JVC SP55M hdmi audio quit after power outage
HDMI audio quit after power outage
  • 151 Answers
SOURCE: No audio or video with HDMI connedction
AT THE START OF THE SET UP MENU CLICK ON IN/OUT ASSIGN.THEN MONITOR OUT APPERS,THEN HDMI NO,FLICK THIS TO ON.IFF YOU GET PICTURE AND NO SOUND GO TO THE HARDWARE SET UP AND DOWN TO HDMI AND SWITCH AUDIO OFF.
HOPE THIS HELPS.
Posted on Jun 02, 2008
SOURCE: Onkyo TX-SR606 getting no sound from HDMI sources
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Posted on Apr 05, 2009
SOURCE: No audio sound from HDMI connection from TV to Onkyo 606 amp.
if you go to the setup menu, hardware setup, hdmi, and turn the audio out: on it should work hope this helps
Posted on Jul 29, 2009
SOURCE: Sherwood RD-7502 Hdmi Audio Problem
if you have a tv with outputs you can connect audio wires from your tv output to your audio receiver input and you will have surround sound for everything connected to your tv
Posted on Aug 28, 2009
Testimonial: "That's a good idea. I hope that my TV will output the hdmi audio through the optical output on it. Thanks"
rulds2008
  • 3866 Answers
SOURCE: how to perform a master reset
Unhook all HDMI connections unplug the yamaha and your tv from the wall outlet then try again. Most cases a copy protection kicked in or the hdmi had a error on the port, Worse case is hdmi controller board failure in ether the TV or the yamaha.
thanks and do be considerate and leave postive feedback and ratings for those that have helped you today, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 29, 2010
Testimonial: "Thanks for the help. I had this same error three or four years ago and just couldn't remember how it got resolved. Can't check it tonight but I will get on it first thing in the morning. Thanks again for the prompt response and great advice."
How do i hook up my jvc player that only has audio out hook ups
See if has an HDMI output - if so get adapter wire that plugs into your JVC HDMI and terminates with the necessary RCA plug outputs of video and two audio (L & R).
Sep 14, 2015 | JVC Televison & Video
JVC SP55M HDMI sound quit after power outage
Unplug unit, wait 10 mins then plug back in. If still does not work, check for breaker trip. Be sure outlet still has power.
Nov 27, 2013 | JVC Audio Players & Recorders
No optical output except when using ipod dock on tv
Unfortunately, there is a limitation on the JVC LT47P789 digital optical audio out. This audio output does not get the signal from any HDMI source. This is described on page 49 of the user manual. The manual is available from JVC here: http://resources.jvc.com/Resources/00/01/14/YA653ien.pdf . There is a similar restriction for the analog audio output from the TV with the HDMI inputs.
If you use the component audio/video inputs on the TV from your set-top cable box and DVD player, then the optical audio output will work. Otherwise, you need to find a way to connect the audio directly to the receiver. Some receivers have multiple HDMI input ports. These then forward the video signal on their HDMI output to the TV. Another option is to connect the analog audio outputs from the cable box and DVD player to the receiver. This may require resetting the Audio output from these set-top boxes to keep from sending the audio over the HDMI cable. With the Cinemate, you might need some sort of audio input switch or an HDMI converter and switch that separates the audio from the video signal.
I hope this helps. Please add a comment with more information about your devices for ideas on how to work-around the problem with this JVC TV.
Nov 05, 2017 | JVC LT42P789 42 in. LCD TV
I get flashing green on my screen when the hdmi cable is hooked up. This only happens after a power outage. How do I reset it?
usually you need to plug the HDMI connection back in, and power everything up. Then using the menu, set the HDMI connection, back, to whatever you wish, often it is efficacious, to have the alternate unit already plugged into the set. It may also pay to reset your TV set, back to defaults.
May 19, 2010 | JVC HD-52G786 52" Rear Projection HDTV
HDMI input 1 with Analog Audio
In the audio menu there should be a setting for which audio you are using. JVC loves putting different options in there audio menu.
Oct 14, 2009 | JVC LT-46J300 46 in. LCD TV
JVC LCD TV (LT-42X688) input panel not working!
1. This TV has setting for the HDMI input that allows you to select the HDMI Audio or Analog(red/white wire) audio. Make sure this is correct
2. Most cable boxes are DVI not HDMI. If DVI then you actually do need to use those Red/white cables. If HDMI, refer back to #1.
3. The cable box has a setting to select the Audio output, HDMI (digital) or Analog(red/white cables). Just like #1, this has to be set.
4. Contact your cable company to help you set up the box correctly. JVC can probably help you check the TV
Mar 05, 2009 | JVC LT-42X688 42 in. LCD HDTV
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
HDMI interface issues
If you swapped directv receivers and the problem followed to a different tv then there is something wrong with the directv receiver. Need to run satellite setup again on this receiver to fix. repeat satellite setup is accessible through the setup submenu by pressing menu from the directv remote. look under satellite submenu once in setup
Dec 23, 2008 | JVC HD-52Z575 52" Rear Projection...
18 people viewed this question
 Grubhead
Grubhead
