Question about Cobra Radio Communications
Cobra cx102a Turn off roger beep
How do i turn off the beeping from cobra microtalk 2 way radio
  1. Press the menu button to scroll through the features.
  2. When it says "set roger beep on/off" press the up or down arrow to turn the roger beep off.
  3. Now press the talk button to return to stand by.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 14, 2011 | Cobra Electronics microTALK® PR 3850 WX ...
What does vox and rog. Stand for on the cobra microtalk
VOX is the abbreviation for Voice activated transmission, and ROG is likely the abbreviation for Roger Beep, which is a small beep or series of beeps at the end of a transmission that alerts the other person you are talking too that your transmission has ended. this is mostly used when signals are noisy, as the beeps are a sure sign that you have finished your transmission.
Aug 29, 2011 | Cobra MicroTalk PR 4200-2 WX (22 Channels)...
Can we turn off the beeps after transmitting. Sometimes I don't want that noise.
Some Cobra radios have a selectable "Roger Beep" while others do not. Without the model number I can't tell if yours can be switched off or not, but if the option is not mentioned in your operating instructions the beep is permanently ON.
Dec 07, 2010 | Cobra 22 CHANNEL 2-WAY RADIOS
Does a cb have a effect on auto ignition?
The Cobra 29 LTD has no effects from the factory. Commonly if an aftermarket effect has been installed it may act erratically on startup, for example roger beeps on the 29 tend to activate when you turn the unit on.
Aug 11, 2010 | Cobra 29 LTD CB Radio
Get rid of roger beep
This seems to be true for Uniden and Motorola 2-way radios, might work for your cobras;
turn off the radio
push down on the channle up button
while holding the button, turn on the radio
once the radio is completely booted up, you can release the ch up button
Let me know if it works either way!
Thanks,
Mike
May 17, 2010 | Cobra Electronics CXT85 Two Way Radio
Want to disconnect the bleep out of my cobra 148 gtl dx
open the cover speaker side and look inside the radio look for a small square board that the previous owner might have had installed that would be the roger beep. the white wire is the audio wire. and usualy is soldered to the audio pin if you remove this wire the beep will be disconnected. but you will most likely want to remove the whole system but it will still work if you dont which would be best. just cut the white wire.
Feb 04, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Want to disconnect the bleep altogether on my cobra 148 gtldx
If this is a stock cobra 148 gtl 40 channel am plus side band, they don't to my knowledge come with a built in r beep. Some roger beeps are instaleed through the transmit circuit on the mic, so if not in the know Don't try to fix it.Some microphones have a beep built in. I used to install beeps on these radios using the pa/cb switch to turn them on. also try the nb switch or the swr/rf switch.
How do you go to silent mode?
There are two different kinds of beeps you can control, the "roger" beep and the "button" beeps. Below is an excerpt from the owners manual explaining the simple procedure.
“Roger” Beeps/Talk Confirmation Tone
When you turn this feature On, your two-way radio transmits a unique tone when
you finish transmitting. It’s like saying “Roger” or “Over” and lets others know
you have finished talking. If the person you are talking to does not hear the talk
confirmation tone, you can enable it by pressing and holding + (plus) as you turn On
your radio. Now, whenever you release the PTT, you let your friends know you have
finished talking by transmitting a “Roger” Beep tone. “Roger” Beeps will be
disabled as the Default Setting.
Note: To toggle the Talk Confirmation Tone feature, turn your radio Off and then
back On while pressing and holding + (plus) .
Button Beeps
Every time you press a button on the front of your radio, it beeps unless you turn
Button Beeps Off. To turn Button Beeps Off, turn your radio On while you press - (minus) and
hold . To turn Button Beeps back On, turn the radio Off and then back On again
while you press and hold the - (minus) . On is the Default setting.
Here is a link to the manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T7100_User_Manual_E.pdf
17
Nov 28, 2008 | Motorola T7100 2-Way Radio
Radio Communications Logo
77 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
