Question about Panasonic Viera TX-32LX70 32 in. LCD TV
Panasonic tv disarm no action shut off activated
2 Suggested Answers
SOURCE: How do you disarm "No action shut-off has been activated"?
menu> setup> eco settings> no opperation off.
Posted on Jun 24, 2012
How do you work 2006 street glide push button key fob
1 long push on the remote turns it on and 2 quick clicks turn it off.
Disarming function may require practice. The key fob button must be pressed twice within 1.5 seconds to send the disarm command. The action is very similar to double-clicking a computer mouse. Light quick taps work best; very hard or very slow taps are less likely to work. The key fob sends a RF signal to activate all remote TSSM functions. The left front turn signal switch wire serves as the vehicle's antenna. If the TSSM does not respond (no confirmation at arming/disarming system) or responds weakly (limited range, won't consistently arm/disarm or synchronize),
Verify key fob battery voltage is at least 2.9 volts. Replace the key fob battery every 2 years.
Interference from physical surroundings may affect RF transmission. Place the fob next to left hand grip and disarm with two clicks or move the motorcycle to a new location and try again.
Check for damage to antenna wire. Does left turn signal work?
After a battery disconnect, the TSSM will not enter the configuration mode on the first attempt. All attempts to assign a fob or enter the configuration mode will require at least two attempts.
The TSSM system uses batteries in the key fob and siren. These are the only parts requiring periodic maintenance.
Battery Replacement
Open the key fob case, place a thin blade between the 2 halves of the case, slowly twist the blade remove and replace battery positive + side down, use a Panasonic 2032 or equivalent, align the case and circuit board, snap the case halves together, while standing next to the motorcycle, press and hold the key fob button for 10 to15 seconds until the security system responds with two turn signal flashes/siren chirps.
May 04, 2014 | Harley Davidson Motorcycles
Panasonic ct-34wx54. I cant remove the closed captions from the screen. When i go to the menu and try to shut it off the on and off modes are "grayed out" and cant be highlighted. Reset with...
Try pressing the volume down button on the T.V. and the info button on the remote. Do this for at least 5 seconds and it will reset the T.V.
Mar 16, 2011 | Panasonic CT-34WX54 34" TV
No action shutoff was activated. How do I turn
Go in ur tv menu go to SETUP.Check for Sleep timer might be on.This timer have setting like 30 60 120 mins.Turn off the sleep timer tv well not auto shut off.Check ur remote control might have a button said sleep.
May 28, 2010 | Panasonic TH-46PZ800U Plasma TV
Has a black block in the middle of the screen when watching satelite. Is okay when watching DVD, or using the action screen
You may have activated one of the closed captioning modes. Double check the TV and may be the menu in the satellite has a caption mode. But I'm sure the Tv will be the problem!
Apr 08, 2010 | Panasonic PV-DM2792 Triple Play 27 in....
How to unblock v chip in panasonic panasonic CT 27SL15 TV
Push the power button and the action button on the tv set until it shuts itself off and this will reset your tv. You cannot use the remote to reset...must use the actual tv buttons on the television set.
Jun 17, 2009 | Televison & Video
How can I reset my Factory Alarm on my Jeep it wont run
Alarm Module Reset Procedure
NOTE: This information applies to a Vehicle Theft Security System (VTSS) that was armed when the battery was disconnected and reconnected.
When the armed VTSS senses that the battery has been disconnected and reconnected, it enters its power-up mode. In the power-up mode the alarm system remains armed following a battery failure or disconnect. If the VTSS was armed prior to a battery disconnect or failure, the system will have to be actively or passively disarmed following a battery reconnection.
The power-up mode will also apply if the battery goes dead while the system is armed and battery jump-starting is attempted. The engine no-run feature will prevent the engine from starting until the alarm system has been actively or passively disarmed.
Passive disarming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the lift gate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter.
Once the alarm has been activated (horn sounding, lights flashing, and the engine no-run feature), either disarming method will deactivate the alarm.
Depressing the Panic button (if equipped) on the RKE transmitter will also disarm the VTSS, but the horn will sound and the lights will flash for about three minutes as part of the Panic feature. The horn and lights can be stopped by pressing any of the RKE transmitter's buttons or driving the vehicle above 15 mph.
Jan 28, 2009 | 1999 Jeep Grand Cherokee
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
Jun 12, 2008 | Panasonic CT-36D32 36" TV
Shutting down....
You have POWER supply board that went out.....apparently this is a common thing for this model.....sorry to see such low activity on this site......hope it helps.....
Apr 13, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic Viera TX-32LX70 32 in. LCD  TV Logo
16 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
