Question about Sta Rite Sr333na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 333,000 Btu Natural Gas
Heater only warms water to 98 degrees
Heater will not heat water temperature higher than. 98 degrees
PartsCenter
  • 125 Answers
SOURCE: Heater won't maintain program high temperature
Not sure which one is correct but here is a link to the Pentair/sta-rite site so you can get the information.
Sta-rite Heaters
Posted on Feb 26, 2009
PartsCenter
  • 125 Answers
SOURCE: sta-rite heater Display shows 125 degrees, won't activate heater
sounds like the temp sensor is bad. Sta-rite Heater
  • 83 Answers
SOURCE: Water Temp on heater reads 126 degrees F
I am not sure if you have resolved this issue, or not, but just in case. Yes, the problem is the Thermistor. This is a sensor that "reads" the incoming water temp. It is really easy to replace as well.
Posted on Jul 09, 2009
  • 83 Answers
SOURCE: Temperature reads 125 degrees.
I am not sure if you have solved this issue, or not, but just in case. The problem is the Thermister, or temp sensor. That will need to be replaced since it is reading the water temp at 125.
The Thermister is located on the manifold, left hand side, between the first two bolts. It is pretty easy to change out and this will correct the problem.
Posted on Jul 10, 2009
  • 990 Answers
SOURCE: Water Temprature read 126 on heater and will not Fire
This is a problem with your thermister (heat sensor) You will find this on the left side of the water manifold about half way down. I'm not sure but I think it is a small tube that slides into the manifold and if you follow the wires back to the board it just plugs in. The part is reasonable priced for a heater part and very easy to install. Good luck.
Posted on Dec 21, 2009
New replacement in-line heater (C3B54P0-3002AU0) inop.
Bath tub heaters will only maintain the water temperature in the bath. They will only heat the water approximately 1-2 degrees an hour.
Whatever water temperature you start with is what you will be able to maintain.
There is a red indicator light on the front of each heater indicating whether or not there is power to the unit when the tub is full of water and the water pump is turned on.
If there is a red light on then it has power to it and is working.
This heater will never feel warm to the touch.
There are three different styles of Bath Heaters available.
  • Tee Heater - installs on the discharge fitting on the pump
  • In-line Pressure - installs anywhere in the plumbing line before any jet.
  • In-line Vacuum Heater - installs before the suction of the pump
If the heater you purchased is installed in the wrong place it will not operate.
Rod
US Parts Center
Dec 04, 2013 | Maax Calla 6042 Bathtub - 101058-000
I have a Vangaurd 6E720 30 gal electric hot water heater and the water does not get very warm.
If this is a new installation, make sure the unit is feed with at least 208+ volts of electricity.
If it is an older tank, try turning up the temperature setting on both thermostats. Set the top one 10 degrees higher than the bottom. If there is now change in the water temperature after a day or two, replace both thermostats. While your at it, change both element as well. A complete universal electric water heater rebuild kit should only cost around $35.
Aug 28, 2010 | Vanguard International Vanguard BY Rheem...
Normal wash cycle is over 2 hours?
Hello there
If your dishwasher's cycle times are too long, check these: Water pre-heating Cycle not completing Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater. Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Jul 19, 2010 | Kenmore 16919 Built-in Dishwasher
My heater ignites and blows really hot exhaust
The water is mixed on the back side of the heater and will exit the heater at 7-11 degres hotter than it came in. This will keep people from being scalded at pool side. So what you have sounds normal.
Apr 05, 2010 | Hayward H Series Pool & Spa Heater 400k...
What cooling system thermastat should I use? My heater is not working. Water temp is 175 to 185 degrees.
Your run temperature is within spec. Your problem possibly is in the heater core itself.
Check the hoses going to the heater core and make sure both are warm when the car in at run temperature and the heat is turned on.
If one is cold and other warm you have a flow problem in the heater core that must be corrected.
Jan 14, 2010 | 2001 Buick LeSabre
The heat control valve appears to have stuck, the water is only luke warm
I do not know what heat control valve you are referring to on an electric water heater. On an electric water heater it has two heating elements in most cases. One at the top and one on the bottom. One of these is more than likely defective. Turn the power to the water heater off at the service panel or at a disconnect switch. Now take the covers off both heating elements. Check each one with a ohm meter to see if you have continuity. If your meter reads nothing that heating element is bad and needs replacing. On each heating element is a thermostat to set the temperature. Set the upper element to 120 degrees and the lower element to 130 degrees.
Jan 05, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
When my car warms up the heater blows out warm but gradually gets cooler and cooler after about 10 min. It will stay cold ( about three degrees above outside temp.) It does this on cold days. And after you...
It may be the valve that controls the amount of water entering heating core but I'm wondering if your engine thermostat isn't stuck open. This is what controls the coolant temperature in your engine. It closes off while engine is off. It will remain closed after you start your car until the water warms to a certain temperature then it starts to open enough to keep your car at the proper operating temperature. If it stick open then it will take a lot longer for the engine to heat up and on smaller cars might never heat up enough for your heater. If you live in very cold climates such as where I live in Wyoming, we have to change to a higher degree thermostat so we have a good heater when it's 30 below zero.
Be very cautious here but one way you can check this is to put a piece of cardboard in front of your radiator and stop the airflow that cools your engine coolant. THIS WILL CAUSE YOUR CAR TO HEAT UP AND CAN CAUSE ENGINE DAMAGE IF IT OVERHEATS. Don't completely cover the radiator but if your heater warms up when you put the cardboard in front of radiator it's a good sign that your thermostat is stuck open and needs to be replaced.
Dec 04, 2009 | 1989 Lincoln Town Car
Heat blow cold air
most likely a problem with the water circulation around the heater core. if you've never used the heater, some vehicles have a hot water shut-off valve for the heater hoses. another possibility is the thermostat had been removed. the easiest way is to start the vehicle and slowly allow it to warm up monitoring the water temperature. it should heat up to normal water temperature, then heat up and then drop down. the thermostat is usually around 180 degrees or 192 degrees. it allows the water around the engine block to heat up then once it reaches 180 or whatever it opens up circulating the cooler water from the radiator into the engine block and pushing the hotter water into the radiator to cool off. no thermostat, then the water keeps constantly circulating not allowing it to properly heat up. this can slow the heater down, lower fuel economy, alot of things especially in the winter driving...
Oct 03, 2009 | 2001 Ford Focus
Dish washer
Water pre-heating
Water pre-heating
May 14, 2008 | EuroTech EWF150 Front Load Washer
Sta Rite Sr333na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 333,000 Btu Natural Gas Logo
35 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
