Question about Frigidaire Affinity ATF7000E Front Load Washer
How to reset a frigidaire ltf2140fs
Is not spinning
Crown series. Why isn't it advancing to spin cycle?
Hey Chuck, thanks for your inquiry!
Based off the information you have provided your Frigidaire washer is not advancing into the spin cycle. You could be experiencing an issue with your timer or wiring harness. I would suggest performing a reset on your washer to help clear out any possible miscommunication that may be within the appliance. You can reset the washer by flipping the household circuit breaker off for at least ten minutes. I hope that this information is helpful to you in some degree. -Matt
Mar 28, 2016 | Frigidaire Washing Machines
My Frigidaire front load washing machine has stopped high-speed spinning. The regular spin works but not the high spin. Any ideas how to fix that?
Hello Mike, thank you for your post!
From what you have described your Frigidaire washer is not spinning on a high speed. This could be a possible issue with your motor, control panel, or speed board. I would recommend performing a reset on your washer and you can do that by unplugging the washer for at least ten minutes. If that does not correct your issue I would suggest having a professional technician out to perform a proper diagnosis and repair on your washer. This will help you avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Apr 29, 2015 | Frigidaire Washing Machines
FRIGIDAIRE LTF2140FS1 SPIN SLOWLY
Hello friend, thanks for your post!
I understand that the spin feature on your Frigidaire washer is spinning slowly. It sounds like a potential problem with your motor control board or control board. I would recommend performing a reset and you can do that by disconnecting the power from your washer for roughly ten minutes. If that does not help correct the issue I would recommend having a professional come out. They will be able to pinpoint the cause of the issue and replace any electrical components to avoid any personal injury or future issues with your washer. -Matt
Feb 21, 2015 | Frigidaire Washing Machines
How do I repair my front load washer that seems like the water pump will not allow the water to drain?
did you check the water filter on the lower part of the machine to be sure it isn't stopped up?
Sep 25, 2014 | Frigidaire Washing Machines
Will agitate won't spin
Good Afternoon Friend,
I understand your Frigidaire washer, model# FWSB5700DS, will agitate but not spin. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When power is returned, select any cycle and run the wash. If you are still noticing that it is agitating and not spinning, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why it will agitate but not spin. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Frigidaire FWSB5700DS Top Load Washer
Frigidaire affinity washer program error. When you turn the knob to normal washing, it only has 26min when it use to have 40min and now you can't make any choose any options. The options are all out...
factory reset you have to
push the Spin Speed and Soil Selection keys simultaneously and hold
until you hear a beep. This is no more than 10 seconds.
If this helps PLEASE RATE ME >.....
Jun 25, 2011 | Frigidaire Affinity ATF7000ES Front Load...
Washer won't spin in final spin out
Hello harley1964dm
Welcome
You said, you have a Frigidaire front loader and it will not spin out in the final spin would you please help me. thanks
For a Frigidaire usually ,
If the washer won't spin.
Many times it's because the load is too small. Add 1 or 2 similar items to help balance the load.
If it does not remedy the problem try unplugging the machine for 5 minutes which will reset the system!
Let me now how it goes.
Huuum
Please remember to leave a rating
Oct 11, 2008 | Frigidaire ATF6000ES Front Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire Affinity ATF7000E Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
