Question about Refrigerators
Ice dispenser lg dispenser sticking
    Champion:
    Habit-Forming:
  • 279 Answers
Seems to be a fairly common problem, i'd be contacting LG for a solution to an obviously wide spread fault in their product. P.S. Complain Loudly, it works.
Posted on Nov 29, 2013
  • Scott Girten
    Scott Girten Nov 29, 2013
    Thanks for the input. I ended up breaking the little "bit" that holds it in place. But it doesn\'t stick anymore, yet it is wobbly. Still trying to get a repairman out here to fix it under the extended warranty.
  • Brian Coughlan Dec 01, 2013
    Stick to your guns mate, it is a common problem from what I have heard. Good Luck.
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: ice dispenser door sticking. has been cleaned but still sticks
See page 38
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 25, 2010
SOURCE: lg lsc27910tt water/ice dispenser sticks in the on
I had the same issue with mine but it is fairly easy to fix, all you need is patience.
1. Press the "Lock" button to ensure nothing is dispensed while performing the fix (worth testing).
2. Remove the grey rubber push from the dispenser carefully (give this part a wash in warm soapy water and leave to dry).
I used a small flat bladed screwdriver but BE CAREFUL not to damage it on removal.
3. Spray a small amount of WD40 (or similar oil) using the straw attachment into the mechanism, especially the spring.
4. Work the mechanism a few times (observe point #1) to ensure it is not sticking.
5. Get a chair.
6. Re-fit the rubber surround following these tips:
a) Starting at the top on the right hand side start gently pushing the rubber lip into the chrome surround.
b) Ensure as you work around the rubber that the legs locate into the holes (use the small screwdriver to guide them in).
c) Work around clockwise using the screwdriver to ease the rubber into the chrome surround.
d) Once in place you can work around again with the handle of the screwdriver putting slightly more pressure on the edge of the rubber (where it meets the metal surround, this will ensure that it locks back under the lip.
***Be patient when refitting the rubber part, it takes a good 15-20 minutes but not doing it right will result in more problems***
Hope this helps!
Posted on Feb 11, 2011
reyjoshua07
  • 1157 Answers
SOURCE: I have a LG LRSC26922TTside-by-side
Hi gener72,
If the lever on you ice dispenser keeps getting stuck when dispensing ice or water, it is often caused by the button attached to the back of the boot has been removed. The easiest way to resolved this is to get the rubber boot in place. Please follow the following steps below on how to disassemble the dispenser.
1. Lock the dispenser using panel button to preclude undesired water/ice while working.
--> Note: the outer bezel (edge of panel) is secured by screws and should not be messed with.
2. The main panel has tabs on all four sides. You can use screwdrivers to pry the panel off ( you can use small to average size).
3. Pry the main panel working through the seam between the bezel and panel.
4. Work your way around starting from the lower left or upper left corner. Each side of the panel has 3 or 4 tabs. Please use a moderate force to pop the tabs loose.
5. Once the panel is loose, you'll need to disconnect the electrical connector at the upper left.
6. The plug comes off and reattaches easily, don't pull on the wires, use the plastic connector itself. Wiggle the panel free.
7. Now, you can get to the back of the boot retention bezel. Carefully push the bezel's securing tabs (x3) through the panel and reattach the rubber boot.
8. You can use needle nose pliers to carefully pull each rubber nib through their applicable hole on the bezel. Now leave the boot/bezel assembly to the side-it's the last step to reassembly. Note how the main panel tabs fit into their receiving slots/flanges.
9. Reattach the electrical connector, snaps right on, and maneuver center of panel into recessed area, around ice chute/water nozzle.
10. Slide the right and bottom sides on first-flanges, not slots for tabs-then align remainder of panel. Using moderate force, pop (punch) the remaining tabs back into their respective slots. The main panel will seat over the bezel. Now align and snap boot/bezel back into place.
Hope it helps.
Thank you for using FixYa.
Posted on Apr 16, 2011
Why does ice dispenser stick?
I dont know what brand you have. But there is a springlever to return the lever to closed posision. Eather the return spring/mechanism is broken. Or has become loose from the fastnerclips holding it in place. I have also seen that ice is the reason for this. Iceing around the very top of the lever.
Feb 17, 2016 | Refrigerators
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
My ice dispenser keep shooting out ice after I moved glass away. The ice comes out in handfuls.
Sounds like there is still ice in the Shute, the unit is design to clear the shute so ice want freeze in the shute. Just touch and allow the shute to clear. The shute doesn't get as cold as the rest is why this happens. There is a micro switch near the handle that might be sticking, but seldom does.
Jan 03, 2015 | LG LFX25960 Bottom Freezer French Door...
LG REFRIGERATOR DISPENSER NOT WORKING
x1 sonny ericcson widows mobile 6.1 version i want to change my language to english
Jan 05, 2014 | LG LSC26905TT Side by Side Refrigerator
How to remove ice dispenser lever on an lg LFX31925ST/00
To replace that you have to take that whole assembly out and you need to install a new Solenoid, new dispenser flap, and a new spring for the flap.
Nov 27, 2013 | Refrigerators
LG refrigerator won't dispense water any more
The water line is freezing in the door due to deteriorated insulation. The only fix I have found to work on my fridge was to defrost the inside door with a blow dryer. Then place a weedeater replacement line (the orange 10" or so size you find at Lowes' or Home Depot) up through the dispenser nozzle, If the line only travels about 3-4 inches up the nozzle, then ice is still in the tube. Blow dry it until you are able to get water to dispense. After the tube is ice-free, place the weedeater line up throuth the dispenser nozzle leaving about 1/8" sticking out. The dispenser will still work with the line stuck in it. The dispenser will probably freeze again in about 8 hours, But all you need to do each time this happens is to pull the weedeater line out, dispense the water to unclog the ice, and place the weedeater line back in the nozzle. I have been using this method for about a week now and it works great. My GE Side-by-side is also 4 years old and this seems to be a problem with all of them. There is a part you can order to fix the problem, but I have heard it may not work.
Mar 21, 2010 | LG LRSC-26922 Side by Side Refrigerator
My side by side refrigerator has an in the door ice and water dispenser that will no longer drop cubes - just crushed ice. What's the deal?
Hello. Here is the fix for your problem. Remove all of the ice and use a blow dryer to dry all of the surfaces well. Then spray the surfaces with PAM no stick cooking spray. This will renew the food safe no stick surfaces in your icemaker and give you months of service. Regards, Joe
Nov 18, 2009 | LG LSC26905TT Side by Side Refrigerator
Stuck Water/Ice Dispenser LG LRSC26920TT
THE ACTUAL BUTTON AND ACTUATOR NEEDS CHANGING AND POSSIBLY THE SWITCH. EARLIER MODELS WERE CHANGED BECAUSE OF THIS.
Aug 18, 2009 | LG LRSC-26922 Side by Side Refrigerator
LG LFX29560 Ice Dispenser
You may need a service call as the ice dispenser flap is operated by a solenoid which is controlled by a small pwb board which is located by the dispenser.
Sgt 48
Nov 30, 2007 | LG LRFC25750 Refrigerator French Door
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
