Question about Zenith DVP615 Portable DVD Player
Does not work always says check disc after loading
When I put the disc inside it loads for a minute and then suddenly says check disc.... my son put his hand inside and I don't know what happened please help me fix my portable dvd player.
    President:
  • 814 Answers
You need to try to clean the laser head and the transport. To do this you will need cotton swabs, isopropyl alcohol and small cans of lithium grease and compressed air.. Open the up the compartment that the dvd discs are placed. In the center of the compartment you will find the spindle and a laser transport. In the transport you will see the laser head. Take a cotton swab and put a small amount of alcohol on the tip. Rub the tip of swab gently across the head of the laser. Do this until the head look bright and shiney. Use the other end of the swab to dry the excess moisture off the laser head. Take another swab and use a small amount of alcohol on the tip and go around the transport device cleaning the dust and dirt from it. Use a small can of compressed air to blow away any dust and dirt in the compartment. Once the laser head is cleaned and the transport is cleared of dust and dirt, Move the transport to the outer most point and bring it back in to its closest point. Do this several times. Do not applie to much pressure while doing it.If you find ruff and uneven action. Clean the areas of problem and return the transport action to smooth and easy operation. If still not smooth and easy. Take another cotton swab and use some lithium grease in very small amounts to lubricate the transport rails. Again move the transport back and forth to lubricate the laser transport. This should return the transport to normal action. Now play a music cd to calibrate the laser head . Let the cd play through a couple of times. After doing this you can now try a dvd disc and it should play normally. If it still does not play correctly, check the spindel to see if it is loose. If this is the case use a drop of super glue to tighten it up. Let it dry completely and try the disc again. It should work correctly. If you are still having a problem.You either have a problem with the laser itself or the drive motor. The drive motor problem would usually be noticed on the playing of the cd. The laserhead and the motor can be replaced if this is the problem. You can find more information on how to do these repairs on you tube. Put cleaning and repairing portable dvd players in the search engine and it will bring up videos on how people have done these types of repairs. I hope this information will help you with your problem.
Posted on May 30, 2009
  • 67 Answers
Try alcohol swab on laser lens let dry and put dvd back in
Posted on May 08, 2009
D drive will not load some disc programs in to the computer
If you are saying D drive is your CD/VDVD drive? If you are installing from CD/DVD drive then suddenly stop the installation/setup/loading you must check your disc drive. To check your cd/dvd drive insert a cd or dvd cleaner and start cleaning most of the cleaner has a movie inside of the disc and run for about 10 minutes. Then try again installing/setup/loading the program to your computer. If its still the same, replace your CD/DVD drive with a new cd/dvd drive because your cd/dvd drive is need to be replace. Have a nice day
Jan 26, 2011 | Computers & Internet
CD's in Changer won't play
When it is broke it will do that, I mean need to buy another if it does it with all discs. It may not be reading anymoree and therefore says the message you get. Try to load from the my computer as well as desk top and see if anything works. Do you have the number to the company??
Dec 22, 2009 | Bose Wave music system Multi-CD Changer...
My son was messing with the controller, and it came to a screen with different languages. I kept trying to go back, but wouldn't let me. so I restarted the console. When it came back on it was stuck on the...
I can bet you that your xbox 360 is vertical? am I right? If no then my disk holder gets jammed a lot, so i would get 2 small flat head screwdrivers and pry it open. So put your xbox 360 horizontal. This would also fix the problem. If your son still has the language screwed up u have to learn some spanish or watever it is to figure out how to put it back. It would be on profile settings.
Aug 14, 2009 | Microsoft Xbox 360 Console
Does not play DVD
You need to open top cover and look inside dvd player cd tray. Does dvd / cd disc spins or having loading problem because grrrrr seems mechanical problem.
Let me know your finding to guide you further.
Thank you.
Oct 25, 2008 | Sony DVP-NS575P DVD Player
Mini Disc Not Working
Pull the power cord. Make sure the three-position switch with "REC/Standby/PLAY" is in the middle position, then plug the cord back in. Wait a minute, then press POWER. Now load a disk and wait 1 minute for it to read the Table of Contents (TOC). Either it will show the tracks, or it will say 'empty disk'. Let us know what happens from there, okay?
Oct 06, 2008 | Sony MDS-JE480 Mini Disc Player
My ps2 is unable to load any disc
maybe it's the lens were loose. Try to check inside of ps2!
Apr 28, 2008 | Sony PlayStation 2 (PS2) Console
My PS3 Games wont show up in the games list
Return under warranty.
the blu ray laser will have been slightly overheated and as a result will need to be replaced.
Feb 18, 2008 | Sony Playstation 3 (PS3) Console
Disk wont load.
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
169
Nov 30, 2007 | Nintendo Wii Console
My nintendo wii wont load discs??
Here's a page on the official Nintendo site that might help.
"Unable to read the disc" / "Disc could not be read" If you are getting one of the above error messages:
    • If your console is placed vertically, the disc label will face to the right.
    • If your console is placed horizontally, the disc label will face upwards
  • If you know you are inserting the Game Disc correctly, but are still have the same problem with only one game (or if you only have one game), try cleaning the Game Disc by following the disc cleaning procedures (click here).
  • If after reading the above information you are still unable to play a game disc, please call 1-800-255-3700 to discuss available options.
Oct 23, 2007 | Nintendo Wii Console
Zenith DVP615 Portable DVD Player Logo
401 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
