Question about Sta Rite STA-RITE CONTROL BOARD KIT - 42001-0096S
128 error code
Wwater not getting hot enough
    Top Expert:
  • Sta Rite Master
  • 7,919 Answers
Possible bad temp sensor
Posted on Oct 01, 2017
Heater does't fire. led appear 128,r13 what's problem?
128 r13 is not an error code. its the startup sequence of that heater
May 14, 2014 | Pentair Mastertemp Heater
Please error code H4 shows on my mx 181 sharp copier please what is the remedy?
Hold down the button to get the 2nd part of the error code. H4 type errors have to do with the fuser, that's the hot rollers that melt and press the toner into the paper. Depending on the 2nd part of the code, it could be too hot or not hot enough.
Aug 10, 2013 | Office Equipment & Supplies
Error code 128. R9
128 R9 isnt an error code
Jul 28, 2013 | Pentair Mastertemp Heater
The code nf keeps coming up what does that stand for
NF(No Fill) code indicates that the washer is not getting enough water supply. Check if wwater supply is turned On and water is coming through the pipe. Then the fill valave can be clogged. t can become clogged with sediment over time
Stop the water supply and then remove the hose and then check for any clogs and if they are fine then in your case most probably your fill valve must have gone bad for this problem.Replacing it must solve the issue.
Jan 14, 2011 | Samsung WF337AA Front Load Washer
It gives me a NF code what is wrong with it?
Jan 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
What are error codes 801 301 3D and 800 1000A on the Sony Playstation 3 console. I need help realy bad. Enyone that awnsers will have there questions awnserd. Thanks for reading.
Error 801 301 3D is due to internet connection issues.
Check to see if your router has backwards compatibility to wireless G because the N router uses 256bit encryption coding while the G uses 128 bit encoding. ps3 , use the 128 encryption coding also. If the router does not support 128 bit encoding you will never connect with it.
And 800 1000A error means that you cannot download from the sony store. hence the connection problems from your first error.
Hope this helps you.
Correct? recommendation and vote would be aw some!
thanks.
Nov 22, 2010 | Sony Playstation 3 (PS3) Console
Charge problems
Appeats voltage regulator ha a plroem, but, check battery wwater level before replacin battery or alternater.
May 27, 2009 | 1989 Honda Prelude
Errors
If this is a Xerox 128, I have looked through all the documentation and those are non standard fault codes.
I would first start by seeing if the scanner was comming on and moving correctly.
The only other thing you can try is to remove all the covers and disconnect and reconnect plugs, and ribbon cables.
There is nothing in the documentation or engineering notes to reference any of those error codes.
Not even eliminating the P and just looking up the individual codes as just numerical codes.
A non functioning scanner will produce many odd codes not listed in documentation, which is why I am having you start there. Reseating connectors will allow all modules to communicate, which can also produce odd codes.
Feb 26, 2008 | Xerox WorkCentre PRO 128 Copier
Sta Rite STA-RITE CONTROL BOARD KIT - 42001-0096S Logo
29 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
