Question about Miele Novotronic W1930 Top Load Washer
Asko washing machine wont drain - Miele Novotronic W1930 Top Load Washer
    Problem Solver:
  • 10 Answers
Hi ,it could be a blocked or seized up drain pump.
You can try and clean the pump ,it normally works.
Posted on May 27, 2014
My Asko washing machine wont go into spin cycle it just keeps on washing after 3 hours I had to turn it off now what
call a technician in
the problem is most likely in the program board not progressing the wash cycle
Jul 12, 2016 | Asko W6021 Front Load Washer
Asko 10625 washing machine wont drain or open
Take the bottom panel off and there is a large drain under the drum. There will be a lot of water that comes out, so be prepared. When you take the drain off, there should be a debis trap in there. Clean this out look to make sure there are no socks or anything in there.
Nov 27, 2013 | Asko Washing Machines
Hi my asko fron load washing machine model W621 wont drain properly anymore and makes a clunking sound as it tries to spin are u able to tell me what possibly could be wrong with it & if its worth...
Not to worry, please check from the drain hose from beneath and open the hose. Look for dirt inside for clogging into the valve/drain pump. Remove and clean the valve/pump if there is dirt. If not during the spin the valves must open and drain. if not check for the controller section for fault. The clunk noise could be misalignment of the suspension or the damper unit. tighen or replace. Hope you try . Good day
Aug 13, 2010 | Asko W6021 Front Load Washer
Washing machine wont drain, door is locked, and cant get clothes out of machine, says F1 and F3 error. wat do i do?
sounds like a safety check is on. check the pump to make sure nothing is stuck in there. read the manual for checking pump on that Asko machine..
Oct 14, 2009 | Asko W6021 Front Load Washer
Hi the machine wont drain and door wont open
this is usually a drain pump tha has something stuck in it and will not allow the water to drain out.use a shop vac and put it on the end of the drain hose to drain any left over wat the check th pump for a foreign object and remove this should solve your problem.
Sep 16, 2009 | Asko W6021 Front Load Washer
ASKO D3432XLB keeps running, draining but hasn't gone into the wash cycle yet. won't turn off even when I turn the power button off.
Water on lower bottom. Leakage or blocked drain pipe. Is common error. The machine will act like this so that water wont get on your kitchen floor, in case of fault on inlet valve. The machine indicates overflow. Dry out water on bottom, and than the machine will work normaly. But check for leakage. Just in case.
Jul 18, 2009 | Asko Dishwashers
Asko 10505 runs through was cycle in approx. 30 seconds, then wont drain. Simply stops. It doesnt matter which cycle I start with, the dial moves quickly to stop. It fill with water and spins. ANY HELP...
hi sir' start the wash machine empty and see if it happens when nothing is in it.
2. When machine is off, open the top grab the centerpiece inside the wash machine and pull and push it slowly, does it move? (For safety unplug the machine)
3. Make sure machine is 100% level (front to back, left to right)
The most common thing is bad drum bearing, which force the wash machine out of whack when in spin / wash. Which are common and the best thing is to call Maytag.
thank u .........................................please rate
__________________
Sep 11, 2008 | Asko Washing Machines
We have a code F3 on our asko washing machine
Most likely a drain pump problem. Make sure there is nothing in the drain hose. Then it would be a bad drain pump
Jun 09, 2008 | Asko Washing Machines
Asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
Mar 06, 2008 | Asko W6021 Front Load Washer
Miele Novotronic W1930 Top Load Washer Logo
41 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
