Matrix dx1000.2 1000 watt 2-channel amp user manual
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: i have a crown ce 2000 watt amp. channel 2 keeps turning off
Do you get any Fault indications?
Have you swapped the speakers around to eliminate them as external causes?
When the channel dies is the unit very hot and is the fan turning very fast (it should be if hot)? The fan could be defective, slow or airflow may be restricted.
Turn the amp off and examine the fan guard on the rear to make sure it is clear of dust and debris. Vacuum it out if necessary. With a small thin non-metalic object reach in and test the fan for free movement by trying to rotate it. It should coast.
Posted on Apr 28, 2009
How many watts does a sony xm-4301have?
it is a 4 channel amp, rated at 30c/60peak x 4 channels @ 4 ohms. bridged to 2 channels, it can deliver 70 w 2x continuous@ 4 ohms pr 150w x2 peak @ 4 ohms
below is the users manual
http://www.eserviceinfo.com/download_start.php?downloadurlid=57827
Aug 23, 2014 | Car Audio & Video
Matrix 1800 watt amp in protection mode
Check for shorted component/s at its audio output section circuit. Contact any service technician. Gopakumar Gopalan Google
Feb 16, 2014 | Matrix MX18002 1800 Watt 2 Channel...
What is the actual watts per channel @ 8-ohms and 4-ohms on the Behringer PMP3000?
Those specs would be right - I have this same board but the amp was fried by a previous owner. I pulled the amp board out and tossed it and use the mixer now to drive an external amp. Great board. This amp is rated at 1200W "peak", bridged into an 8ohm load. That would equate to about 900W RMS bridged into 8ohm or 450 per side into 4ohm loads per side. You can't daisy chain all 4 speakers....impedance would be too low. You can run two of your 8ohm speakers per side - that results in a 4ohm load per side for the amp. That would give you amp delivery of 450W per side. Your speakers are rated to handle more than that so you're fine. For the record.....you could run one speaker per side no problem....just lower power output.
Aug 16, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
Sony X-Plode amplifier. NOT working
It is possible if the model amp you have is bridgable to 1 channel. Usually when you bridge an amp you will need to hook one wire to the positive side of one channel and the negative side to the other. You will need to consult you user manual for the amp or get the manual from the sony website for instructions on how to bridge the amp or if the amp is even bridgable.
Oct 11, 2009 | Car Audio & Video
How many watts is it
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kac528.pdf
Page 7 of the manual gives you all the different configurations of this amp, and it's MAX power. FYI; Kenwood rates their amps at MAX power, not clean. Hope this helps.
Sep 30, 2009 | Kenwood KAC-628 Car Audio Amplifier
Kicker 8 inch 4 ohm subwoofer 200 watts rms?
Max 200 W. You could bridge 2 channels of a 4 channel amp (or get a 2 ch amp and bridge it) and connect the sub. Bridging = connect + of sub to + of one channel, and connect - of sub to - of *other* channel. Check amp manual for instructions.
Don't get a mono - most are 300W or more - might burn the coil during loud passages.
Jun 22, 2009 | Car Audio & Video
I cannot find the specs or user manual on the JVC archived items list. A few sites want to charge $10.00 for the user guide info, but I think that is too much to charge.
Defiantely not 200 watts
KS-A82
  • 2 Channel Amplifier
  • Bridgeable 2 channel amplifier
  • Output power: 25W x 2, 20 - 40,000 hz at .08 THD
  • 2 ohm stable
  • Adjustable gain (.1 - 2v)
  • MOS-FET DC-DC converter
  • Multi phase connection
  • 1 Pair of line input terminals
  • Remote relay turn on system
  • MSRP: $159.95
http://www.admtechusa.com/JVC.html#KS-A82
May 22, 2009 | Car Audio & Video
I have a kicker zx700.5 amp
Hello aj_vidal22,
Here's the link to MTX's sub page where you can view or download the information you need to properly wire the subs to your amp.
http://www.mtx.com/caraudio/products/manualsQuickInstall/subs.cfm
For maximum power, you'll need to wire the subs so that they present a 2 ohm load to the sub outputs on your amp. That will give you the full 420 watts RMS the amp is rated for. Likewise, you,ll want the run the front 4-channels at 2 ohms. Run separately, they produce 85 Watts times 4 channels, or if bridged, 130 watts times 2-channels. But if you run fronts at 4 ohms, they only produce 70 watts times 4 channels and your sub output at 4 ohms drops to 210 watts.
Hope this helps.
Apr 17, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
I dont know how many watzz is my amP!
200 X 4 does mean 200 watts times 4 channels. In other words each channel pushes out 200 watts. I believe u have a total output power of 800 watts but check with ur manual and if u do use that much power make sure you check for overheating, specially if its used for bass. Soundstorm amps cant take much of a beating so be careful.
Jan 27, 2008 | Soundstorm F200.4 Car Audio Amplifier
 Grubhead
Grubhead
