Question about Admiral AW22 Top Load Washer
Loud noise on Spin Cycle
On the spin cycle there is a loud vibrating noise that I just noticed. I was able to complete the load without any noticeable problems. However, I tried another load and it shut off in the middle of the spin and there was a burning smell. Checked all the functions after the burning smell and everything still works, but there is still a loud vibrating noise during the spin. Thanks
  • gwsmallwood Dec 04, 2007
    I'm having the same problem but was not brave enough to attempt to finish the load cycle.
    Problem Solver:
  • 19 Answers
CENTER SUPPORT BEARING IS BAD. VERY COSTLY IF NOT UNDER WARRANTY USE FOR BOAT ANCHOR. GOD KNOWS I HATE TELLING PEOPLE THAT. SORRY, FXIT
Posted on Jan 30, 2008
SOURCE:
Frigidare Gltf1040as0
Good Afternoon Carrie,
I understand that you are hearing a loud noise in the spin cycle as well as water leaking from your Frigidaire washer, model# GLTF1040AS0.
You will commonly hear a high pitched "jet engine" noise during the spin cycle. If you are hearing a vibrating noise, it could be your washer is not resting firmly on the floor. With this you will adjust the leveling legs so the washer is level. If after leveling your washer you are still receiving a vibrating sound, you might want to redistribute the wash load inside your appliance.
If after you redistribute the wash load, you are still hearing a loud noise in the spin cycle, I suggest contacting a local authorized technician.
For the leak I recommend contacting a technician. This way they are able to find where the leak might be coming from and repair it before there is any damage done to your appliance. Hope this is helpful.
-Best Regards-
WP
Apr 29, 2014 | Frigidaire Washing Machines
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
Spin cycle loud vibration problems on spin cycle
What is the complete model number of your unit?
Dec 04, 2012 | Washing Machines
When entering spin cycle, making a loud noise. I
Check your belt it may be lose. A lose belt will cause a squealing noise and the machine spin slower or take time to come up to full speed
Oct 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
Loud noise on spin cycle
most common cause for this is pump bearing on water pump. remove belt and attempt to turn pump by hand. if it grinds get a new pump.
Oct 08, 2009 | Maytag PAV2300 Top Load Washer
Vibration of wash machine
Hi!
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 22, 2009 | Danby Washing Machines
Loud screeching noise when spin cycle is on
Good morning! Possibly the noise was due to improper placement of load into the spinner which should be within its capacity load. best regards.
May 02, 2009 | Washing Machines
Loud spin cycle/water leaking
If your washer is making a "freight train" like noise in the spin mode, ( loud roaring ), this is often the spin bearing built into the bottom area of the transmission that is worn out. This bearing is part of the transmission and means a new transmission is required. The noise is usually a result of water leaking from the center seal and bearing area onto the transmission. This water washes out the bearing and it gets very noisy in the spin cycle!! Do check the easy stuff before condemning, nail/pin caught in one of the inner basket holes, nothing is caught in the drain pump, the inner wash basket is not loose and wobbling around.
Jan 14, 2009 | Kenmore 44102 Front Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
No longer spinning/loud noise
Did all the standing water pump out?? If sou you may have broken a drive coupling
Jan 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Admiral AW22 Top Load Washer Logo
628 people viewed this question
Top Admiral Washing Machines Experts
jimorris77
Gerry Harvey
Gerry Harvey
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
