Question about Toys
Polar express lantern snow globe battery replacement
3 Suggested Answers
  • 59 Answers
SOURCE: polar express lantern stoped working how do i get the battery changed
The battery is not replaceable according to the manufacturer.
Sorry!
Posted on Dec 02, 2012
e79r84p51
  • 3 Answers
It's possible but you have to use a razor saw and cut the top off the lantern. Go around the top and cut only through the plastic. Don't try to saw a single cut all the way through the whole top at once. You can then replace the 2 CR1220 batteries inside. I added some tabs to the top with scrap plastic and drilled holes so the handle would hold everything in place.
Posted on Dec 16, 2016
What is the correct globe for the Eveready Model AV425 7 Watt U Tube lantern?
Hi, Check and clean the contacts from the batteries to the lamp.
There maybe corrosion in there. Also the switch maybe bad. Clean and retry. Use a bit of emery paper to clean contacts. good luck.
Jan 12, 2015 | Eveready Camping, Backpacking & Hiking
Polar express lantern stoped working how do i get the battery changed
Dec 02, 2012 | Toys
My 6 foot inflatable snow globe won't blow the snow inside,the fans and motor are working just fine it just wont blow the snow it just sits in the bottom...
Maybe the problem is condensation. The globe gets all fogged up and the snow pellets start sticking to the plastic and it just looks like a mess. Temperature might be less of a concern where you are, but it is something to consider. I had briefly thought of putting something like a hair dryer in line with the main fan to keep the inside temperature up. But it turned out to be more of a problem than I wanted to deal with. Good luck though!
Dec 20, 2010 | Gemmy Inflatable Polar Bear on Motorcycle
Hallmark polar express conductor snow globe, how do you change battery
I have very successfully replaced my batteries by removing the top and the epoxy in it back on. I would consider doing it. 734bd5f6-c137-48ff-bbc0-e61ade22b916.jpg
Dec 11, 2010 | Toys
Replacing batteries on Energizer Hard Case Lantern
If you have the Energizer Hard Case Lantern TUF4D1, simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Jul 05, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
My gemmy inflatable snowglobes ( 2) are not blowing snow this year. The fans work fine- the globes inflate- but the snow just sits in the bottom of the globe. If I shake the globes the snow works for a few...
I am having the same problem the globe is inflated and the characters are rotating but no snow its all bunched up on the bottom and doesnt blow all the way up if you get an answer from gemmy its a miracle. if you solve it please contact me at marriageishell@aol.com thanks.
Dec 12, 2009 | Gemmy Toys
Replacement globe for a 1960's thermos portable gasoline lantern
Hard find.........www.ronfoo.com
This guy may be able to point you in the right direction being an antique/collector's item.
GGBMDB
Oct 28, 2008 | Camping, Backpacking & Hiking
Coleman lantern fan am/fm radio
This lantern/fan/radio combination does not use/accept batteries. It is recharged using the black A/C adapter provided with the lantern. I hope you received the adapter with the lantern when you bought it @ the garage sale? You plug the adapter into the little circular opening just above the round spotlight on the lantern. Hope this helps!
Aug 22, 2008 | Coleman Lantern Fan Radio (841.321) AM/FM
Rechargeable Camping Lantern
you need to coldsolder the pc board.
Apr 09, 2008 | Dryers
Toys Logo
688 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
