Question about Kenmore 63942 Dryer
How do I replace the door switch on my Kenmore 70 Series dryer? I can't seem to get at it?
    Genius:
  • 1,122 Answers
Most people just bypass it,remove the 2 head screws one on each side (you might have to snap off the plastic end caps,flip the head up,you will see the lid switch jack in the middle,unplug it and cut the 2 outside wires and wire them together,plug back in and your done-mike
Posted on May 09, 2009
  • MIKE major May 09, 2009
    this was a mistake don't use this on a dryer it's for a washer,i posted the dryer solution-mike
Where can i find the door switch on the kenmore 70 series dryer
the door switch is located inside the door on top left or top right of the dryer, if it is one of the newer 70 series dryer it will be on the inside bottom towards the middle
Apr 13, 2014 | Kenmore 63942 Dryer
How do you replace the door switch in a Kenmore 70 Series 68702 electric dryer?
What is the model number of your unit? Look inside the door area.
Nov 19, 2012 | Dryers
Kenmore 70 series suddenly stopped. Door switch seems to be engaging. Not sure about other switches. Is there a fuse I can check?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 15, 2010 | Kenmore Dryers
How do you turn off the dryer signal on kenmore 70 series dryer
On a 70 series dryer, the knob on the far right of the panel controls the signal. You can turn it left or right to set the signal to "On" or "Off."
If you've set it to Off and the signal still comes on, that switch that sits behind the knob is bad. It's the same switch that controls when the dryer starts. You can either try to repair it (by bending the contacts back into their original alignment) or replace it. A new switch is less than $10, and you can get one many places online, including from PartSelect.com:
http://www.partselect.com/PartDetail.aspx?inventory=345390&SourceCode=3
May 20, 2010 | Kenmore 63942 Dryer
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 series dryer problem
HI. This may be an issue concerning the pressure switch that is located inside the rim of the actual door.
This switch activates the main drum motor when a cycle is selected when you are ready to dry your clothes. As soon as you select the desired cycle and you load the clothes and shut the door, the last thing to do is push the start switch. if the door pressure switch is malfunctioning, it will not allow you to start the dryer. it will simply not spin.
If you can visibly see the light inside the drum/basket while the door is closed, this will confirm the malfunctioning pressure switch that is located inside the inner part of the door rim.
Its located in this position so that the actual door can make contact with it, in return, applying pressure to close the switch and complete the circuit. this will cause the dryer to spin.
You stated that you can see the drum light shinning when the door is closed and, this will confirm my diagnosis. You can preform a hard reset just to make sure of this defect. Simply unplug this unit for 5 minutes or, shut down the circuit breaker for 5 minutes as well. Any methods will work. Once the 5 minutes are up, simply plug back in this unit and try to run a normal cycle. if this problem is still and issue, it will once again confirm a door pressure switch failure and you will need to replace the switch in this unit.
I would check the wire clips and connectors as well located on this switch for lose or worn contacts. this can be a problem spot as well.
Please rate and god bless:)
Apr 26, 2009 | Kenmore Dryers
Kenmore dryer series 70 won't turn on
most of the time it is the door switch that goes bad,also you can check the main fuse inside the dryer on the blower box,and always make sure your dryer vent and wall vent are clear to vent,let me know what you find-mike
Oct 26, 2008 | Kenmore 63942 Dryer
when you put your belt back on you must have had to take the front panel off am I correct? Did you forget to reconnect the door switch wires? Without them re-connected your dryer won't run.
Kenmore 63942 Dryer Logo
184 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
