Question about SonicWALL CDP 4440i (01SSC6303) 600 GB Network Hard Drive
How can I delete and/or reset a SonicWall 4040i CDP device? I have a policy (Agent)that won't delete and I need to get it off the machine. If I have to reset up the machine afterwards that's ok.
2 Suggested Answers
reyjoshua07
  • 1157 Answers
SOURCE: we have a sonicwall cdp
Hi rmshah,
Below are all the steps that you may follow to reset your device.
First, you'll want to be onsite with the device. Hook up a keyboard and monitor; you will come to a login prompt, here type in your login/password. If you do in fact get passed the login prompt then there may be something else that is happening, but a simple restart webui may fix the issue. If not type in reset (will factory default the device) and follow the steps below. Also you'll want a laptop connected via an Ethernet cross over cable to the device.
1. Force the device to restart (you may find that you have to actually hard reboot the device).
2. As you see on the monitor the device come back up just start pressing the esc key.
--> This will trigger the GRUB loader screen
3. Once in the GRUB loader choose safe mode
--> The screen will pull up with configuring the device's ip addres, leave everything default
4. On your laptop configure the IP as 192.168.168.50/24 and the gateway 192.168.168.169
5. Open a browser and go to the gateway IP: 192.168.168.169
--> This should take you to safe mode
6. This should take you to safe mode
--> Start a consistent ping going to the device just to be aware when it will be coming back up.
7. Go back to the keyboard and monitor and let the cli complete until you get the login prompt.
8. Log in using admin/password.
9. From the "SNWLCLI>" type reset
--> This will force the reboot
10. From this point let the device run through its reboot when it's done, from the laptop try accessing it again from a browser (192.168.168.169)
15. You should now have a proper login screen.
16. FIN
If there are any issues at any point please note which step you hit a wall as well as what happened, and open a ticket with Support.
Hope it helps.
Thank you for using FixYa.
Posted on Apr 27, 2011
Port forwarding sonicwall 4060
Check port setting option policy setting
Feb 06, 2014 | SonicWALL pro 4060 security appliance...
Question: I have a sonicwall CDP 1440i. Does it hold a firewall for my server as well serve as a back up device? or do I need an additional external firewall to support the windows operating system?
It will act as a firewall for essentially anything that is "behind" it. As long as your server and PC are connected to it (or a switch/hub that is connected to it) it will act as the firewall.
You don't need anything additional to support your windows machine.
Feb 28, 2011 | SonicWALL CDP 1440i (01SSC6300) Firewall
Sonicwall client won't connect to the internet
The default VPN policy rules prevent LAN access, also known as split-tunneling, since this creates a security risk (the ability of the VPN session to be hijacked or compromised through a covert channel).
If you are not the system admin, you need to talk to your system admin. If you are the system admin, then you need to review the documentation with respect to
http://www.sonicwall.com/us/support/kb.asp?kbsk=policy+allow+lan
Oct 07, 2009 | Sonicwall PRO 3060 NFR (01-ssc-5378)...
Open Port Sonicwall
1. If the port is to be opened for internal people to access the port outside the network, add a firewall allow policy in Firewall -> Access Rules -> LAN->WAN
2. If the port is to be opened for external people to access the port in the network, add a firewall allow policy in Firewall -> Access Rules -> WAN->LAN
Jul 13, 2009 | Sonicwall PRO 3060 NFR (01-ssc-5378)...
How to routing router static ip address and local
Use the Sonicwall configuration wizard..
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
Apr 22, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
SonicWall 5060 will not reset to factory default
hi,
there is notch on sonicwall to reset it.
Mar 07, 2009 | SonicWALL Pro 5060F Firewall
Cannot run RDP, Telnet over MPLS when sonic firewall is connected
You have to give rights to the particular systems. Means enable NAT policys in the sonicwall router.
for details go to the SonicWall Router Manual. Or else you can contact me, I will help you.
Thanks
Sriram.S
Chennai - 4
Feb 26, 2009 | SonicWALL PRO 100 Firewall
Site to Site VPN Link with dynamic dns
Hi Rajmeet, Here is the documentation on the SOnicwall TZ170 the detail configuration can be found on page 211. Please let me know if this helps you and if youhave any other questions. http://www.sonicwall.com/downloads/SonicWALL_SonicOS_Standard_3.1_Administrators_Guide.pdf
Apr 02, 2007 | Sonicwall TZ 170 NFR (01-ssc-5564)...
SonicWALL CDP 4440i (01SSC6303) 600 GB Network Hard Drive Logo
565 people viewed this question
Top SonicWALL Computers & Internet Experts
Raymond Ramirez
Raymond Ramirez
Frank Zabroski
Frank Zabroski
Steve P
Steve P
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
