Question about Samsung RS2556 Side by Side Refrigerator
Fridge side began freezing everything then the fan
Fridge side began freezing everything. We reduced the temperature which helped on this samsung sidexside. then the fan seems to be running all the time and is very noisy and is really not keeping the temperature at the 38 degrees
    Problem Solver:
  • 14 Answers
Generally speaking, sounds like you may have the frozen condensor problem that is so common
because of the design flaw in the Samsung products.
Turn it off, empty the freezer.
Study the back and look for formed ice around the seams.
So it got too cold, and now it is still too cold, or not cold enough ?
Posted on May 08, 2009
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
Everything in the fridge and drawers began to freeze about 10 months after purchase. Reducing the temperature to as high as 46 F doesn't help.
Check the ice bank door to make sure it is closed properly. It is the door that covers the icemaker. Usually that is the problem that someone has left the door ajar leaking freezing temperature into the refrigerator.
Jun 17, 2011 | LG LFX25971ST Bottom Freezer French Door...
Fridge temp is set on 1 and milk and eggs are still freezing.
This is a common problem and it has to do with the electronic temperature sensor. Check with Sears to see if there is either a recall or a TSB (Technical Service Bulletin) for your model. They may try to get you to buy a new circuit board, but the solution is actually the temp sensor itself. (www.searspartsdirect.com) will give you the scematic as well as the part number. Just enter your model and press enter.
Mar 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Temperatures not staying cold, then getting too cold. First everything in freezer thawed out. Then, fridge wasn't cold enough. We moved everything to freezer just to keep colder (not to freeze). Then, days...
assuming fan now working. clean out vents/ drain holes (make sure no ice in bottom of freezer or in fridge unit)i.e. a total defrost.then check door seals all okay(no air leaks) if unit was trying to defrost itself and you reset to colder it will need to reset itself.....
Feb 11, 2010 | Hotpoint HSS25GFP Side by Side...
Water dipenser
The instruction book suggests this could be because the freezer temperature is set too low. Mine is set at -20C. It says the water line can freeze stopping water flow. Try reducing the temperature.
Sep 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS263BBWP Side by Side Fridge: Water line continually freezes
higher numbers on the tempature set make the fridge
colder lower numbers make wormer
May 23, 2008 | Samsung RS2556 Side by Side Refrigerator
Samsung american fridge sn 188742bp100124K
The freezer temperature ok.
The fridge keeps freezing
Dec 06, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Fridge fan freezing
you may have a obstructed drain line
Dec 05, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS21w USA style frige freezer panel problem
hold down the 2 lower buttons for 5 seconds to unlock the display panel
Sep 06, 2007 | Samsung RS2630WW Side by Side Refrigerator
Samsung RS2556 Side by Side Refrigerator Logo
209 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
