Question about HP iPAQ hw6510 Mobile Messenger Smartphone
GPS on hp6515
Hi guys
Ive got the above model which ive installed tomtom navigation 6 (maps on sd)
when i start up there is'nt a problem but then after 1 hour the screen flashes and you can see gps navigation(default hp programme ) and then the start menu tries to load(windows icon in middle of screen) Then the whole unit freeses up completely freeses up - I f I leave it though for another hour sometimes it comes back - howver you can still notice that the gps is running in the background (still receive spoken directions/speed camera warnings
The only other way is to exit from the unit by using the top switch, reboot and then stop the gps navigation prompt via the runing programmes page and then re-boot into tomtom- Ive contacted tomtom who cant seem to resolve the issue from their side and who suggest that hp are best placed to resolve this annoying occurance
Regards
Adrian brown
  • 85 Answers
Firstly the GPS on this model is not a standard GPS, it uses AGPS which requires an update to be performed either ever 2 or 10 days, depending on the rom version of the ipaq.
This annoying thing normaly occurs when the update is out of date. On the home screen, in the bottom right hand corner, you will see a circular icon with grid lines and a dot in it. If it is blue the update is good, grey means it is out of date.
There are several ways to update this, the easiest being having your iPaq connected to active sync, then tapping the above icon, tapping download now.
However, if you have recently performed a soft reset, you will need to perform a hard reset to resolve the issue (this will wipe all your data so back up first!!!) Then re-install tomtom and try again.
Posted on Jun 20, 2008
SOURCE:
HTC TOUCH CRUISE mobile:
see the manual of your gps sytem
Jul 24, 2008 | Tomtom GO 920 GPS Receiver
Tip
Red X flashing when starting up TomTom
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card
  • Connect the device to your computer.
  • Open the TomTom Home application.
  • Click on 'Update My Device'.
This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
on Jun 14, 2009 | Tomtom One XL GPS Receiver
I just purchased a Tom Tom XL 335 SE, but when you turn the volume up above 85% there is no sound. I exchanged the gps for a new one and the new one does the same thing. Any ideas for how I can get it to...
This was is a known bug to TomTom. The suggested solution is to update to the newest software version. The Download Page Here is where you can get the newest version.
(1) Ensure that you have the latest version of TomTom HOME installed
(2) Backup your navigation device by clicking Backup and restore in HOME
(3) Make sure you have enough space on your memory card or internal memory.
(4) Transfer your favourites to your new map
Downloading and installing your map
(5) Select your navigation device:
Before you disconnect
(6) If you have a speed camera subscription, install your TomTom speed cameras.
Select your new map
(7) If you have more than one map installed on your device, select the new map. On your navigation device, tap Manage maps in the Preferences menu and then tap Switch map.
Mar 12, 2011 | GPS
What is the requirement sd card to download tom tom navigator
Min System Requirements for Tom Tom Navigator are as below:-
Windows 2000, XP, Vista, or Windows 7 (newest servicepacks required)
Pentium III or higher
256 MB RAM, 512 recommended
Internet connection (Broadband - DSL/cable/LAN) for downloading updates, maps or services
The TomTom HOME software is a 20MB download requiring 50MB of disk space when installed
For NAVIGATOR 6 devices, the system requirements for Windows are:
Windows XP, 2000, Vista or Windows 7 (newest servicepacks required)
500 MHz processor or better
128 MB RAM
Internet connection (preferably broadband - DSL/Cable/LAN) for downloading updates maps or services
Internet Explorer version 5.0 or higher
Please note that the following MOBILE & NAVIGATOR versions are not supported by TomTom HOME:
MOBILE
MOBILE 5
NAVIGATOR 1
NAVIGATOR 2
NAVIGATOR 3
NAVIGATOR 2004
NAVIGATOR 5
Dec 19, 2010 | Computers & Internet
Invalid version of TomTom application installed on your TomTom device. To use HOME you need to install the correct version of the TomTom application''
For users with Smartphones, Pocket PCs etc using TomTom Navigator 6,7 or 8. Please do the following...
If you have installed the application TomTom Navigator to your SD/MMC Storage card as supposed to your device storage then you need to uninstall TomTom Navigator. This will not affect your maps etc. These stay on your stotage card. After you have unistalled TomTom Navigator. Reinstall it but this time when asked where you wish to install it select Device, do NOT install it to the storage card.
Once done lauch TomTom Navigator and follow the setup instructions. Enable Map Share if you you want to use it. When you are finished with configuring the setup close TomTom. Connect your device to your PC/Laptop and open TomTom Home. The error message should now be gone plus if you were not recieving map updates and map shares etc you will now.
Nov 20, 2009 | GPS
Tomtom 1 v3 wont read new sd card help
Take special not of part 6
1. Remove the SD card
The card needs to be formatted properly first that's all,
2. formatting is better done in a card reader.
3. Right click on it and select format select FAT32 as the files system
4. Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
5. You now ned to select your tom tom which will also show as a drive.
6. In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
7. Then just copy ALL the files from the tom tom to your sd card
8. DO NOT USE CUT AND PASTE !
9. Once all the files are on switch off the tom tom and insert the sd card
It should now work
Sep 15, 2009 | Tomtom ONE XL GPS
Loading TomTom one maps for northern France
First you need to have the relivent map on your SD card. Typicly this will be the Tomtom Map " Western Europe ". When you purchase maps from TomTom you also get an activation code and instructions telling you how to install the map onto your device and how to authorise it using the code that comes with it.
Before doing anything ... BACK-UP your existing data ( the whole SD card ) onto your computer . This will ensure that if any update is unsuccesful you can at least return things to the way they were before you tried to update.
There are several ways to obtain maps
  • buy a new TOMTOM SD card for your tomtom that containes the required maps. Make sure it comes with the authorisation card.
  • buy a CD from TomTom or a TomTom authorised dealer . This CD will contain the required map so you can download the required map to your own SD card. Make sure it comes with the authorisation code AND instructions.
  • buy the required map from TomTom online . You can download it to your PC , then copy it onto your SD card later. It will come with some instructions and authorisation code ...... You can also use "TomTom Home" software and this does most of the job of downloading maps ( that you buy from tomtom ) and puts them onto your sd card for you in a semi-automatic way . If you go down this route then its best to be sure you have the latest version of TomTom home software by going to the TomTom website first.
With ANY of the above methods------- BACK UP your existing SD card first . In fact ... make a BACK UP NOW , then if anything goes wrong at any time , you can at least revert back to your backup.
Good Luck
Jan 18, 2009 | Tomtom One Europe v2 GPS Receiver
Help
Hi, i did the same thing with my tom tom 300 go, i fixed it by borrowing my mothers sd card from her tom tom 710, i put the card into a card reader and copied the hole card to my computer then copied it back onto my sd card out of my tomtom then put in mine and bingo it worked with all the fetchers that her tom tom had and the updated maps it still said it was a 300 but had the 710 stuff try this it worked for me it should work for you.
Mar 08, 2008 | Tomtom GO 300 GPS Receiver
Lost my activation code
Call TomTom support 1-866-486-6866 (www.tomtom.com) and they will help you pretty quickly with that problem.
Nov 29, 2007 | Tomtom ONE GPS Receiver
HP iPAQ hw6510 Mobile Messenger Smartphone Logo
153 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
