Question about ASUS N50Vn-C3S 15.4-Inch Notebook PC
Cant send file to asus A550c via bluetooth even i try to search device from my lappy and phone. either cant detect each other
RescueTechLA
  • 2653 Answers
SOURCE: how to enable bluetooth on eee pc 701sd
Are you sure it even has bluetooth?
This guy had to do a lot to get it working.
http://forum.eeeuser.com/viewtopic.php?id=3982
You could check your manual or even the box that it came with to check easily. It will say whether it does or not.
Posted on Feb 21, 2009
Kree8iv
  • 192 Answers
SOURCE: ASUS EEE PC wireless problem
There is a great program called Network Magic that will configure your wired and wireless connections with absolute ease. ALthough it is not a free program, you can use it to sonfigure everything and after the initial 7 day (used to be 30 day) free trial, it will ask you to purchase. You can easily uninstall it through add/remove programs in Control Panel. If you choose to uninstall it, it will not undo the connections it has made, and will not leave any residual program information in your computer. You may decide to keep it though. It is a great program that will keep you informed of many network functions, as well as help with your network security. It will even tell you when others have wirelessly logged on to your network and allow you to create barriers against this. You can find it here: http://www.purenetworks.com/download/thankyou.php
Posted on Jun 18, 2009
  • 64 Answers
SOURCE: cant connect asus computer to tv via hdmi
Try turning both pc and tv off and connect, then turn both on. Also, make sure your Display setting are correctly configured. Goto Control Panel, Display and click on Settings Tab. If your still having trouble. Try changing your resolution and make sure that you have your TV to the right input. My TV has 4 HDMI 3 RCA 2Component 1 Digital Optical many USBs...can get kinda confusing. The connection should be numbered. Switch inputs with your remote til you get the right port. Then work on getting your pc to display correctly. Set your aspect ration to 16:9 first. Most tv and laptops are set this way. GOOD LUCK let me know how it goes.
Posted on Sep 12, 2009
shibuda
  • 1812 Answers
SOURCE: I cant use my bluetooth
Hi friends
It s a simply way, to solve the problem.you will follow the instruction.
Follow the bellow step.
1. just enter your Bluetooth in your pc.
2. when the icon show your task menu bar just
3. double click on icon
4. add>check on my device >next(ensure phone Turn BT on )
http://www.acroname.com/garcia/tutorials/bluetooth/connection/connection.html
you can see the phone model which Bluetooth on.
just select the device >choice any ask code >I will advice you, please select, let me choice> type any 8 digit >next >now the same
number > in your mobile >finish
For dial up go r click on my network>properties>create a new connection> connect to internet>next >set up manually>connect
using dialup>select your mobile modem>next >type any name >type the exact name and number eg: for Airtel=*99#>next >no user
name and password just next >check on add short cut>and finish.
Just double click on the icon, it will connect soon.
Or
you can install PC suit and set it through the following step.
Setting> Setting >participate tic on yes .Double click on phone icon >next>tic on Bluetooth connection >next >select yes the phone
mobile>next
Remember always set the mobile for connection select the yes.
Hope it will help you.
Posted on Feb 23, 2011
manoshar282
  • 94 Answers
SOURCE: My Laptop specifications are, ASUS
Seems like your Bluetooth and Wifi settings are disabled from BIOS.
On laptops usually there is a setting in BIOS where you can disable/Enable Wifi+Bluetooth. Shutdown computer Turn on computer and press "F2" to go to BIOS settings Find settings for Wifi+Bluetooth and set it to default.
Save settings and restart computer You will be able to see your Bluetooth and Wifi.
Hope this works
Posted on Jun 29, 2011
I have alcatel z221 cant download pictures to computer
You can transfer pictures from your phone to your computer in 2 ways.
Bluetooth
1. Enable Bluetooth
- From idle mode, select Menu > Settings > Connections > Bluetooth.
- Press the OK Key to set Bluetooth to On.
2. Pair your phone to your Bluetooth enabled computer. If your phone does not have a built-in Bluetooth module, you can buy a Bluetooth dongle from your local electronics store.
- From idle mode, select Menu > Settings > Connections > Bluetooth > My devices.
- Press the OK Key to search for available Bluetooth devices.
- Highlight a device from the list and press the OK Key.
3. Select your desired file, and select Left Soft Key [Options] > Send > Via Bluetooth.
4. Select the target device from the device list, and press the OK Key to send.
Email
1. Select your desired file, and select Left Soft Key [Options] > Send > Via Message
2. Enter your email address. press the OK Key to send.
3. You can now download the file from your computer.
Aug 31, 2015 | Alcatel Cell Phones
hi
i have a asus a550c
i cant found the blutooth and i cant send or resive file
help me please
Nov 01, 2013 | ASUS N50Vn-C3S 15.4-Inch Notebook PC
I can't Install Java Games i my Samsung A767 ...Its always Says "Unsported Files"
hi i think u might have directly copied the games to ur phone's memory card via data cable doing so may result in the phone saying unsupported files but since ur phone is java supported and the games will work for sure u can install the games via bluetooth enabled laptop or even u can use a bluetooth dongle to install the games in ur mobile.To install the games in ur mobile via the dongle follow these steps:-
1.first plug in the bluetooth dongle in ur system and ur PC will detect it,as soon as it detects the device go to the START menu PROGRAMS ->ACCESSORIES->COMMUNICATIONS->BLUETOOTH TRANSFER WIZARD and click on the ur system bluetooth wizard
2.switch on ur mobile bluetooth and search for any paired device u will receive a prompt message as soon as ur system detects the mobile and will ask u to enter the password type the same password which the system will generate and ur mobile will be paired u can then select a game file and send it in ur mobile from the PC via the dongle as soon as the file is copied u will receive a message in the mobile to install it type yes and there u go the game will be installed.
u can also try using another phone switch on the bluetooth device of the other phone and copy the file in the targeted phone via the bluetooth .was this useful to u if yes pls do rate my solution and u can also send ur views via the testimonials thanx fr visiting fixya
with warm regards - bonefirediv.
Apr 18, 2011 | Samsung Propel A767 Cell Phone
How do you transfer the photos to the PC
first of all, you turn on your bluetooth. then the laptops bluetooth. you select the recieve file on the laptops bluetooths option. then you search for device on the phone then you select the photo you want to send then send via bluetooth.
you can also send via usb cable. when the laptop or computer reads the usb, select the mass storage, then you try to locate the photo you cant to send the transfer it through the cable.
goodluck
Jan 31, 2010 | LG Vu CU920 Cellular Phone
Bluetooth Connecting Problem in Laptop
GO TO THE BLUETOOTH SETTINGS AND ALLOW ALL DEVICES MAKE SURE U PAIR THEM AND THAT BOTH PHONE AND PC ARE DISCOVERABLE USE THE SAME PAIRING CODE WHEN ASKED 4 1...EX.0000
Oct 25, 2009 | Samsung OmniaHD i8910 Smartphone
I cant send data via bluetoorh to other phone... or receive data from other phone throught via bluetooth... cant detect other device after searching for other phone throught via bluetooth. Im using P990i...
When you are receiving the file, check whether you have checked the Visible to other option. And it will ask for the confirmation when you will be receiving the file from other phone whether to accept or not. While sending the phone to which you are sending data should accept the file you are sending.
Let me know if you have any comments.
Jun 10, 2009 | i-mate SP3i Smartphone
Blackberry 8110 - cant receive bluetooth stuff
with a blackberry you have to go to the media player, go to music for music and then hit options receive using bluetooth
Dec 03, 2008 | RIM Blackberry 8110 Cellular Phone
Brand new phone but cant use bluetooth feature for some reason
Do u power on the Bluetooth... if not then u can't connect any device via bluetooth...
Turn on the Bluetooth by Selecting
Menu > Settings > Connectivity > Bluetooth link
now, select
Set up >Power
Click on Change Button and select On
go back
and select hands free then click [look for devices]
it will search for the device...
From another mobile send a file via bluetooth by powering on the bluetooth.
in Motorola copy or move will send the file via bluetooth.
Contact me if any problem persist at shahbaz8x@gmail.com ...
Thank you!
Oct 22, 2008 | Motorola Mobility RAZR V3
Samsung d900 bluetooth help
Your bluetooth output device may have a weak signal generator. I suggest visiting an electronics store to check it thoroghly. Good Luck!
Sep 11, 2007 | Samsung SGH-D900 Cellular Phone
D900 Bluetooth
try a hard reset *2767*3855# then try again
Sep 02, 2007 | Samsung SGH-D900 Cellular Phone
ASUS N50Vn-C3S 15.4-Inch Notebook PC  Logo
113 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
