Bad mouse or usb ports
Not sure if its the mouse or usb ports, but my trackball is only a few months old and i used it on my previous laptop, which is only a month old. Says it doesnt recognize it. Also, my headset doesnt work in the ports... so again, not sure if its the ports
  • 38 Answers
Clean the mouse properly.... try some different mouse run a hardware daignostic test on mouse and also on the mother board....
Posted on Aug 03, 2009
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
Cursor freezing
Remove viruses.
hope this helps
Oct 09, 2012 | Sony Vaio VGN NS20E Laptop Car- Air DC...
My V450 Nano Cordless Laser Mouse for Notebooks aint working the green light is on but it doesn't get recognize by may laptop
Q: Troubleshooting: Basic Mouse/Trackball Problems trnsp.gif This article covers some common reasons why a Logitech mouse may cease to function.
trnsp.gif This article applies to the following products:
All Logitech mice/trackballs
Cause:
There are a number of reasons why a mouse or trackball may suddenly stop working. These include the following:
  • defective hardware
  • system configuration changes
  • wireless detection issues
  • hardware connection failures
Solution:
It is possible that the mouse or trackball has failed. A failed unit can be described as a product that works for a period of time then suddenly stops working. Verify that you have not made any changes to the system that might coincide with the failure of the product. For example, if you moved the connection of the device to another port to add another device to the system or if you added new software or made other system changes. Also, verify the device has not become disconnected from the system by checking to see the device is correctly connected. Once you have verified the above potential causes for failure, proceed to the following steps.
1. Wireless Detection Issues
If you are using a wireless mouse or trackball, you should first check to see if you have a connection issue. Please see Knowledge Base article 970 for information on diagnosing and resolving detection issues.
2. Port Connection Issues
If you have concluded that the issue is not due to a detection issue and the pointing device has just stopped working, try the device in another port. If you were using it on the PS/2 port, try moving it to the USB port if you mouse supports it. If you have another USB port, try that other port. If you were connected through a hub, try connecting directly to the system ports to verify the hub has not failed.
3. If the device doesn't work on a second port, try it on a second system, if possible. If it fails on a second system, then the device probably is defective. You may also want to try a second mouse in the same port that the failed mouse was using.
4. If the second mouse does not function in the same port, verify the system port has not failed. Contact the system manufacture for more information on the status of the system port.
5. If either the mouse fails on a second system or the second mouse works in the same port, then you know the Logitech mouse is defective. If this is the case, please contact to inquire about a warranty replacement.
Answer ID 3997
Created 2006-06-13 01:54:48
Updated 2009-06-03 04:28:23
Jul 18, 2010 | Logitech V450 Nano Cordless Laser Mouse
My mouse and printer are both connected through USB ports. The mouse will not now work when the USB cable to the printer is attached and printer is turned on. All USB ports are working properly. This is a...
I had the same problem with mouse, it happens when devices connected to two USB ports that are close to each other, so I connected mouse in the back of computer USB and printer in the front USB (or reverse), or further away from each other.
Oct 30, 2009 | Microsoft IntelliMouse Trackball 1.0
The trackball and buttons under eneath do not work
Is that a USB or PS/2 mouse? If that is a USB mouse, try connecting it into anotherUSB ports of the computer or try another machine.
Same thing with the PS/2 mouse, try another machine and if you get the same problem, then the mouse is bad and needs to be replaced.
Thank you!
Aug 26, 2009 | Dell Computers & Internet
Scorpius K3NT USB Keyboard prevents resume after standby in Win2K
When entering standby, the usb ports go to sleep. Most motherboards allow you to tell the bios that you are using a usb keyboard. That should solve the problem. I keep an old ps2 keyboard plugged in and on the floor as a 'just in case'.
Jul 24, 2009 | Mini iOne / Qtronix Scorpius K3NT PS/2...
My Trackman Marble FX stopped working after dealing with a virus. Never could get it to work, maybe I just wore it out. Bought a Logitech optical mouse but the left click is messed up. It locks and does a...
It could be a bad Trackman or a bad PS/2 Port.
1st test if it's the port by trying another mouse, or by trying this Trackman in another known working PS/2 port on another computer.  (don't forget to reboot each time you plug in a PS/2 device)
2nd, you can try using a PS/2 to USB adaptor.
These two have great reviews...
$12 TRIPP LITE USB to PS/2 Adapter Model B015-000
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16812120006
$20 SIIG JU-ACB012-S2 USB to PS/2 adapter cable
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16812191021
Best of luck getting that wonderful Trackball working again!
~Andrew
EmpoweringSolutions
Feb 20, 2009 | Logitech Trackman Marble FX Trackball
Mouse not working
Normal 0 Try disconnecting the Mouse from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse to the USB port, do so and it should work.
Hope this helps. Bud
Oct 31, 2008 | Logitech Cordless TrackMan Optical...
Logitech Marble Mouse driver/setpoint messed up my synaptics touchpad on my laptop...can't fix this!
Hi, Please uninstall any logitech software version present on your OS (if available) - Then please proceed to clean boot. ( http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228 ) -> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if
possible rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for
new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software if available and/or plug the hardware when needed. -> Should work.
This TB delete the usb ports " memory " means if a device as been previously flagged with error, it will redetect
the device without the flag, unless there is some serious issue with the hardware/OS
If after this the issue persist, then I suggest you to call Logitech support to issue a replacement, hardware
failures are covered by warranty terms
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Oct 24, 2008 | Logitech Marble Mouse Trackball
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
