Question about iLO V27DMBX Television
Need 3 digit remote contro code for DW39F1Y1 Westinghouse TV
Using Channel Master DVR which requires a three digit TV code but Westinghouse isn't among the listed brands.
2 Suggested Answers
SOURCE:
SOURCE: onn tv lost channel list after powercut. no remote
although initialy I was able to operate tv with sky remote, after power cut none of the codes in my freesat information pack would reconnect to tv. On the forum page one of the emails posted said they had been given the code 0527, it hadn't worked for them but it worked for me. My sky remote now operates tv. It does have an irritating habit of always switching to scart 2 at first instead of scart 1where I have freesat, I then have to use the the remote to switch to scart 1 before I can proceed any further. I am happy enough though, I was pulling my hair out before I found your Website.
Cheers
JP
Posted on Jun 22, 2009
What is the code for a Panasonic tv/dvd/vhs combo.....
New 3 digit codes for DVD/VCR, DVR/SAT, TV/VCR, TV ...
www.eliztech.com/remotes/ge-new-3digit-combo-codes.php
DVD/VCR, DVR/SAT, TV/VCR, TV/DVD, DVR/CABLE and DVR/DVD combo codes for GE/Jasco three digit universal remote controls purchased after ... 3 digit codes for GE Universal remotes purchased after August 2002 ... PANASONIC, 437.
[PDF]Manufacture Code List
https://www.att.com/support_media/images/.../set-up-code-list.pdf
AT&TDVD VCR COMBO. VCR. HTIB. REC TUN. AMPLIFIER. TV. Abex 1098. Admiral ....Panasonic 1003, 1010, 1049, 1053, 1096, 1123, 1152, 1231, 1289,. 1292 ...
Remote Control Program Codes - FTC - Farmerstel.com
Jan 01, 2016 | Panasonic Televison & Video
Westinghouse acces code for model. Dw39f1y1
The code is stored in the remote. If you are using a Westinghouse remote, it should work automatically with your TV. If you are trying to use a programmable remote, you can use its code search feature to seek a suitable code. If a thorough search through all available codes stored in the remote fails, you may have to try another programmable remote.
Dec 04, 2014 | Westinghouse Televison & Video
Westinghouse codes
I just bought a 40" Westinghouse at BestBuy and had the same problem. My TWC remote still had the code from my old analog Samsung. Fortunately I kept the code sheet from Time Warner and using the 3 digit method reprogrammed it. Westinghouse uses 4 dif codes on their LED-LCDs. Here are the 3 digit code nos. 076 276 435 001. I ran thru the first 3 and mine was 001. Whoever your provider is use their remote to do this and not the one that came with your set. I used that remote to make all the adjustments on my set to fine tune it, color, sound, etc.following the menu. Hope this helps.
Aug 18, 2014 | Westinghouse Electric LD-3255VX 32 in. TV
Needing the channel access code for a westinghouse tv model DW39F1Y1 serial number 7532V33500473
I need Code the Channel Access, WestingHouse Tv
Modelo: DW39F1Y1
N?mero De Serie: 7531V34300250
Jan 04, 2014 | Televison & Video
Tv remote code for haier tv l24c1180a?
Hello
Four digit universal remote contro codes for Haier TV are:
0081 0216 0217 0157
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Jun 26, 2011 | Televison & Video
Code for Channel Master CM-7000 Digital TV converter box ? I need code number for Sony TV
If you do the setting up using device codes scan correctly (page 25 in the user guide ) it worked with my sony bravia KDL-32L5000.
Oct 26, 2010 | Channel Master (9537) Remote Control
Remote codes for directv HD DVR and westinghouse tv
2. Locate the 5-digit code for your TV (see pages 13-16).
3. Move the slide switch to TV.
4. Press and hold in the MUTE and SELECT keys at the same
time until the green light under the TV icon flashes twice
and then release both keys.
5. Using the number keys enter the 5-digit code for your
brand of TV. If performed correctly the green light
under TV will flash twice.
6. Aim the remote at your TV and press the power key
once. The DIRECTV Receiver should turn off. If it does
not turn off, repeat steps 3 and 4, trying each code for
your brand until you find the correct code.
10463, 10623 Westinghouse 00002 dvr hd
Jun 20, 2010 | Sony STRDH810
Comcast Remote requires 3 digits be entered to change channels
I had the same prob and found the answer posted elswhere.
This worked for me...
If you go into the main menu under Setup --> Guide Setup --> Set Auto-Tune to "YES".
now the channel will change without the 3 digit requirement.
Nov 23, 2008 | Universal Remote Control Remote Control
l. Push the "Menu button"
2. Push the "Menu button" again
3. Scroll to "Setup" and push "OK"
4. Scroll to "Guide setup" and push "OK"
5. Scroll to"No Auto Tune"
6. Click on arrow next to "No Auto Tune". This will change it to "Auto Tune".
7. Now exit, or just punch in any channel number.
You should now be able to go directly to a channel without entering zeros.
Nov 23, 2008 | Philips Tivo HDR812 80-Hours Video...
iLO V27DMBX Television Logo
295 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
