Question about Homelite Mighty Lite Lawn Trimmer
Goes dead after 2 second
My homelite_mighty_lite_lawn_trimmer recently stoped working. Once I start it just goes dead after 2 seconds. Could anyone give some advise?
  • 38 Answers
Start by setting both the High and Low speed screws on the carburator to 1.5 turns out. Simply screw them both in until they are snug, and then back them out 1.5 turns. Give it a shot and see how it runs.
Please be sure to rate this solution.
Regards,
Joe
Posted on May 08, 2009
Is the homelite mighty lite a 2 stroke??
Most small engines are 2 cycle requiring oil be added to gas
Feb 08, 2011 | Homelite Mighty Lite Lawn Trimmer
Homelite Might Lite 26ss starts up but wont run for more than 20 seconds when idling and floods out when you give it throttle. i checked the fuel filter even ran it without the filter does the same thing....
I think with the symptoms that you are having, that you need to 1. Remove the carburetor 2. Inspect/Replace fuel filter and fuel lines 3.Disassemble and Clean the carburetor 4. Possibly install a new gasket and diaphragm kit or a complete rebuild kit.
Jan 26, 2011 | Homelite Mighty Lite Lawn Trimmer
Correct start proceedure
My name is Dane and I am going to help you solve your problem.
I don't know what homelite says, but I have found that this works well on any 2 cycle engine.
1. Push the primer bulb between 3 to 5 times.
2. Place choke on full.
3. Pull rope until engine fires once or starts.
4. Move choke to half choked position and allow to warm up.
5. When warm place choke in run position
If it doesn't attempt to start within the first 3-6 pulls, check your spark plug and make sure your fuel/oil mixture is correct.
I hope I've helped! Thank you! Dane
Dec 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Trimmers: Homelite Easy Reach-25cc-Model # UT20044B& Homelite Mighty Lite- 26cc- Model # UT21546 Both trimmers will start but when throttling up they cut out. They will also cut out when the choke is...
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Sep 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Can not get it started.
have you tried to replace the H T lead?
Jul 22, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite mighty lite wont stay running
the problem is in the carburetor most likely, it may be cleaned and adjusted, if not it will likely need a new carb
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer Magneto Air Gap setting 25cc
Normall setting is 10 thou but if there is no play in the crank bearings you can set at 8 thou
Jun 23, 2009 | Homelite Mighty Lite Lawn Trimmer
Correct gas to oil ratio for Homelite Mighty String Trimmer Model
most trimmers are 50:1. or 40:1. i would use synthetic 2 cycle oil and use the 50:1 ratio. i know guys with trimmers that require 50:1, and they use synthetic at 80:1 with no problems for years. they say the engine runs cleaner. i am a part-time lawn care operator.
Jun 18, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
165 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
