Question about Flash Pad 2.0 Touchscreen Handheld Game with Light & Sound - Black -
How do I adjust the volume on a flash pad 2.0
    New Friend:
To turn the volume off completely, press and hold the second top button from the left. (It's the spiral at the top of the Twist Me column.)
To reduce the volume, press and hold the third top button from the left. (It's the ship's wheel at the top of the Chase Me column.)
Do this when you first turn the game on. Be patient because it will take a few moments for the above volume buttons to light.
Posted on Aug 01, 2014
How fix the firmware problems with alesis dm6?
Have you updated the firmware recently? If not, do so.
If you are having volume issues, you can adjust them with the following:
Adjusting the volume of individual pads:
-Press Voice.
-Then press Volume.
-Strike the pad you would like to adjust.
-Then use the + and - buttons to adjust the volume of the individual pad.
-To adjust another pad, strike that pad, and repeat step 4 above.
Aug 04, 2014 | Alesis DM6 Electronic Drum Set
Alesis DM6 kick/bass has a really low volume-any way to make it louder?
MAKE SURE WHEN YOU ADJUST THE VOLUME YOU PRESS
SAVE , GO BACK IN A CHECK VOLUME LEVEL TO A MAX OF 16
Jan 09, 2013 | Alesis DM6 Electronic Drum Set
Where is volume control on dell laptop
Hi there! this might work :)
1.Click once on the speaker icon in the lower right corner of the laptop screen on the task bar to open the volume control.
2.Click and hold the slider control with the left mouse button or the left button on the touch pad, then drag the control higher to increase the volume on the built-in speakers.
3.Click the "Start" or Microsoft flag button in the lower left corner to access the Dell's Control Panel. Click twice on the Control Panel.
4.Click "Hardware and Sound" then click "Adjust System Volume" under the "Sound" listings.
5.Click and drag the slider control to adjust the sound level, then click the "X" box in the upper right corner to close the application.
Sep 30, 2011 | Dell Tablets & eReaders
Is there a button or switch on the computer, so that you can physically adjust the volume with out having to use the mouse?
look on the keyboard for a little icon of a speake (there may be one for up volume and one for down volume, or it may be arrowns). you press the "FN" key and then one of the arrows to raise and lower volume.
Mar 19, 2011 | ASUS U52F-BBL9 Laptop
I cant turn up the volume on the second cordless phone. how is this done/
Do you want to turn up the ringer volume or the call volume?
To adjust the volume of the ringer press the UP or DOWN arrow on the pad to bring up the main menu. Move to the 'Handset setup' icon and press OK. Select 'Ringer Setup' and press OK. Now select 'Ringer Volume' and OK. (At this point if you have 2 incoming lines you will need to select the correct line). The display will now show the volume, use the UP and DOWN arrows to adjust the volume. When finished press the OK button, then press the CALL END button to return to the main screen.
Adjusting the call volume is easier. When you are on a call use the UP and DOWN arrows to alter the volume.
I hope this helps.
Jul 19, 2010 | Panasonic (KX-TG1032S) Phone
How do you set the key pad to silent?
Hi to adjust the volume of keypad tone you need to Adjust the volume of the key tones
In Idle mode, press [Up /Down ] to adjust the key tone
volume.
Let me know if this will solve your prob
Nov 27, 2009 | Samsung B2100 Cell Phone
Touch pad/multimedia console
I have the same problem. The onliest thing is that I can't adjust the leds with the volume control center either...
Oct 02, 2009 | Acer Aspire 6920 Notebook PC
Shortage?
There is a ribbon cable between the laptop & the screen. It sounds like you have a short in that cable. If you're not good with tedius electronic repairs, it would be best to have a shop repair it.
Mar 25, 2009 | Gateway Computers & Internet
Programing
Here are some suggestions Volume You may adjust the ringer, speaker, handset and headset volumes independently with the VOLUME ^ and VOLUME v buttons. Your telephone comes with predetermined settings which can be adjusted to individual taste. You will hear an error tone when the maximum or minimum volume level is reached. During volume adjustment, a ?dashed line? icon shows in the display. Adjusting the Ringer Volume Press the VOLUME ^ or v button while in on-hook mode. And/or 1 Selecting a Ringer Tone You may select the ringer tone for each line independently. You may choose to turn the ringer off or select one of the four available ringer tones for each line. 1. Press STORE. The red indicator blinks indicating unit is in Store Mode. 2. Use the number pad to select a ringer tone 0 through 4 (selecting 0 turns the ringer off). 3. Press STORE and then press the desired line button. NOTE: The line indicators continue to flash for incoming calls even with the ringer disabled. You may not select the same ringer tone for both lines. Checking the Ringer Settings Check the setting or each ringer (on, off) by pressing STORE, followed by LINE 1 or LINE 2 button when the phone is on the hook. The ringer setting of the selected line will be shown in the display. If there are any further questions or comments please post here. Please rate this solution through fix-it. Thank you.
Jun 23, 2007 | GE 29485GE2 Three - Line Speakerphone w/...
Flash Pad 2.0 Touchscreen Handheld Game with Light & Sound - Black - Logo
1,984 people viewed this question
Top Flash Pad Video Game Consoles & Games Experts
James Wishart
Are you a Flash Pad Video Game Console and Game Expert? Answer questions, earn points and help others
