Farenheit HP-115 does not connect to wireless
Have 2 black wires n 1 green is this 115 0r 220 volts n where do wires go l1 or l2
The TWO Black Wires are Phase and neutral and it's irrelevant which way they go on the motor, the Other is the earth and that MUST connect to the case.
Black, L1 & L2 the other green EARTH.
115 or 120 doesn't matter
Aug 09, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Well it is not an AO Smith, but I have an older Eneregair compressor with an Energair America motor 2 HP, 230v 12 amp. It says on the compressor that it is a 115/230, so I am wondering if it is possible...
Thank you for posting your question here on Fixya.com.
A 2 HP motor is usually only going to connect to 230V 1~ because of the high amp draw if ran on 115V. The motor itself should say 115/230 V and then would also read 24/12 Amp. It seems based upon your post it is not a dual voltage motor, likely for the reason I stated. You can not reconnect the motor from series to parallel because the winding connections to the leads are not brought out for you to do so. Otherwise it would be labeled for 115/230. You can of course try to get a 2 HP 115 volt rated motor or try to reconnect a circuit where you wish to use the compressor to bring the 230 V to it. In the long run, you would be better off running the motor on 230V.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 05, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Got a waterway 1.5 hp 1 speed 115/230v, wired 115 need 230
Is there a coverplate where the wires come out of the pump? If so, remove the plate and there should be a wiring diagram inside.
Good Luck
Kurt
Mar 18, 2009 | Waterway Champion 1 1/2 Hp 230v Energy...
Not sure what I need for audio
Try turning your stero to 88.7. I cannot figure out how to get the sound to come out through the jacks though. I plan on buying the IR headphones at somepoint, but I would like to be able to use the jacks in the meantime
Dec 13, 2008 | Farenheit DVD-13 Car DVD Player
Glasses that become cloudy after a few washes. The temperature is never above 55.
hi
Dishwashers usually run on 115-volt or 120-volt power. The water they use comes directly from the water heater, and wastewater is drained into the sink's drainpipe. The dishwasher is not connected to the cold-water supply. For best dishwashing results, set the temperature control of the water heater to no less than 140 degrees Farenheit. Water cooler than this usually doesn't get the dishes clean, unless your dishwasher is a newer model that preheats incoming water. The water shutoff for the dishwasher is typically located below the adjoining sink.
Nov 10, 2008 | Miele Dishwashers
Not cleaning properly. all jets have been cleaned. could it be the heating element that has covered with limescale as we live in a very hard water area
hi Dishwashers usually run on 115-volt or 120-volt power. The water they use comes directly from the water heater, and wastewater is drained into the sink's drainpipe. The dishwasher is not connected to the cold-water supply. For best dishwashing results, set the temperature control of the water heater to no less than 140 degrees Farenheit. Water cooler than this usually doesn't get the dishes clean, unless your dishwasher is a newer model that preheats incoming water. The water shutoff for the dishwasher is typically located below the adjoining sink.
Sep 14, 2008 | Dishwashers
Hi, my dishwasher is not draining, any ideas?
Sep 13, 2008 | Asko Dishwashers
Ge top load washer WSERE526FOWW
Sep 11, 2008 | GE Washing Machines
How do I get audio on my farenheit dvd-15?
Did you try tuning in to FM 88.7, this should pick up dvd audio
Jun 28, 2007 | Farenheit DVD-13 Car DVD Player
52 people viewed this question
 Grubhead
Grubhead
