Question about EliteGroup K7S5A Pro Motherboard
Want to improve speed of p.c
HI, WALTER HERE, LOOKING FOR SOME ADVICE, ON MY K7S5A MOTHERBOARD I HAVE 512+256 MB SD133 RAM, THERE ARE 2 OTHER SLOTS ON THE MOTHERBOARD WHICH SAY DDR, WHAT SPEED IS THE DDR RAM AND HOW MUCH CAN BE FITTED. ANY IDEA.
    Sergeant:
  • 239 Answers
If ur motherboard has 2 extra RAM slots...den u can add 2 more ddr rams...They come in 512,1gb,2gb catagories...
Posted on May 08, 2009
Hello Sir, I had 512 MB 533 MHz DDR2 RAM(Dynet). Now I have bought 1 GB 667 MHz DDR2 RAM(Dynet). My system has 2 slots. In one slot, I have 512 MB RAM and in another slot, I installed 1 GB RAM that I have...
The Intel D102GGC2 uses a Dual Channel Memory Architecture meaning that both slots need to be running at the same speeds. I would suggest getting another 667 MHz RAM card and installing it along side your current one, just as I reminder this motherboard only supports 2GB RAM Max so don't get one that is above 1GB.
Mar 28, 2011 | Intel D102GGC2 Motherboard
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Hi... Can you help me in the software of my pc the Video Controller (VGA Compatible) It was gone when I was reformat the PC. Motherboard Manufacturer: Company Name Micro-Star International Motherboard...
Field Value North Bridge Properties North Bridge SiS 661FX Revision 11 Memory Timings CAS Latency (CL) 2.5T RAS To CAS Delay (tRCD) 3T RAS Precharge (tRP) 3T RAS Active Time (tRAS) 5T Memory Slots DRAM Slot #1 256 MB (DDR SDRAM) DRAM Slot #2 512 MB (DDR SDRAM) Integrated Graphics Controller Graphics Controller Type SiS 330 Mirage Graphics Controller Status Enabled Graphics Frame Buffer Size 32 MB AGP Controller AGP Version 3.05 AGP Status Enabled AGP Device SiS 330 Mirage Integrated AGP Aperture Size 64 MB Supported AGP Speeds 1x, 2x, 4x, 8x Current AGP Speed 8x Fast-Write Not Supported Side Band Addressing Supported, Enabled Chipset Manufacturer Company Name Silicon Integrated Systems Corporation
Jul 16, 2010 | Microsoft Windows XP Professional SP2
Just bought 2 1GB PNY dual Chanel memory modules for my Computer Make: HP Pavilion 061 Computer Model: RJ181AA-ABA a1600n Currently has Memory: 4 slots: 512 MB, 512 MB, empty, empty QUESTION: which slots...
Start off by putting the first memory module in DIMM slot 0 this is the slot nearest the processor. DIMM slot 1 is the slost after DIMM 0.
Regards.
Jun 28, 2010 | HP Computers & Internet
Would A 1GB PC3200 run in the K7s5a alone.
According to the specs the max amount of ram is 1 GB and max speed is pc2100 so a pc3200 would not run on it unless the board was able to clock the speed down of that single stick of ram.
I was not able to find the max amount of ram per slot on a quick search but most likely it would be 512 mb per slot for a max of 1 GB between the two DDR slots.
at Newegg you can find DDR 266 1 GB kits (2 x 512mb) which would get you the 1 GB of ram.
Jan 08, 2010 | EliteGroup K7S5A Pro Motherboard
Wont boot after disconnect CD Rom
1. Power off your computer
2. Open the case
3. Remove the RAM from the slots.
4. Wipe the ram pins with cloth or best is eraser to maximize contact
5. Interchange the RAMs if you have 2
Now turn ON the computer.
Jan 05, 2010 | EliteGroup K7S5A Pro Motherboard
Ram compatabilty for k7s5a motherboardand can I run a 1gig of ram with this board
A really unique MB since Each DIMM slot can accommodate DIMMs up to 512 MB in size, although both DDR and SD-RAM are supported, but any one at time, i.e. one among consisting of a bank of 2 DIMM slots(blue pair & black pair having the pairs 2 slots each) for DDR or 2 DIMM slots for DDR or SDR memory cannot be used at the same time. Thus the board supports either 1 GB of PC133 SDRAM, or 1 GB of DDR sdRAM, but not both at the same time.
I hope you got the Catch 22 here !! Nice low costs for doing simple work?
but it's a Catch 22 situation{either choose the Devil or Hell !) ................. sodeep
Oct 25, 2009 | EliteGroup Computers & Internet
I am working on a friends computer and he has a k7s5a pro Mobo..
Maybe it requires DDR2 or DDR3 RAM. As it is there are only 2 DIMM slots, so check the FSB. If it does not match asper the manual then you might need to replace the RAM with the appropriate one....sodeep
Mar 19, 2009 | EliteGroup K7S5A Pro Motherboard
I Have a Motherboard K7S5A xp 1800 I would like to now if it will hold 2x1gb of ram for a total of 2gb of ram Please Help Thank You
No, Maximum memory on this board is 1GB total. There are four memory expansion slots (places to put memory sticks.)
Mar 14, 2009 | EliteGroup K7S5A Pro Motherboard
Regarding upgradation of SDRAM
hi dear
there is always speed mismatch problem occur when we use low processor & high ram
so try to use 256 ram
also try to use 1 slot of 256 ram & 2 slots of 128 ram diffrently
& compare the speed
hope it will help to u
Jul 08, 2008 | ASUS SiS Chipset CUSI-FX Motherboard
EliteGroup K7S5A Pro Motherboard Logo
175 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
