Question about Brother MFC-8460N Laser Printer
Reset toner mfc-9340
How do I completely use all the toner in the TN-225 cartridges or reset the message?
SOURCE: MFC 8460N giving Toner Life End message
I just solved my own problem. Try it for yours. I had been using several compatible toners for the MFC-8460N with no problems until today, as I posted earlier. On a hunch, I went to the local office supply store and purchased one original Brothers TN550 toner and put it into the printer and closed the cover. Everything clicked. Toner End Life message gone. I then took that Brother toner out and put the compatible one back in and still everything was fine. Am keeping the original Brother toner as a "kickstarter" if it happens again.
Posted on Mar 19, 2008
SOURCE: HELP! Brother MFC-8460 "Toner Life End" won't clear
The problem with a new toner cartridge that will not signal the printer that it has been changed has to do with a gear positioned wrong on the new or rebuilt cartridge... we had 3 factory brand new toners that would not clear the replace the toner message... I finally found the following link that came from a toner company that sells refills that tells how to reposition the gear to let the machine know a new cartridge has been installed. I did the proceedure on pages 5 & 6 having to reposition the gear and all cartidges then worked flawless... it works.
http://www.castleink.com/265/cartridge/TN580.pdf
Posted on Sep 23, 2008
the kowalski
  • 86 Answers
SOURCE: Brother 5250DN Printer Toner light
Try resetting the toner counter manually;  * Turn off the printer and open the front cover * Press and hold the Go-button down * Turn on the machine while still holding button down, when all three LEDs are lit, release Go-button * Press the Go-button twice, and all three LEDs should be lit again. * Press the Go-button five times (six times if you have the High Yield toner) * Close the front cover and the toner counter should be resetted.
Posted on Jun 02, 2009
  • 4 Answers
SOURCE: how to get ride of Toner life end message
You could try resetting the toner cartridge settings. OPen the machines front door where you would replace the cartridges. On the top panel you will see a "clear/back" button. Press it and on the display you will see a reset menu come up. Arrow to each one and hit the OK button. Press "1" to reset. Once you have gone through all close the front door of the machine and press stop to bring the display back to normal.
Hope this helps.
Posted on Oct 21, 2009
  • 13433 Answers
SOURCE: Message on Brother MFC
Open door
press Clear/Back key
press *00
press OK
Do not choose anything for drum replacement. when drum replacement menu comes up, just press the * and then 00, then just press OK.
that should clear the error message, the printer has a toner life counter that needs to be reset.
Posted on Oct 04, 2010
I replaced the fuser. How do I reset the fuser?
Replace Fuser Message and Reset Brother MFC 8480DN ...
? 0:46
www.youtube.com/watch?v=quGzXnDsZQA
Jun 27, 2012 - Uploaded by Kevin Gumpp Instructions on how to reset and replace the fuser on a BrotherMFC 8480 ... V?deo Recarga Toner Brother TN 580 ' MFC 8860DN ' DCP 8060 ...
Oct 01, 2015 | Brother Printer MFC L8850CDW Wireless...
How do you reset counter on Toner for TN-360
No, If you use a refill in your recent toner cartridge you need to reset the toner, if you use a new toner cartridge, no need to reset.
Aug 28, 2014 | Brother MFC 7840W Printer
I get a message to replace toner, i replaced and still get the messag
You may want to try the following steps:
  • Step 1 - First turn on your printer: Brother MFC 9840CDW.
  • Step 2 - Push the button on the front of the printer to open the cartridge cover or the front panel of the printer where you can access the toner cartridges. However, do not remove the toner cartridges (Brother TN-115).
  • Step 3 - Push the Clear/Back button and hold still to bring up a reset menu. There are 8 different toner functions ( two Black, two Cyan , two Magenta, and two Yellow).
  • Step 4 - For each of the eight functions in turn, push the O.K. button and then push it again to indicate 'Reset'. After a few seconds, it will say 'Accepted' and will then display a message that the cover is open.
  • Step 5 - Repeat the steps 3 and 4 for each of the other eight toner functions as needed.
  • Step 6 - Once your finished, close the front cover of your printer so the status bar will be reset to normal with no error message.
  • Also, you may want to clean the corona wires for each toner. Clean the corona wire inside the drum unit by gently sliding the green tab from left to right and right to left several times.
Nov 29, 2013 | Brother MFC-9840CDW Laser Printer
Error message "put the black toner cartridge back in"
I got this same error message on a newly acquired Brother DCP-7040 that I purchased used off of ebay.
As I was troubleshooting this unit (that I bought untested off of ebay - hey gambling has paid off handsomely for me many times before!), this error message kept popping up.
I checked the COUNTERS (page & Drum life) and found out that the DRUM had 0% life left. BUT, the reason it showed ZERO was because this unit did not have any drum! The toner cartridge (TN-360) needs to sit WITHIN the drum (DR-360) on this DCP-7040 unit, as well as in models DCP-7030, MFC-7340, MFC-7345C, and MFC-7440N.
So perhaps some of these "put the black toner cartridge back in" problems could be related to the DRUM (or lack thereof). A possible tipoff (since the toner cartridge actually does slide into the unit much like other units that do not use Brother's DRUM carrier) seems to be the relative ease with which the toner cartridge slides into the DCP-7040 and really doesn't seem to "lock" into position real firmly.
DCP-7040 USER GUIDES: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&type2=-1&prod=dcp7040_us_as&c=us&lang=en&flang=all
Apr 23, 2012 | Brother MFC-7340 All-In-One Laser Printer
I have a Brother fax and copy machine and have just replaced toner with a brother TN 350 cartridge and still getting message that toner is low
You didn't include the model, but here are instructions for the Fax-2820; it should work for any of the models that use the TN-350 toner:
  1. With the power on, open the front cover.
  2. Press the Options key. The display will read "Change Drum?"
  3. Press Start.
  4. Press 1 0.
  5. The display reads "Accepted" for about 2 seconds, then change to "Cover Open."
  6. Close cover. The "Replace toner" message should be cleared.
Normally, inserting a new cartridge (with the power on) will reset the toner counter, and you won't have to do any of this.
Dec 21, 2009 | Brother IntelliFax-2820 Laser Fax
Brother MCF-7340 first time toner replacement
If this model comes with the drum separately of the cartridge, only replace the cartridge. There's no need to change it every time. until prints start to get lines or dots. Don't expose the drum to light too much.
Jul 30, 2009 | Brother MFC-7340 All-In-One Laser Printer
Brother mfc 6800 all in one
dear friends
Cheap Brother TN250 toner cartridges and Brother TN-250 supplies from ConcordSupplies.com http://www.concordsupplies.com/brother-tn250-toner-cartridge-brother-tn-250/33092.html
<a href="http://concordsupplies.com">http://concordsupplies.com</a>
May 18, 2008 | Brother MFC 6800 All-In-One Laser Printer
Mfc-7220 replaced starter cartridge, new Brother one gives error no cartridge
there is a new toner detect sensor left front upper inside of printer, when a new toner is put in reset lever on cart hits sensor then fall back to front of cart, remove gear asst and put lever in new position, 3/4 the way back. reinsert toner into drum and insert.
Nov 03, 2007 | Brother MFC-7220 All-In-One Laser Printer
Brother MFC-240C
try unplugging the machine wait a few minutes and retry!
Jun 20, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC-8460N Laser Printer Logo
164 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
