Question about Mitsubishi WS-65712 65" Rear Projection Television
When i plug in tv green light keeps blinking - Mitsubishi WS-65712 65" Rear Projection Television
  • 1153 Answers
SOURCE: My TV won't turn on. The Green light just keeps on flashing
1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067002 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). 5. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 6. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 7. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001
Posted on Sep 05, 2007
SOURCE: blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Posted on Sep 19, 2008
SOURCE: cannot turn tv on
What i did to fix the problem, and no i did not throw it off the porch which was my first idea after i received an estimite. There are 4 capcitors on the d board which a believe is the digital board. Its located to the left of the card tray and its the only board in a steel can cover. They need replacement. I bought mine at radioshack and the repair worked for me. I was later told that the radioshack caps will blow out in a few months but i had already installed them. It worked.You have to desoder the old ones out and resolder the new ones in. It cost me about 2 hours time and 5 dollars at radioshack because i needed to buy solder as well. I will try to find the directions someone sent me and post them, also i will try to find the right (cap) part number as i stated before, the radioshack ones are not going to last. You have to use HIGH HEAT cap do to all the heat the tv puts out.
Posted on Oct 11, 2008
SOURCE: Mitsubishi dlp tv green timer light blinking
timer light keeps blinking tv does not turn on
Posted on Nov 29, 2008
SOURCE: Mitsubishi TV WS 65869 blinking Green Light
I have the same problem with my projection screen TV.
Posted on Dec 08, 2008
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
The green light on front of tv keeps flashing and tv wont turn on
Howdy,
The green light blinking indicates your TV has a problem. The problem is that each Brand of TV has different codes and with out the Brand and Model number, I can not help you at this time.
Please, count blinking sequence. Model number will be on back of TV.
Recap : Provide Model Number, Brand and Count Blinks.
First though; unplug TV from power source for 3-5 minutes then plug TV & box back into a/c outlet.
Good Luck, BIG IRISH.
Dec 03, 2009 | Televison & Video
My Mitsubishi tv power light keeps blinking
have a 55 inch Mitsubishi TV.. the green power light keeps blinking.. is there anything I can do myself?.. or I have to have someone to get it fix?
Nov 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No picture, green light keeps blinking, hear fan go on then off, blinking light changes to red
Count the blinks between the pause, Let me know or call a sony service center if your a novice at tv repair
Apr 24, 2009 | Sony KP-57WS500 57" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blinking green light, will not power up
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Mitsubishi WS-65712 65" Rear Projection Television Logo
44 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
