Question about Turtle Beach Ear Force X42 Headset
Can't hear game sound in x42 headphones
Bought headset adapter for hdmi connection and still cannot hear sound
Why am i getting no power in x42 turtle beach earphone?
I am assuming this is not a sound issue, and an entire headset not coming on issue. Here are the steps that I would take...
1. Put in BRAND NEW BATTERIES!!! (Usually that is the culprit) ;-)
2. Unplug and then re-plug in all wires and cords to the console and the controller.
3. Check to see if the wires are connected from headset to end cords (on the one that plugs into the controller).
4. Once everything is connected and with brand new batteries, it should work, turn it on again. Remember the beep sound goes up when the turtle beaches come on, and the beep sound goes down when the turtle beaches are turned off.
Jul 02, 2014 | Turtle Beach Ear Force X42 Headset
Cannot hear sound from TV on Turtle Beach Headphones X32
This depends on if you use HDMI or cable component, inferring that you use HDMI you are going to need an adaptor for ur game system.
Oct 26, 2013 | Turtle Beach X32 Headset Xbox 360
Beaches wont turn mic
I for 1 don't know. But try to go to www.Turtle Beach.com they can help you out. I have Turtle Beach Ear Force XC1 and my mic I can talk but I can't hear anything but if your mic isn't working properly try using a different controller. If that doesn't help try getting a brand new mic.
Jun 23, 2013 | Turtle Beach Ear Force X42 Headset
I cant hear anything through my x41 headset
I can hear everything but myself on x41 other can hear me I just cant hear myself..
Mar 06, 2012 | Voyetra Turtle Beach Turtle Beach Ear...
How do i get game sound through my x11 whilst usind a hdmi cable as the headset plugs into xbox lead then into tv but u cant use the xbox lead and hdmi lead as they go in the same connection
In this situation you have two options. A) Use the orignal xbox lead cable with component, and YpBpR cable ends and plug in your headphones with that configuration. B) A lot of TV's these days have red and white (audio out) jacks, plug your headphone adapter into the audio out, and use your headphones with that configuration!
Apr 22, 2011 | Voyetra Turtle Beach Ear Force X11 Headset...
I have Bought an Adapter For my turtle beach headphones to my xbox 360 but i can only talk to people and not hear them any help?
Turtle beaches have two important cords to them, your microphone cord goes into your controller, then to get sound you have av adapters. You want to plug in you xbox av sound cords, the white and red ones, into your turtle beach ones. This then should deliver sound. If you use an hdmi cable look on the back of your tv for audio out ports.
Mar 10, 2011 | Microsoft Turtle Beach Ear Force Z2 PC &...
Voices and Game sounds from headset and from TV speakers
It isn't a headset issue. This is an issue that should be easily solved by going into the options menu of your game.
Aug 24, 2009 | Skull Candy Lowrider Headphones
Cannont connect Ear Force X3 with my HDMI set up .
Is the problem that you're using a single HDMI cable to connect your Xbox to your TV? If so, this Turtle Beach article should help... ________________________________________
HDMI and Connecting Ear Force Xbox Headphones
The current Microsoft Xbox 360 series of gaming consoles allow the use of HDMI cables for simpler hookup to home theater systems and Hi-Definition televisions (HDTV).
The Xbox 360 Elite (the black one) comes with two additional cables, an HDMI cable and a separate AUDIO cable that provides a pair of RCA jacks (red and white) and an optical digital audio output (S/PDIF Out). With this cable package, you can easily connect any of our X-series headsets and an HDMI-connected television at the same time.
This Xbox 360 HDMI Cable package is available as an extra-cost option from Microsoft: http://www.xbox.com/en-US/hardware/x/xbox360hdmiavcable/
Here's a more in-depth explanation of the Xbox 360 HDMI Cable and how it works: http://support.microsoft.com/kb/937899?sd=xbox
[NOTE 1:] The standard Xbox models do not come equipped with this cable set. The HD cable they have obscures the HDMI connector, so that the two sockets cannot be used at the same time. If you only have this stock HD connector (component video, composite video, stereo analog audio and optical digital audio connectors), then you will not be able to use the HDMI connector at the same time.
In order to use both sockets at the same time (HDMI and A/V) you'll need to purchase the Xbox 360 HDMI Cable package described above.
[NOTE 2:] The current Xbox 360 Elite Holiday Edition (Fall 2009) does not come with the HDMI Cable set.
___________________________________________________________________
Some companies make aftermarket HDMI cables for use with the Xbox 360, but these may not provide the dual RCA jacks that carry the 2- channel analog audio necessary for hookup of the anlog-only Ear Force X-series headsets. If this is what you have, you may need to find another way to connect your Ear Force X-series headset.
The TOSLINK digitally-connected X-series headsets can be always be connected using optical digital "Toslink" connections (and that's the best way to use them!).
The oldest white-and-gray Xbox 360 models DO NOT have an HDMI port. With this particular (obsolete) model, you cannot use HDMI connections, but you can use any of our X-series headsets.
Current Xbox 360 models all have separate HDMI and A/V ports ("sockets") on their back panels.
Here are some suggestions for alternative connection schemes:
XBOX 360 AUDIO PLAYS THROUGH TELEVISION SET:
For X4 and X41: Your best bet would be to connect the Xbox optical digital audio out to the X4 transmitter's optical digital input. Then connect the X4 optical digital output to the optical digital audio input on your HDTV or home theater amplifier.
[NOTE:] Some HDTV systems have an optical digital audio output that will not transmit Dolby Digital/DTS encoded digital audio, only stereo PCM audio will be passed. In this case, you must connect as above.
For X2, X3 and X31: You can use the Headphones jack or the Audio Out jacks on your TV to connect to the Audio In jack on the Transmitter.
For X1 and X11: You can use the Headphones jack or the Audio Out jacks on your TV (if available) to connect to the headset's analog Audio Input.
NOTE: Please make sure your TV has Audio Out jacks. Some TV's only have Audio In jacks.
Audio In jacks only accept incoming audio signal; they do not send audio signal out. If no audio signal is being sent to the headset, no sound will play from the headset.
You may need to purchase a suitable adapter cable in order to connect the TV audio output(s) to the Ear Force X-series headset's transmitter or Audio Input plug.
- Connect the HDMI cable so that the Xbox 360 plays its audio through the TV.
- For X1, adjust the Dashboard > Settings > System > Voice in the Xbox 360 so that the talkback and game sounds are played together (Play Through Speakers). - For X3, X31, X4 and X41, you should set this to Play Through Headset.
XBOX 360 AUDIO PLAYS THROUGH HOME THEATER RECEIVER (except X4 and X41): This is exactly the same as the above, except that you will use the receiver's Headphones output jack to connect to the Audio In on the Ear Force Xbox-compatible headset's Transmitter (X2, X3, X31) or the green Audio Input plug (X1).
- You may need to obtain a shielded audio cable with 1/4" stereo phone plug to 1/8" stereo mini-phone plug ends. The 1/4" phone plug goes to the receiver's Headphones jack, while the 1/8" mini-phone plug goes to the Audio In on the Ear Force Transmit- ter (X2, X3, X31) or Audio Input plug (X1).
- Adjust the Dashboard > Personal Settings in the Xbox 360 so that the talkback and game sounds are played together (Play Through Both). For X3 and X31, you may also set this to Play Through Headset.
Mar 13, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
When i load Conan game my wireless insignia headset stops playing sound. I hear sound any other time
Sounds like there are some settings within the Conan game itself that need to be adjusted to output to a headset, but I have never even HEARD of this game, much less played it, so don't quote me. Just trying to help.
Jan 24, 2009 | Insignia Bluetooth Wireless Headphones...
Chat...yes, actuall game sound...... no
Microsoft:
This should let you hook everything up correctly.
Dec 29, 2008 | Voyetra Turtle Beach Turtle Beach Ear...
Turtle Beach Ear Force X42 Headset Logo
41 people viewed this question
Top Turtle Beach Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Turtle Beach Radio Communication Expert? Answer questions, earn points and help others
