Door Seal Replacement.
Hi, is it an easy job to change a Hotpoint WM62 door seal?
    President:
  • 1,489 Answers
Not a big deal. Give it a try!
Posted on May 08, 2009
Hotpoint aquarius 1000 WM62 leaks from the bottom at the front of the machine towards the end of the cycle. How do I fix this?
Carefully exmine the door seal for a hole or split, remove the clamp ring round front and pull seal of front of cabinet and check it carefully, if no sign of leak from seal, then it is going to be leaking from the plastic drum front of washer.
This will entail removing tye front panel.
Hope this helps.
Jan 17, 2010 | Washing Machines
Hotpoint WF340 washer machine. I have noticed the rubber seal just as you open the door has gathered water and now begins to smell, can you tell be if i can replace it, how much the part would be and how...
the door seal can be changed from the out side of the washer but its a devel of a job to do
its held on by 2 spring clips, one around the outer door seal you hook this off then you fold the seal inside out and the other spring is on the inner drum
to fit a new door seal first turn it inside out and clip the sealing spring over the inner drum, them pull the door seal over the outer caseing and put the spring round that bit,,,
net easy i sead!!!
if i were you if the old door seal is not leaking leave it be,,, just clean it up with a drop of bleach it should have drain holes in it have a look to see of there not blocked up, when ever its washing it should get flushed out every wash,, unless its blocked up,,,
Oct 26, 2009 | Washing Machines
Hole in door gasket of a Hotpoint 9901w washer dryer.
It is quite involved to change the seal, as requires a partial strip down, if the hole is not very big, then you can do a fairly good repair using a bicycle punture repair kit..
Remove the plastic clip that holds the clamp ring on the front of the washer seal at the top, remove the clamp ring, take note how it is fitted, then pull seal off front of washer, and fit patch on underside of seal, refit seal and clamp,and job done!!!!
Plz rate my solution.
Thanks.
Jan 25, 2009 | Washing Machines
Door seal
remove the front retainer, wire/spring affair.
slip the front of the seal off.
seal is held onto drum by a large sprung retainer, remove this by levering it off with a screwdriver.
put the new seal in and it's a case of putting the retainers back. the inside can be made easier with the application of some soapy water in the seals groove that the inner retainer sits in.
good luck as it can be easy or difficult doing the same job.
Dec 23, 2008 | Hotpoint Ultima WD72 Front Load...
How to replace door seal of Hotpoint WF860 washing machine
Hi, This is a very simple and straight forward job. First turn off the washing machine and remove the plug from the wall and earth the plug on the cabinet of the machine to remove any residule current in the machine. Remove the top of the machine with the screws at the rear of the machine. You can now look in the top? Open the door and take off outer door seal clip ( look and you will see how ) If it is a plastic clip it will have a small cut out in the side for a small screwdriver to be put in a pushed open. It could even be a small spring that is laying in side the small lip of the door seal. You could now attempt the removal of the door seal if you can see the inner clamp to get a long screwdriver onto the screw! If not now remove the soap drawer. Remove screws from around the soap drawer and slide the facia to the right and it should all be off.. Then you can remove the three screws that hold the front on along the top and the same along the bottom edge of the front panel. This then will allow you to take off the front panel and have better access to the door seal. Then once you have replaced the door seal you just need to replace as you took off..
Good luck................
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Door seal has two holes in it and leaking
Hi.
You need to remove the front console panel and then the front panel to change the door seal.
Pull the dispenser drawer out and remove the screws.
Slide the console panel to the right and support it while you remove the rfont panel.
Change the seal, and reassemble in reverse order.
Good luck.
Nov 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
How do i change the door seal on hotpoint ultima wf860
hi this is a ten minute job take your lid off your machine and then take you soap drawer out there are 2 screws in the behind the soap drawer undo these unclip the top board as you look in side the machine and put the fasia in a safe place now you will have two screws on the top of machine from where you just took the facia off and 2 underneath the bottom by removing the plastic kicker plate undo these and open the door to the right you will see 2 screws that hold the interlock in remove these and then remove the band around the door seal normally metal with spring now lift the front of the machine upwards and that will be the front off now unclip the door seal from inside and check for holes if ok soak in bleach over night and rinse in the morning try some descaler to remove and limescale when you use machine again total 10 screws to undo really easy goodluck and please leave feedback
Sep 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wma46 door lock
make sure door seal is fitted correctly to the cabinet. you may find that all that is required is to push the door harder than usual till the seal beds in
Mar 29, 2008 | Hotpoint WMA46 Front Load Washer
Hi hotpoint wm62 door locked
Try "end of cycle" button & wait for 2 minutes before you try the door..........
Jan 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
236 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
