Question about Soltek SL-85DRC Motherboard
Suddenly no video, monitor ok, tried replacing video card with working unit, still no video, harddrive and optical drives working.
    Problem Solver:
  • 9 Answers
Do you have video with onboard video card??if so try setting up the bios to display your agp or pcie card first.
Posted on May 08, 2009
( Dell xps m1530 laptop ) Monitor blank, powers up but screen won't come on.
It ISN'T the LCD screen. Since you diagnosed with an external VGA monitor, you now know the problem is the laptop.
(When you connect an external VGA monitor to a laptop, you are bypassing the Video Cable, and LCD screen. You are connected directly to the laptop )
The basic Windows files aren't being found. The boot files. This may mean a bad Harddrive.
Do you have the Restoration CD Disk? Laptop on insert it into the optical drive tray, close the tray.
When asked choose - Repair. (Non-Destructive Installation)
If a checkdisk is done, you have bad sectors on the harddrive.
There IS a special procedure in replacing a harddrive.
[ More information on Harddrives,
http://computer.howstuffworks.com/hard-disk.htm ]
Regards,
joecoolvette
Feb 26, 2012 | Dell XPS M1530 Laptop
Veriton 7600gt why no output video is going to the monitor
Hi mellomoris,
Sometimes we wonder why there is no video output on the monitor or we just get "no signal" display. This may happen if the vga cable or the cable that connects from the monitor to the system unit (tower) is loose. It also happens when the monitor has power but the system unit is not turned on. In this case, you can try to do the steps below if it can resolve the issue. (This works with others, I hope it'll work on yours.)
- Sheck the cables and connections to make sure that they're securely plugged in.
- If you have another monitor, please try to plug it in.
- Try to check if there is activity on your harddrive or fan, issue might not be with the monitor but with the system unit.
Hope this helps.
May 27, 2011 | Acer Veriton 7600GT PC Desktop
I have no video output from my computer to my monitor. I was playing a video game (Guild Wars) and all of the sudden my computer shut off. I was unable to receive video output from there on out. The...
Test the PSU if the units fan is not working the power supply unit is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electric extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
May 03, 2011 | Abit AS8-V (MBABITAS8V) Motherboard
Monitor is OK but when turned on the screen is black with a little square that has a message "Dell, No input signal". How can you repair this.
Monitor is not getting signal - picture from pc. Did this ever work or is this new pc? Is PC running? Does it do more than just blow fans? Like hard drive spinning up etc.. Check your video cable connections. Turn off monitor and pc first. Remove and re plug both ends of the video cable. Look for bent pins in plug ends before re pluging. Try a different cable if possible. If not fixed, you may need a new video card. Is this a pc that was working and suddenly failed? Either the pc is not running, or the video card is failed.
Nov 09, 2010 | Computers & Internet
Removal of eMachine M6410 optical drive
There are two small screws that the monitor cable would screw into, these have to be removed (7mm i believe) to be able to remove the base. The optical drive will typically pull out of the side after a screw has been removed and latch has been opened. I wouldn't go as far as removing the entire base.
Dec 08, 2008 | E-Machines M5305 Notebook
Computer powers on but does not boot - no videe output.
replace the ram if its bad you wont get any video..if that does not work it is the CPU..
Nov 17, 2008 | HP Pavilion 525c (DD210AR#ABA) PC Desktop
NO DISPLAY
Hi m_o_redz,
If you are using the on-board (integrated video), S3 Graphics Chrome9 HC Integrated Graphics core. Than check you're video cable, video cable connection. Try another monitor. If all check out ok than the MSI integrated video is defective. Suggest you install a PCI-E video card.
If you are using a PCI-E card, try removing it. Clean the copper contacts using a cotton swab & alcohol. (Let it dry) Than reseat the PCI-E card.
Try booting again.
Good Luck!
Mike
Apr 22, 2008 | MSI P4M900M-L Motherboard
Computer won't boot
ok, try another monitor now.
Oct 04, 2007 | E-Machines eMachines Desktop PC
Motherboard Problem
Were all these working fine together before or did you just replace something? Did you try connecting the monitor to another PC? Try the pc on another monitor which works. try unplugging the video card and plugging it back in. try without the memory, it should post and beep looking for the memory. try without the harddrive.
Apr 02, 2007 | Chaintech Slot 1 CT-6ATA2 Motherboard
No power to monitor
Is the Bios rom set to the on board settings for the video driver?? Did you allocate enough ram for your video driver in the Bios rom?? If all thats ok then the on board video driver is bad or not configured properly. Try disableling the On board video driver and stick a video driver card in and try and see if the monitors working correctly. Good Luck
Jun 13, 2006 | Samtron 76df 17" CRT Monitor
Soltek SL-85DRC Motherboard Logo
101 people viewed this question
Top Soltek Computers & Internet Experts
Steven Burn
Steven Burn
Iqbal Husain
Iqbal Husain
David
David
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
