Question about Cameras
Best picture settings for Sharp LC-60LE757 60-inch Aquos Quattron 1080p 240Hz Smart LED 3D HDTV
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
  • 10865 Answers
SOURCE: I can't find the owner's/TV manual for Sharp AQUOS
http://www.sharpusa.com/files/tel_man_LC46D43U.pdf
Posted on Jun 04, 2009
bshldn
  • 736 Answers
SOURCE: Sharp AQUOS 52" 1080p 120Hz Flat-Panel LCD HDTV
Press the menu button and scroll over to the setup sub category. Scroll down to reset and press enter. Select yes and then enter. Select yes again and press enter. The television will turn itself off and then back on.
If that basic reset doesn't work call 877-332-7867 to be walked through the no sound troubleshooting up to an INIT. I cannot put the steps for an INIT into print because any wrong move could erase everything from your television.
Posted on Dec 29, 2010
bshldn
  • 736 Answers
SOURCE: How to adjust for best picture a Sharp Aquos
This sounds like a setting that can be adjusted. What I like about some of the Sharp televisions is the av mode setting (preset brightness/contrast adjustments). I am not looking at the manual for this model so I'm not sure if this is an option on this television. However with this being a high end aquos model there is free assistance available to you. You can register your television at aquos advantage and chat live with an aquos advisor at Sharp's Midwest Corporate Headquarters. The agent may advise you to call in if your television need and Industry Initialization because you have to be talked through it. I advise the chat reps initially because when you call you aren't able to speak with the Midwest Corporate Sharp reps unless your call is being escalated.
http://www.aquosadvantage.com
Posted on Apr 22, 2011
SOURCE: LCD Screen replacement for KDL-55HX800 55in 1080p 240Hz 3D LED TV?
Hi there and good morning to you
I am sorry I do not know of anyone apart from trying AMAZON.
Here in Iceland Imight eventually find one but it is far away.
Good luck toyou
Kolbrun
Posted on Feb 25, 2012
How can i remove channels such as 17.1 17.2
Dear,
Please follow the below URL and flip to page 25, you will see the steps to delete the channel
URL: http://files.sharpusa.com/Downloads/...UN_65E77UM.pdf
Regards,
Samy
Aug 10, 2014 | Sharp " AQUOS Quattron - 70"" Class - LED...
TV Freezes up and once in a while goes blank then turns back on after about 10 second when I am watching something
Try to use a different cable. If your using hdmi, try component instead. Sometimes there's a data conflict with hdmi
Jun 13, 2014 | Sharp " AQUOS Quattron / 60"" Class / LED...
When i push the power button nothing happens, I replaced the big computer board in middle of tv but didn't help, what can i do next
Most likely needed the Power Board.
If you search you tube with you eggzact model you might find people showing you how to fix it without replacing the board. (any good at Soldering?)
May 15, 2014 | Sharp AQUOS Quattron 60 Class LED 1080p...
Screen broken on tv
Sorry to hear that, sadly a replacement screen is most likely out of the question. It will cost more to replace the screen vs. buying a new set!
Nov 05, 2012 | Sharp AQUOS Quattron 60" 3D Full HD 1080p...
No sound thru pioneer equaliser from quatrron tv
There are two way to do this.
1. Connect all your devices individually to the Pioneer receiver. Doing this allows you so have different sound settings for each input. A reason you might want this is that your DVD will need a DTS or Dolby sound setting so that you get the best audio from your DVD, whereas your TV may only be outputting stereo audio. In this case you would set your Pioneer to a stereo setting.
2. Connect your devices to the Sharp display, then connect the audio output of the Sharp to a free audio input on the Pioneer.
Your Sharp LED TV has two ways to do this: a. If you have a digital capable Pioneer sound system, connect using the "Digital Audio Output". You will need a Toslink (Optical) cable for this connection. b. If you only have analog capabilities in your Pioneer sound system, you must use the 3.5mm (1/8 Inch) analog audio output from the Sharp TV to stereo RCA (red and white plugs that are most commonly supplied with home theatre product).
Oct 27, 2012 | Sharp AQUOS Quattron 60 Class LED 1080p...
Cameras Logo
20 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
