Question about Caroma CARAVELLE270ADAW-EL Caravelle Elongated Dual Flush Toilet - White
Caroma slimline cistern won't refill and doesn't shut off automatically
2 Suggested Answers
SOURCE: I have a 1998 Caroma Reflections cistern p/n
the inlet washer needs to be replaced to stop the overflow, the washers are easy to get and cheap but trying to get the unit open to replace the washer is my big question at the moment
Posted on Sep 29, 2010
I have a caroma toilet about 15 years old and i need to get a replacement part for it. Where in Brisbane can i get parts?
George these guys are good . I purchased a flush valve from them for a really much older caroma cistern . They will most likely have the part you need .
https://plumbingsales.com.au/
Aug 20, 2017 | Caroma Home
Caroma duel flush cistern 20 yrs plus not flushing when buttons pushed
well past used by date
parts will be difficult to get so consider a new cistern
Jul 05, 2017 | Caroma Home
Caroma invisi cistern not flushing enough water
check the water level in the cistern
it should be about 3/4 " below the overflow pipe edge
May 25, 2017 | Caroma Home
Where to buy parts for Fowler toilet cistern .
adjust the float
you are looking for the inlet valve or diaphragm
not as much fowler out here as caroma system parts
ebay
large hardware stores
plumber
Oct 30, 2016 | Home
When toilet is flushed and refills water leaks into the cistern.
Are you saying that water is running into the toilet bowl? If so, check the rubber flapper at the bottom, and the valve (tube standing up).
Mar 29, 2016 | Caroma Home
Why is the cistern noisy when refilling
remove lid and look where refill hose is located should be attached and in fill tube [center tube ] if it is than your toilet s noise is normal --you can knock it down a little by turning down the water pressure[turn the external valve on the water line going into toilet ] turn it a little this will also slow refill time as well --and as to ultra quiet that s for the flush mode not the refill mode
May 09, 2014 | Caroma toilet - water saving Sydney Low...
I have a 1998 Caroma Reflections cistern p/n 6871774. It is making a hissing noise after the tank is refilled, and water streaks down from the supply rim of the bowl. Which part needs to be replaced?
Jan 10, 2010 | Caroma 270W-RF Reflection Round Front...
Problem overflow valve
Firstly open the top of the Cistern(Where water is held)There are two most common Cistern internals ie;Ball-O-Stop(Ball on a arm connecting to valve). This one is easy, you just bend the arm downwards in the centre so that the ball shuts the valve at a lower level; The other type has a shaft(plastic) with a thread on it, connecting it to a "small bowl" that lifts up as water enters the cistern. To adjust the water level in cistern you have to turn the thread(Shaft) lowering the "small bowl" wich will shut the inlet to the cistern at a lower level. Hope this helps
Mar 04, 2009 | Caroma CARAVELLE270ADAW-EL Caravelle...
Caroma CARAVELLE270ADAW-EL Caravelle Elongated Dual Flush Toilet - White Logo
Top Caroma Home Experts
john h
Ngoro
Ngoro
Are you a Caroma Home Expert? Answer questions, earn points and help others
