Question about Juki DDL-8700
Irregular stitch length on heavy materials
I have a Juki DL 8700.
When sewing orthotic (double) leather straps which in part includes foam in between leather, bogs done stitch creating very unsightly work, I set stitch length to 4.5 but when sewing over irregular thickness (foam pad) feed dogs tear up leather and shorten stitch length to appox 05 - ugly! Only happens on 2 layers the leather and foam part of the strap.
Thank you
Sharon (sewer)
2 Suggested Answers
  • 43 Answers
SOURCE: skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
Posted on May 07, 2009
Juki 8700- stitch length won't go below 2.5. Knob gets stuck. How to make stitch length lower?
SLIGHTLY unscrew the large screw in the center of the stitch length knob, turn the knob to the right several clicks and retighten the screw. DON'T take it completely out, or you will make more work for your self.
Jul 07, 2016 | Juki Sewing Machines
Have a Juki 8700 what type of needle do I need to sew leather? Also what kind of leather have a Juki 8700 what type of needle do I need to sew leather? Also what kind of leather foot do I need?foot do I...
hi there
regarding your inquiry about JUKI machine model DDL-8700 , first your machine type was what ? DDL-8700/SS ( for light to medium material , DDL-8700/HS ( for jeans and can use to sew light to medium lather, type of needle is DBx1, size for lather was 18 and you can use thread number #30 and #20. one more thing you want to change your presser foot to teflon presser foot ( please see attached photo for that presser foot you want to buy.
if need more information please ask
thanks and best regards
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Mar 07, 2015 | Juki DDL-8700
I have a juki 8700-7 and error 007 can you help me
HI THERE
PLEASE SEE NEXT;
Overload of motor • When the machine head is locked. • Check whether the thread has been
entangled in the motor pulley.
• When sewing extra-heavy material beyond • Check the motor output connector (4P)
the guarantee of the machine head. for loose connection and disconnection.
• When the motor does not run.
• Motor or driver is broken. • Check whether there is any holdup when
turning the motor by hand.
BEST REGARDS
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail,com
Feb 11, 2014 | Juki DDL-8700
How to set up DDL8700 for free motion stitching i.e. Tension, stitch length etc.
i need help with my juki 8700-7 computer cs 910a
error 007
Dec 29, 2013 | Juki DDL-8700
Sewing with heavy thread, what should the tension be set on?
hi there
the tension depends on thikness of material but you must use heavy thread on needle and thin thread on bobin case .
- you must be sew fiew stitches firist and look if losse stitch from down you must tight tension slowly sloly and if there is losse stitches from upper you must tight screw for bobin case spring slowly slowly until stitch format be agood condation.
best regards
ashraf abozid
aabozid@hotmail.com
Jan 06, 2011 | Juki DDL-8700
Irregular stitches
If you mean irregular length it may be the arm that holds the feed teeth ha sworked loose slightly to see if this is it the faster you go on a max stitch length the shorter it gets. If this is the case tilt the machine head back and see were the arm is fixed at the rear sholud be 2 screws that go on to a long arm running the length of the machine and make sure these are tight. This should help.
Aug 26, 2008 | Sewing Machines
Juki stuck needle
check settings
Apr 28, 2008 | Juki DDL-8700
Problems when sewing over heavy jean hems
Are you using the correct type of needle? have a word with your needle supplier and explain the problem. Different threads and different thickness material need different top and bottom tension adjustments.
Can I suggest sew one thickness material at a time with tension adjustments for that thickness. Then change the tensions and do a batch of thicker material.
Mar 29, 2008 | Juki DDL-8700
Juki DDL-8700 Logo
62 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
