power off the computer. Power it back on and tap the number 2 key 4 - 5 times at the Dell logo screen. This will take you to the system setp screen. Check if you see any thing listed next to solid state drive. If you dont see any thing try reseating the hard drive. Here are the steps to reseat the hard drive.. If you see an entry next to the solid state drive. You'll need to reinstall windows on the computer. If you have been shipped XP you will need an external CD drive to reinstall windows. If the system was sen with ubantu try to download it to a usb drive and boot off it.
Rate if useful.
Posted on Aug 08, 2009
  • 5 Answers
SOURCE: Problems with my inspiron 1501 details below
The problem your having could be the operating system is damange or the hard drive failed. Try to boot from a Windows XP or Vista CD to see if the drive is recognized.
Regards,
Posted on Sep 01, 2009
  • 16 Answers
SOURCE: Pxe-e61: media test failure, operating system not found
First, take out any CDs/DVDs and try to boot again. If that doesn't work, your hard drive may be defective.
There will be a cover on the bottom of your laptop that holds the hard drive (easy access). You can try removing and reinserting the hard drive and then booting the PC afterward.
If that doesn't work, you will likely have to replace the hard drive, but best advice would be to take it to a computer technician for further analysis.
Posted on Sep 02, 2009
Testimonial: "I knew it migth be the hard drive, but I was hoping it was not. Thank you."
  • 188 Answers
SOURCE: Dell inspiron mini pxe-e61 media
To fix the issue we have to reinstall the software
Use the follwing link and do that
http://findtechhelp12.blogspot.com/2010/11/how-to-reinstall-os-in-dell-computer.html
Posted on Nov 29, 2010
Dell inspiron mini wont boot, screen says pxe-e61: media test failure, check cable, pxe-m0f: exiting pxe rom. And operating system not found. What do I do?
This is because the Bios doesn't find where to boot from and it tries to boot from lan. Take out the hdd, put it back and try again. Try also with another hdd. Check the bios to see the boot order. Post here results !
Apr 15, 2013 | Computers & Internet
Operating system not found
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 22, 2012 | Dell Inspiron 910 Laptop/notebook Black
PXE-E61 Media test fail, PXE-MOF Exiting Broadcom PXE ROM
Disable PXE in the Boot Sequence in the BIOS setup [F2]
Aug 10, 2012 | Dell Computers & Internet
Pxe E61 Media Test Failure Check Cable
my server ph prolite doesn't start gives an error essage "PXE-E61: Media test failure, check cable" the reboots after 5 seconds
Apr 22, 2012 | HP ProLiant DL180 G5 Server
When I turn on the Mini laptop, what does this mean: Realtex RTL8101E/8102E PCI-E Ethernet Controller v1.08 PXE-E61: Media Test Failure, check cable PXE -M0F: Exiting PXE ROM Operating System not...
media test failure like above while
booting means that the problem already solved as long as you can get
into Vista/win7/xp as usual. PXE shown in the massage is
the Ethernet network boot option which you’re not using. There are 4 options you can use for boot up the laptop:
1. Network
2. DVD/CD
3. USB Storage
4. HDD
That was better to use HDD unless you are connected to a LAN then you need to change it to Network
Aug 31, 2010 | Dell Inspiron Mini 10 Notebook
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
When turning my laptop on i get a message media test failure
Jan 19, 2009 | Dell Inspiron 1501 Laptop
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Aug 31, 2008 | Acer Aspire 3680 Laptop
Dell Vostro 3700 Laptop Computer  PC Notebook Logo
73 people viewed this question
Alun Cox
