Question about Dryers
Changed ignitor on lg gas dryer and still not getting hot, also cleaned vent
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
There are two more compnents in the circuit the gas valves and the flame sensor
Posted on Dec 01, 2013
aborcass
  • 2651 Answers
SOURCE: Amana ALG443RAW Gas Dryer will not heat up.
you can remove the lower acess panel (2) 5/16 screws along bottom. youll get a good view of workings there. turn on dryer (make sure a heat cycle is selected. you should see the ignitor light with in a few secs. if not unplug the ignitor(small white connector maybe 6inhes back from ignitor itself) and with a meter ck for 110v in that connection when unit is turned on, if you do have 110volts , you hav abad ignitor. ifyou dont get 110 volts you need to check the thermostat(s) located on top of the heater box right above the ignitor, if no continuity you need a new thermo.
Posted on Mar 12, 2008
MNTECH
  • 1543 Answers
SOURCE: front load gas dryer lg model dlg 5988w does not heat
This can obviously be several things, but I would first check the small safety thermostat. On the gas models, there is a small pin sticking out of it which can be pushed back in to reset it. It is located on the heater housing and is only about the size of a dime, with two wires on it. This will trip out easily if your vent was not clean, or is long or restricted in some ways (like using flex ducting)
If you need more help getting to it, let me know and I'll give you more instructions.
Posted on Dec 22, 2008
  • 686 Answers
SOURCE: GE gas dryer gets hot but doesn't dry clothes like it used to
rule number one take everything off of it and never store clothes or anything that can insulate the top it overheats them. It kind of fools all your sensors when you store stuff on top
Posted on Feb 27, 2009
  • 11 Answers
SOURCE: GAS DRYER WON'T HEAT
you need to check to see if the egnitor is comeing on do you see a orange glow in there if not you will need to replace the ignitor
Posted on Mar 24, 2009
smartr10U
  • 1305 Answers
SOURCE: Whirlpool Gas Dryer LGR4634EQ2 is not getting hot,
You may have damaged the glow bar gas ignitor when cleaning the dryer.. it's a ceramic element that gets brittle after it has been used. And if you bang into it with a vacuum hose or tool or whatever while you're cleaning it, it can crack or break....try cycling the dryer and watch the ignitor while it attempt to heat up... if there isn't any glow at all, its the ignitor... it's a simple job to swap it out...
Let me know if that doesn't work...
KEN
Posted on May 09, 2009
Model dlg0452w lg gas dryer is not getting hot
After checking for the obvious, ie; is the gas valve on, the next suspect would be the ignitor. It could be faulty or a safety device such as a blocked vent sensor, may be stopping the ignitor from coming on.
Mar 04, 2013 | Dryers
Lg dlg7188rm - My dryer is not getting hot. When I start a cycle the ignitor comes on (orange glow under dryer) and then gas comes on (blue glow). After about 30 seconds both shut off.
There are two or three sensors in the heat exchanger and another one or two in the fan housing. Check them all for continuity. One in the heat exchanger is resettable
Jul 22, 2017 | LG DLG7188 Gas Dryer
The dryer heats up, but not hot enough to dry the clothes. Have cleaned all the vents and have good air flow.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 16, 2010 | LG DLE5932W Electric Dryer
Dryer wont stay hot
Assuming you have removed the lower access panel (two or three scres all the way at the bottom of the lower front panel) to view the glow plug (ignitor), if you see the ignitor cycle on but the gas does not ignite after the machine initially heated in the beginning of the cycle you will want to replace your gas valve coils. They are the round black things mounted to the top of your gas valve.
This should solve your problem.
Good luck to you!!
Jul 13, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My gas dryer is not getting hot i tried cleaning vent and lint trap
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Bosch Nexxt 500 Plus Dryer
I HAVE A LG GAS DRYER...MODEL NUMBER DLG2532W...THE PROBLEM, WHEN I WAS ATTEMPTING TO RESET THE THERMOSTAT BUTTOM, I ACCIDENTALLY BROKE A PART THAT HAS A COIL AROUND IT WHICH I THINK GETS HOT AND i THINK...
OK i see the other modle #.
Yes the ignitor can be replaced part# 5318EL3001A
If you have to reset the thermal fuse your vent is clogged so be sure to clean the vent all the way to the outside.
Jan 17, 2010 | LG DLE0332 Gas Dryer
Whirlpool Gas Dryer LGR4634EQ2 is not getting hot, I cleaned the vent,I don`t know whats nexts to try?
KEN
May 09, 2009 | Whirlpool Dryers
LG GAS DRYER NOT LIGHTING THE SECOND TIME AFTER COLD START. IGNITOR COMES ON: SENSOR SEES IT IS HOT ENOUGH AND GAS VALVE OPENS. FLAME COMES ON THEN GOES OFF WHEN TEMP IS REACHED BUT WHEN DEMAND FOR THE...
If your vent is clear (strong flow of air at vent outlet outside) then you have a bad gas valve. I have seen this a few times on LG gas dryers. You really only need one of the coils on the gas valve, but they are not available individually. You have to get the entire valve.
Oct 28, 2008 | LG Dryers
Dryers Logo
Top Dryers Experts
