Question about Garmin iQue 3600 GPS Receiver
Garmin ique 3600 not working
My ique has only a blinking power indicator until battery is dead. Would not reset hard or soft? Got any ideas? The battery had been only showing half charged and life was low.....Don't know if that is related.
  • Anonymous May 24, 2009
    I purchased a new battery and put it in. Still doing the same thing. The unit will not charge. The green light does not come on....Any ideas?
  • freeman28139 May 24, 2009
    I had purchased a new battery. No help. Any other ideas????? It is my understanding that Garmin is no longer supporting his unit.
Been there. If the unit will not reset with the hole in the back poke you need to disconnect and reconnect the battery. Use a small torx screw driver for the four screws in the corners. Gently split the back case off by the thumbwheel and pivot it around. the battery connector is a small white connector in the lower left hand corner. Be careful of the power switch, ir lamp cover, and plug gasket since when you open the case they sometimes make a break for freedom.
Posted on May 24, 2009
Garmin iQue 3600 has a blink screen
if it will not power up, you don't have many options.
unscrew the head of the sylus to access the rest tool
Press the reset at the back with the stylus
This is re-booting, all data safe still here.
Hard reset is last resort...data erased here.
Press the reset button again as above
after you release, press the power button, keep pressing until the message
( all data stored is about to be erased )
to complete the reset press the upper half of the scroll button, on the front,
The digitizer screen appears
pressing any other button here performs a soft reset.
Update it if you get it up and running.
Hope this helps
Ric.
Mar 22, 2009 | Garmin iQue 3600 GPS Receiver
Dark screen on garmin ique 3600 pda
Turn the unit on and try holding the on/off button down for three oe four seconds.
Mar 13, 2009 | Garmin iQue 3600 GPS Receiver
I have a ique 3600 and was working fine until I plugged in the ac adapter to the bottom of the unit. It won't turn on. I did a soft reset and now I get a flashing Palm Software screen. I even tried a reset...
Mine has gone into the looping/flashing Palm Screen and then displays the hard reset do you want to erase everything. I fixed it by pushing the up button when it gave me the chance to delete everything and it fixed it.
Dec 20, 2008 | Garmin iQue 3600 GPS Receiver
Ique 3600 Hard Reset problem.
Hold POWER button down while doing a RESET. On restarting all should be OK
Sep 12, 2008 | Garmin iQue 3600 GPS Receiver
IQue 3600 Fatal Alert
You'll have to do a hard reset. Push the reset button, then hold the power button until the Palm Power appear and then release the power button. Next it will ask if you want to erase the data. I hate to said this but select yes. No will not work. Then after the inital set up run a HotSync.
Jun 18, 2008 | Garmin iQue 3600 GPS Receiver
Garmin ique 3600 won't turn on after battery goes dead
You have to charge the unit before it will start from a dead battery (usually about 10 minutes) before even trying to start the unit.
Jan 10, 2008 | Garmin iQue 3600 GPS Receiver
Screen Display Problem
Do hard reset? See Owners Manual.
Call Garmin they are very helpfull
Garmin USA 1-913-397-8200
Tech support 1-800-800-1020
1-888-442-7646
8am to 5pm Mon -Fri
Garmin Europe 44 1794-519944
Garmin Taiwan 886 2-26429199
Oct 27, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600
Did you try to do ANOTHER hard reset?
Aug 13, 2007 | Garmin iQue 3600 GPS Receiver
Garmin Ique 3600
May be a hardware issue. I had similar behavior when I replaced my IQue 3600's battery. If the circuitboard inside wasn't seated properly on the contacts coming from the battery, the iQue would keep rebooting. Start by checking that all the external screws are snug (but not over-tight). If not, you can try to open the case to check the two screws inside holding the circuit board. But I'll leave that up to you, since I can't honestly guarantee that you're experiencing the same problem. (After all, you seem to be sure that it has something to do with the software...and you may be right.)
Feb 03, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600
'Soft Reset' If that fails 'Hard Reset' while plugged into the mains! You will end up with an empty iQue but a HotSunc will re-intall
Mar 29, 2006 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
285 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
