Question about HP LaserJet 3380 All-In-One Printer
HP 3380 making weird sounds.
It keeps making a sound like it is resetting and then makes a louder sound like it is trying to feed paper through. It keeps doing this for 15 minutes stops then 20 minutes later does it again.
    Novelist:
  • 152 Answers
Check for blinking lights on the control panel to determine if there is an error (consult your documentation for troubleshooting)
If you cannot determine there is an actual error, reinstall the printer's drivers.
1) Unplug any connection to your computer from this device (usb wire, scsi, cat-5 cable)
2) uninstalling the drivers from the hardware menu
3) reboot your PC
4) confirm the printer is no longer installed on your PC by going to the printers section of your control panel.
5) Follow the installation proceedure ducumented for your printer.
6) restart your PC if requested, if not go to step 7
7) test that you can print to your printer.
If this does not fix your problem, contact HP support. They may have more information for you. I'm seeing alot of these HP LJ3380's today. are they all yours?
Posted on May 29, 2009
When I try to print, the printer sounds like it wants to print but the paper does not get fed into the machine it just makes a really weird sound.
hi.... First check the lifter *** lifting the tray, when the caridge block move towards the left it pushes the plastic lock of lifter assembly to lift the tray check them for working if it works then go to next step..
clean the feed roolers & replace the paper seprator of the printor satuated on the end of paper feed tray (brown colour).
Your problem will be resolved 100%.
Aug 31, 2010 | HP DeskJet 612c InkJet Printer
Printer won't feed and makes a strange grinding sound
Its probably just old and worn out. They dont even make bubble jet printers anymore. Printers are cheap now anyway. Go to www.tigerdirect.com and you can get a printer for around 50 dollars.
Apr 10, 2009 | Canon Office Equipment & Supplies
HP Laserjet 3380 line the length of the paper.
Lift up the document feeder and clean the small scanner glass.
Mar 10, 2009 | HP LaserJet 3380 All-In-One Printer
Automatic document feed tears paper and jams in machine while trying to fax.
Make sure the unit is clean, and free of debris on the feed rollers, also make sure you are using the appropriate size of paper for your printer. Make sure your paper is seated properly per the models needs. Make sure you don't have too much paper seated.
If these solutions do not help you resolve the issue, please contact HP, or search the HP help for more information pertaining to your printer. hp.com
Printer either eats up paper or won't print anything out
what you might try is to find some thing that has been laminated on both sides and manuall feed it in to the feed rollers and see if you are able to push out what ever is in the paper path making your paper go in crooked. brother tech
Jan 17, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
HP Laserjet 3380
If it is from the adf which is on the top then there is a small piece of paper stuck in the back. open the lid and you will find a plastic holder in the back. This helps the paper turn through the adf. Usally the paper is in there or this is out of positions which will cause this.
May 12, 2008 | HP LaserJet 3380 All-In-One Printer
Paper not feeding right
Hey. I too am having that problem with my ip1800 canon printer. It makes a weird "clicking" sound whenever I turn it on, and then when I try to feed it paper, the sheets either get stuck and become crooked and cumpled. OR, when it does sound like its printing, it doesn't print on the page--maybe the tip of the page, but not the whole page.
May 02, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Hp LaserJet 1100: Runs louder than normal and continuously, BUT will not grab paper and print
Fred shine a flashlight down the paper feed throat and see if the feer roller is rotating when the printer tries to print.
I have had to replace many of the feed rolls and separation pads in this series of printer.
the tires get dirty or worn and feed multiple sheets or none at all. check for obstructions as well-sometimes the black mylar sheet which sits in front of the feed roll gets in the way of the paper path and has to be pushed in place. I have also seen paper pieces stuck next to the paper path switch which is visible after removing the toner cartridge. hope this helps.
Mar 28, 2008 | HP LaserJet 1100 Printer
HP laserjet 3380 ADF
It sounds like the rollers need to be cleaned in your ADF. Please make sure there isn't any torn paper or labels in the path of the ADF. Try qtips and some water to clean rollers. If you have roller cleaner that would be great or 91% alcohol but be very careful with the alcohol. DO NOT use anything below 91% because it can cause damage to the rollers. If this does not work you will need to replace the rollers in the ADF. Good luck.
Feb 12, 2008 | Office Equipment & Supplies
HP LaserJet 3380 All-In-One Printer Logo
126 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
